💬 Temperature Sensor
I use USB pretty much all the time and never had any issue. I had many problems in the beginning with radio modules that had the black blob instead of the ic and once I got the new ones everything started to work. I'm still working on increasing the range, probably because they are clones and not good quality.
Is it also possible to upload the example code to a Arduino Nano, and connect it via USB to a Windows PC with Domoticz?
Or will it only work with the radio modules (and extra gateway?)
Thank you for posting this project!
Could like to suggest a small change to the sketch. There are several posts out there about this not running with the latest DallasTemperature library. The call to sensors.millisToWaitForConversion won't compile because the method is not public. From another post I learned that this method is very simple and could be included in the sketch. I would suggest changing the line
to read
int16_t conversionTime = millisToWaitForConversion(sensors.getResolution());
and add this function to the sketch:
int16_t millisToWaitForConversion(uint8_t bitResolution)
switch (bitResolution)
case 9:
return 94;
case 10:
return 188;
case 11:
return 375;
default:
return 750;
}In any case, this might help the next person using this project.
I had some problems with Domoticz triggering an event based on a certain temperature. When using multiple DS18B20 it is a good idea to use the ID of the sensors to always get the same order of sensors. If one is not read, for example B of A, B, C then C becomes B. See: https://forum.mysensors.org/topic/4143/about-ds18b20-onewire for more info. You maybe need to adjust the sketch a bit for your number of sensors.
could you explain how to solve this ?
I'm no pro, and wanted to use 1 single DS1820 in a sketch and also got same message about :
int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());Mysensors is hard hard nut to learn, specially because of a lot of changes in the newer version 2.1.0 ...(and im still learning to work with arduino software , i keep running often against old sketches i like to try as sample to use them in other sketches , (my way of learning) but than they dont work with latest version. because something changed.
but i love the mysensors functions.p.s sorry for my bad english....
@Rene046 The solution is here:https://forum.mysensors.org/topic/4828/temperature-sensor/46
I sofar got the sketch running and giving good data on serial and into domoticz
i only could use some help with how to sent my Temperature in Celsius to domoticz to
i tried to use:
send(msgTemp.set(insideThermometer ,2));
and
send(msgTemp.set(tempC,2));both without luck, the first did transmit some data but wrong numbers
second did nothing think because with this i done i does not know what address the DS1820 is on.Im learning every day something new....
Maybe someone could help,
forgot the sketch
// Enable debug prints to serial monitor #define MY_DEBUG // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #include <SPI.h> #include <MySensors.h> #include <BH1750.h> #include <Wire.h> #include <OneWire.h> #include <DallasTemperature.h> // Data wire is plugged into port 3 on the Arduino #define ONE_WIRE_BUS 3 // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) OneWire oneWire(ONE_WIRE_BUS); // Pass our oneWire reference to Dallas Temperature. DallasTemperature sensors(&oneWire); // arrays to hold device address DeviceAddress insideThermometer; unsigned long SLEEP_TIME = 180000; // Sleep time between reads (in milliseconds) int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point int SOLAR_SENSE_PIN = A1; // select the input pin for the solar sense point #define CHILD_ID_BATTERY 4 #define CHILD_ID_SOLAR 6 #define CHILD_ID_LIGHT 1 #define CHILD_ID_TEMP1 2 BH1750 lightSensor; int oldBatteryPcnt = 0; MyMessage msgTemp(CHILD_ID_TEMP1,V_TEMP); MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE); MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE); MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL); uint16_t lastlux; //lux void setup(void) { // use the 1.1 V internal reference #if defined(__AVR_ATmega2560__) analogReference(INTERNAL1V1); #else analogReference(INTERNAL); #endif // Send the sketch version information to the gateway and Controller sendSketchInfo("Battery Meter", "2.0"); present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); //Serial.begin(9600); // start serial port Serial.print("Locating devices..."); // locate devices on the bus sensors.begin(); // start