  2. Announcements
  3. 💬 Relay
💬 Relay
139 Posts 47 Posters 79.6k Views 45 Watching
  • Mitja BlazinsekM
    Mitja BlazinsekM
    Mitja Blazinsek
    Arduino: 1.8.1 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega168 (5V, 16 MHz)"
    In file included from c:\users\mitja\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\avr\io.h:99:0,
                 from c:\users\mitja\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\avr\pgmspace.h:90,
                 from C:\Users\mitja\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino/Arduino.h:28,
                 from sketch\button_relay.ino.cpp:1:
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp: In function 'bool hwUniqueID(uint8_t (*)[16])':
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:246:26: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID) = boot_signature_byte_get(0x00);
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:247:30: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID + 1) = boot_signature_byte_get(0x02);
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:248:30: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID + 2) = boot_signature_byte_get(0x04);
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:249:30: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID + 3) = boot_signature_byte_get(0x01); //OSCCAL
    Multiple libraries were found for "Bounce2.h"
    Used: C:\Users\mitja\Documents\Arduino\libraries\Bounce2
    Not used: C:\Users\mitja\Documents\Arduino\libraries\Bounce2-master
    exit status 1
    Error compiling for board Arduino Pro or Pro Mini.
    option enabled in File -> Preferences.
    • Mitja BlazinsekM
      Mitja BlazinsekM
      Mitja Blazinsek
      OK it's probaly because ia have mini with 168 chip i have to buys 328 :( again wait 1month to arive from china
      • L
        L
        lekeb
        hello.
        I am building a node with several kind of sensors and two relays.
        My sensors use CHILD ID from 0 to 3. I would like to start child ID of relay from 4.
        How I can't do that with this sketch?
        I guess I have to change this part of sketch :
        "for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        present(sensor, S_BINARY);"
        correct?
        thanks
        rejoe2R 1 Reply Last reply
        • L lekeb
          hello.
          correct?
          thanks
          rejoe2R
          rejoe2R
          rejoe2
          wrote on last edited by rejoe2
          #104
          @lekeb
          You may do something like this:
          In Header:
          uint8_t DS_First_Child_ID = 7; //First Child-ID to be used by Dallas Bus
          an then in presentation():
          for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
              present(i + DS_First_Child_ID, S_TEMP);
          But afaik, it's not recommended to shift the ChildID's for relays but always start with 1. Imo it's better to change the ChildID's of the other attached sensors. You may also take care (in case of shifting ID's) about a consistent mapping from ID to the PINs where the relays are attached.
            Agreed, set you sensors to higher ID numbers like 20 or 30 and you are good to go .
            • L
              L
              lekeb
              ok thanks a lot I will try this night
              • L
                L
                lekeb
                perfect it works great. I started my temperature sensor at CHILD ID 4 and let relays from 1 to 2. I had to add also "DS_First_Child_ID" in the sent message to gateway.
                thanks
                • pepsonP
                  pepsonP
                  pepson
                  Hi
                  Please put to this topic code your sketch....
                  • L
                    L
                    lekeb
                    Sur,
                    my node controls two relays, one water pressure sensor and three DS18b20
                     code pour controle cave a vin, temp et pression
                    //#define MY_DEBUG
                    #define MY_REPEATER_FEATURE
                    #define MY_NODE_ID 15
                    #include <OneWire.h>
                    #define BARO_CHILD 0 //Child ID for pressure sensor
                    #define BAR_SENSOR_ANALOG_PIN 0 // pin for pressure sensor
                    #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
                    #define RELAY_PIN 3 //pin for first relay
                    #define NUMBER_OF_RELAYS 2
                    int numSensors=0;
                    bool receivedConfig = false;
                    bool metric = true;
                    float lastpression;
                    uint8_t DS_First_Child_ID = 4; //First Child-ID to be used by Dallas Bus
                    MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
                    MyMessage msg(0,V_TEMP);
                    void before()
                            pinMode(pin, OUTPUT);
                      sensors.begin();
                        sendSketchInfo("Buanderie node", "1.0");
                        //present pressure sensor
                        present(BARO_CHILD, S_BARO);
                      //read water pressure
                    int lecture_adc = analogRead(BAR_SENSOR_ANALOG_PIN);
                      float pression = ((lecture_adc*5/1024.0)-0.50)/1.7;
                      if(pression != lastpression) {
                          send(pressureMsg.set(pression, 2));
                      lastpression = pression;
                      sleep(conversionTime);
                        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                        #if COMPARE_TEMP == 1
                        #else
                          send(msg.setSensor(i + DS_First_Child_ID).set(temperature,1));
                        if (message.type==V_STATUS) {
                            // Change relay state
                            digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                            // Store state in eeprom
                            // Write some debug info
                            Serial.print(message.sensor);
                    gohanG 1 Reply Last reply
                    • L lekeb
                      Sur,
                      //#define MY_DEBUG
                      int numSensors=0;
                      bool metric = true;
                      float lastpression;
                      void before()
                        sensors.begin();
                          #else
                      @lekeb said in 💬 Relay:
                      Why are you using the same child ID (since you set #define BARO_CHILD 0)?