reading sensor Serial.print("Found "); Serial.print(sensors.getDeviceCount(), DEC); Serial.println(" devices."); Serial.print("Parasite power is: "); // report parasite power requirements if (sensors.isParasitePowerMode()) Serial.println("ON"); else Serial.println("OFF"); // assign address manually. the addresses below will beed to be changed // to valid device addresses on your bus. device address can be retrieved // by using either oneWire.search(deviceAddress) or individually via // sensors.getAddress(deviceAddress, index) //insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 }; // Method 1: // search for devices on the bus and assign based on an index. ideally, // you would do this to initially discover addresses on the bus and then // use those addresses and manually assign them (see above) once you know // the devices on your bus (and assuming they don't change). if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0"); // method 2: search() // search() looks for the next device. Returns 1 if a new address has been // returned. A zero might mean that the bus is shorted, there are no devices, // or you have already retrieved all of them. It might be a good idea to // check the CRC to make sure you didn't get garbage. The order is // deterministic. You will always get the same devices in the same order // // Must be called before search() //oneWire.reset_search(); // assigns the first address found to insideThermometer //if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer"); // show the addresses we found on the bus Serial.print("Device 0 Address: "); printAddress(insideThermometer); Serial.println(); // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions) sensors.setResolution(insideThermometer, 9); Serial.print("Device 0 Resolution: "); Serial.print(sensors.getResolution(insideThermometer), DEC); Serial.println(); } // function to print the temperature for a device void printTemperature(DeviceAddress deviceAddress) { // method 1 - slower //Serial.print("Temp C: "); //Serial.print(sensors.getTempC(deviceAddress)); //Serial.print(" Temp F: "); //Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit // method 2 - faster float tempC = sensors.getTempC(deviceAddress); Serial.print("Temp C: "); Serial.print(tempC); Serial.print(" Temp F: "); Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit } void loop(void) { // call sensors.requestTemperatures() to issue a global temperature // request to all devices on the bus Serial.print("Requesting temperatures..."); sensors.requestTemperatures(); // Send the command to get temperatures Serial.println("DONE"); // It responds almost immediately. Let's print out the data printTemperature(insideThermometer); // Use a simple function to print out the data { // get the battery Voltage int sensorValue2 = analogRead(BATTERY_SENSE_PIN); delay(1000); int sensorValue1 = analogRead(BATTERY_SENSE_PIN); delay(100); int sensorValue = analogRead(BATTERY_SENSE_PIN); delay(1000); int sensorValueS = analogRead(SOLAR_SENSE_PIN); delay(1000); #ifdef MY_DEBUG Serial.print("Battery Voltage2: "); Serial.println(sensorValue2); Serial.print("Battery Voltage1: "); Serial.println(sensorValue1); Serial.print("Battery Voltage: "); Serial.println(sensorValue); Serial.print("Solar Voltage: "); Serial.println(sensorValueS); #endif // 1M, 470K divider across battery and using internal ADC ref of 1.1V // Sense point is bypassed with 0.1 uF cap to reduce noise at that point // ((1e6+470e3)/470e3)*1.1 = Vmax = 3.44 Volts // 3.44/1023 = Volts per bit = 0.003363075 const float vRef = 4.200/ 1.05/ 1023 ; int batteryPcnt = sensorValue / 10; float batteryV = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt float batteryS = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt #ifdef MY_DEBUG Serial.print("Battery Voltage: "); Serial.print(batteryV); Serial.println(" V"); send(msgbatt.set(batteryV ,2)); Serial.print("Solar Voltage: "); Serial.print(batteryS); Serial.println(" V"); send(msgsolar.set(batteryS ,2)); Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %"); #endif if (oldBatteryPcnt != batteryPcnt) { // Power up radio after sleep sendBatteryLevel(batteryPcnt); oldBatteryPcnt = batteryPcnt; } uint16_t lux = lightSensor.readLightLevel();// Get Lux value Serial.println(lux); if (lux != lastlux) { send(msg.set(lux)); lastlux = lux; } sleep(SLEEP_TIME); }} // function to print a device address void printAddress(DeviceAddress deviceAddress) { for (uint8_t i = 0; i < 8; i++) { if (deviceAddress[i] < 16) Serial.print("0"); Serial.print(deviceAddress[i], HEX); } } -
forgot the sketch
// Enable debug prints to serial monitor #define MY_DEBUG // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #include <SPI.h> #include <MySensors.h> #include <BH1750.h> #include <Wire.h> #include <OneWire.h> #include <DallasTemperature.h> // Data wire is plugged into port 3 on the Arduino #define ONE_WIRE_BUS 3 // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) OneWire oneWire(ONE_WIRE_BUS); // Pass our oneWire reference to Dallas Temperature. DallasTemperature sensors(&oneWire); // arrays to hold device address DeviceAddress insideThermometer; unsigned long SLEEP_TIME = 180000; // Sleep time between reads (in milliseconds) int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point int SOLAR_SENSE_PIN = A1; // select the input pin for the solar sense point #define CHILD_ID_BATTERY 4 #define CHILD_ID_SOLAR 6 #define CHILD_ID_LIGHT 1 #define CHILD_ID_TEMP1 2 BH1750 lightSensor; int oldBatteryPcnt = 0; MyMessage msgTemp(CHILD_ID_TEMP1,V_TEMP); MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE); MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE); MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL); uint16_t lastlux; //lux void setup(void) { // use the 1.1 V internal reference #if defined(__AVR_ATmega2560__) analogReference(INTERNAL1V1); #else analogReference(INTERNAL); #endif // Send the sketch version information to the gateway and Controller sendSketchInfo("Battery Meter", "2.0"); present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); //Serial.begin(9600); // start serial port Serial.print("Locating devices..."); // locate devices on the bus sensors.begin(); // start reading sensor Serial.print("Found "); Serial.print(sensors.getDeviceCount(), DEC); Serial.println(" devices."); Serial.print("Parasite power is: "); // report parasite power requirements if (sensors.isParasitePowerMode()) Serial.println("ON"); else Serial.println("OFF"); // assign address manually. the addresses below will beed to be changed // to valid device addresses on your bus. device address can be retrieved // by using either oneWire.search(deviceAddress) or individually via // sensors.getAddress(deviceAddress, index) //insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 }; // Method 1: // search for devices on the bus and assign based on an index. ideally, // you would do this to initially discover addresses on the bus and then // use those addresses and manually assign them (see above) once you know // the devices on your bus (and assuming they don't change). if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0"); // method 2: search() // search() looks for the next device. Returns 1 if a new address has been // returned. A zero might mean that the bus is shorted, there are no devices, // or you have already retrieved all of them. It might be a good idea to // check the CRC to make sure you didn't get garbage. The order is // deterministic. You will always get the same devices in the same order // // Must be called before search() //oneWire.reset_search(); // assigns the first address found to insideThermometer //if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer"); // show the addresses we found on the bus Serial.print("Device 0 Address: "); printAddress(insideThermometer); Serial.println(); // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions) sensors.setResolution(insideThermometer, 9); Serial.print("Device 0 Resolution: "); Serial.print(sensors.getResolution(insideThermometer), DEC); Serial.println(); } // function to print the temperature for a device void printTemperature(DeviceAddress deviceAddress) { // method 1 - slower //Serial.print("Temp C: "); //Serial.print(sensors.getTempC(deviceAddress)); //Serial.print(" Temp F: "); //Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit // method 2 - faster float tempC = sensors.getTempC(deviceAddress); Serial.print("Temp C: "); Serial.print(tempC); Serial.print(" Temp F: "); Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit } void loop(void) { // call sensors.requestTemperatures() to issue a global temperature // request to all devices on the bus Serial.print("Requesting temperatures..."); sensors.requestTemperatures(); // Send the command to get temperatures Serial.println("DONE"); // It responds almost immediately. Let's print out the data printTemperature(insideThermometer); // Use a simple function to print out the data { // get the battery Voltage int sensorValue2 = analogRead(BATTERY_SENSE_PIN); delay(1000); int sensorValue1 = analogRead(BATTERY_SENSE_PIN); delay(100); int sensorValue = analogRead(BATTERY_SENSE_PIN); delay(1000); int sensorValueS = analogRead(SOLAR_SENSE_PIN); delay(1000); #ifdef MY_DEBUG Serial.print("Battery Voltage2: "); Serial.println(sensorValue2); Serial.print("Battery Voltage1: "); Serial.println(sensorValue1); Serial.print("Battery Voltage: "); Serial.println(sensorValue); Serial.print("Solar Voltage: "); Serial.println(sensorValueS); #endif // 1M, 470K divider across battery and using internal ADC ref of 1.1V // Sense point is bypassed with 0.1 uF cap to reduce noise at that point // ((1e6+470e3)/470e3)*1.1 = Vmax = 3.44 Volts // 3.44/1023 = Volts per bit = 0.003363075 const float vRef = 4.200/ 1.05/ 1023 ; int batteryPcnt = sensorValue / 10; float batteryV = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt float batteryS = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt #ifdef MY_DEBUG Serial.print("Battery Voltage: "); Serial.print(batteryV); Serial.println(" V"); send(msgbatt.set(batteryV ,2)); Serial.print("Solar Voltage: "); Serial.print(batteryS); Serial.println(" V"); send(msgsolar.set(batteryS ,2)); Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %"); #endif if (oldBatteryPcnt != batteryPcnt) { // Power up radio after sleep sendBatteryLevel(batteryPcnt); oldBatteryPcnt = batteryPcnt; } uint16_t lux = lightSensor.readLightLevel();// Get Lux value Serial.println(lux); if (lux != lastlux) { send(msg.set(lux)); lastlux = lux; } sleep(SLEEP_TIME); }} // function to print a device address void printAddress(DeviceAddress deviceAddress) { for (uint8_t i = 0; i < 8; i++) { if (deviceAddress[i] < 16) Serial.print("0"); Serial.print(deviceAddress[i], HEX); } }@Rene046 Your sketch doesn't show either of the send commands you say you are attempting. This makes it difficult to determine why it wouldn't be working. I am relative new to all of this as well, and use Vera not a Domoticz. On the first version that is sending a message, what data is getting through? I would try putting the "send" command someplace in the code where msgTemp has already been set. Then just call send(msgTemp).
hi
Then i would have placed this in the loop>
The error i get then is :'TempC' was not declared in this scope#ifdef MY_DEBUG Serial.print("DS1820 Temperature: "); Serial.print(tempC); Serial.println(" C"); send(msgTemp.set(tempC ,2)); Serial.print("Battery Voltage: "); Serial.print(batteryV); Serial.println(" V"); send(msgbatt.set(batteryV ,2));``` -
so far my result.
had to use float TempC = 50.5 at the start
but in my serial i get the right temperature,
but using it in the loop gives me still wrong number 50.5 so gets not updated.// Enable debug prints to serial monitor #define MY_DEBUG // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #include <SPI.h> #include <MySensors.h> #include <BH1750.h> #include <Wire.h> #include <OneWire.h> #include <DallasTemperature.h> // Data wire is plugged into port 3 on the Arduino #define ONE_WIRE_BUS 3 // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) OneWire oneWire(ONE_WIRE_BUS); // Pass our oneWire reference to Dallas Temperature. DallasTemperature sensors(&oneWire); // arrays to hold device address DeviceAddress insideThermometer; unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point int SOLAR_SENSE_PIN = A1; // select the input pin for the solar sense point #define CHILD_ID_BATTERY 4 #define CHILD_ID_SOLAR 6 #define CHILD_ID_LIGHT 1 #define CHILD_ID_TEMP1 2 BH1750 lightSensor; float TempC = 50.5; int oldBatteryPcnt = 0; MyMessage msgTemp(CHILD_ID_TEMP1,V_TEMP); MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE); MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE); MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL); uint16_t lastlux; //lux void setup(void) { // use the 1.1 V internal reference #if defined(__AVR_ATmega2560__) analogReference(INTERNAL1V1); #else analogReference(INTERNAL); #endif // Send the sketch version information to the gateway and Controller sendSketchInfo("Battery Meter", "2.0"); present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); //Serial.begin(9600); // start serial port Serial.print("Locating devices..."); // locate devices on the bus sensors.begin(); // start reading sensor Serial.print("Found "); Serial.print(sensors.getDeviceCount(), DEC); Serial.println(" devices."); Serial.print("Parasite power is: "); // report parasite power requirements if (sensors.isParasitePowerMode()) Serial.println("ON"); else