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @gohan Effectively, he will never report any temp reading under ChildID 0. Within presentation() and the send() commands, the "0" is replaced by "i + DS_First_Child_ID".
                        But you are partly right, to avoid any misunderstandings wrt. that the statement could also be written as follows:
                        MyMessage msg(DS_First_Child_ID,V_TEMP);
                        • L
                          L
                          lekeb
                          correct, it makes sense. I will correct this error.
                          However Domoticz reads correctly the temperature and links correctly the CHILD ID's, so...
                          • Jonathan PucelJ
                            Jonathan PucelJ
                            Jonathan Pucel
                            Hello everybody !
                            I would like to creat a sensor with two relays and two buttons to command this relay direct from the sensor (with actualisation of their stat in domoticz)
                            Someone know the code to do this ? I'm a complete newbie on mysensor !
                            Thank's a lot !
                            • Jonathan PucelJ Jonathan Pucel
                              Hello everybody !
                              Thank's a lot !
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @jonathan-pucel Have a look at the code in this post.
                              • Jonathan PucelJ
                                Jonathan PucelJ
                                Jonathan Pucel
                                Excellent ! It's perfect, thank's a lot rejoe2 !
                                  mysz0n
                                  This post is deleted!
                                  • V
                                    V
                                    Vorace
                                    Hi
                                    Using Home assistant, and Optimistic set to false in the mysensors config, the switch in homeassistant would turn the relay on, but in the view in homeassistant the flip switch jumped off straight after switching on. It was solved by adding the following line to the sketch, ensuring that hassio knows that the actuator actually have received the command. Not sure if this is a good way of doing it, but it seems to work for me.
                                    send(msg.set(state)); // Send new state and request ack back
                                    in:
                                    if (message.isAck()) {
                                    state = message.getBool();
                                    saveState(CHILD_ID, state);
                                    • A
                                      A
                                      arraWX
                                      wrote on last edited by arraWX
                                      #118
                                      Hi!
                                      I would like to control some 230VAC equipment (for now roller shutters), based on inputs from my mysensors sensors (temperature and light). For controller I use domoticz.
                                      I would like a safe, robust and preferably authorized/lawful solution (I'm in EU/Denmark).
                                      I came across the following solutions:
                                      https://aeotec.com/z-wave-plug-in-switch
                                      https://sonoff.itead.cc/en/products/sonoff/sonoff-basic
                                      https://dlidirect.com/products/iot-power-relay
                                      I think the first one and maybe the second one will be authorized/lawful...? However, I have experience only with mysensors and neither z wave nor sonoff...
                                      Anyone has some experience/thoughts/suggestions to share?
                                      Thanks.
                                        There are also roller shutters nodes running via zwave if you are looking at a retail solution
                                        A 1 Reply Last reply
                                          A
                                          A
                                          arraWX
                                          #120
                                          Thank you @gohan! Retail solution is not the keyword here. What I am searching for is an authorized/lawful (safe) solution.
                                          I decided to do my own node (mysensors) with a cheap relay module for the arduino. Once I achieve the desired functionality I will change to some more robust hardware. Following your suggestion this could be a z wave roller shutter (e.g. fibaro or qubino).
                                          bjacobseB 1 Reply Last reply