Serial.println("OFF"); // assign address manually. the addresses below will beed to be changed // to valid device addresses on your bus. device address can be retrieved // by using either oneWire.search(deviceAddress) or individually via // sensors.getAddress(deviceAddress, index) //insideThermometer = { 0x10, 0x9C, 0x04, 0x26, 0x01, 0x08, 0x0, 0x8C }; // Method 1: // search for devices on the bus and assign based on an index. ideally, // you would do this to initially discover addresses on the bus and then // use those addresses and manually assign them (see above) once you know // the devices on your bus (and assuming they don't change). if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0"); // method 2: search() // search() looks for the next device. Returns 1 if a new address has been // returned. A zero might mean that the bus is shorted, there are no devices, // or you have already retrieved all of them. It might be a good idea to // check the CRC to make sure you didn't get garbage. The order is // deterministic. You will always get the same devices in the same order // // Must be called before search() //oneWire.reset_search(); // assigns the first address found to insideThermometer //if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer"); // show the addresses we found on the bus Serial.print("Device 0 Address: "); printAddress(insideThermometer); Serial.println(); // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions) sensors.setResolution(insideThermometer, 9); Serial.print("Device 0 Resolution: "); Serial.print(sensors.getResolution(insideThermometer), DEC); Serial.println(); } // function to print the temperature for a device void printTemperature(DeviceAddress deviceAddress) { // method 1 - slower //Serial.print("Temp C: "); //Serial.print(sensors.getTempC(deviceAddress)); //Serial.print(" Temp F: "); //Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit // method 2 - faster float TempC = sensors.getTempC(deviceAddress); Serial.print("Temp C: "); Serial.print(TempC); Serial.print(" Temp F: "); Serial.println(DallasTemperature::toFahrenheit(TempC)); // Converts tempC to Fahrenheit } void loop(void) { // call sensors.requestTemperatures() to issue a global temperature // request to all devices on the bus Serial.print("Requesting temperatures..."); sensors.requestTemperatures(); // Send the command to get temperatures Serial.println("DONE"); // It responds almost immediately. Let's print out the data printTemperature(insideThermometer); // Use a simple function to print out the data { // get the battery Voltage int sensorValue2 = analogRead(BATTERY_SENSE_PIN); delay(1000); int sensorValue1 = analogRead(BATTERY_SENSE_PIN); delay(100); int sensorValue = analogRead(BATTERY_SENSE_PIN); delay(1000); int sensorValueS = analogRead(SOLAR_SENSE_PIN); delay(1000); #ifdef MY_DEBUG Serial.print("Battery Voltage2: "); Serial.println(sensorValue2); Serial.print("Battery Voltage1: "); Serial.println(sensorValue1); Serial.print("Battery Voltage: "); Serial.println(sensorValue); Serial.print("Solar Voltage: "); Serial.println(sensorValueS); #endif // 1M, 470K divider across battery and using internal ADC ref of 1.1V // Sense point is bypassed with 0.1 uF cap to reduce noise at that point // ((1e6+470e3)/470e3)*1.1 = Vmax = 3.44 Volts // 3.44/1023 = Volts per bit = 0.003363075 const float vRef = 4.200/ 1.05/ 1023 ; int batteryPcnt = sensorValue / 10; float batteryV = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt float batteryS = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt #ifdef MY_DEBUG Serial.print("DS1820 Temperature: "); Serial.print(TempC); Serial.println(" C"); send(msgTemp.set(TempC ,2)); Serial.print("Battery Voltage: "); Serial.print(batteryV); Serial.println(" V"); send(msgbatt.set(batteryV ,2)); Serial.print("Solar Voltage: "); Serial.print(batteryS); Serial.println(" V"); send(msgsolar.set(batteryS ,2)); Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %"); #endif if (oldBatteryPcnt != batteryPcnt) { // Power up radio after sleep sendBatteryLevel(batteryPcnt); oldBatteryPcnt = batteryPcnt; } uint16_t lux = lightSensor.readLightLevel();// Get Lux value Serial.println(lux); if (lux != lastlux) { send(msg.set(lux)); lastlux = lux; } sleep(SLEEP_TIME); }} // function to print a device address void printAddress(DeviceAddress deviceAddress) { for (uint8_t i = 0; i < 8; i++) { if (deviceAddress[i] < 16) Serial.print("0"); Serial.print(deviceAddress[i], HEX); } } -
here is my serial result.
45651 MCO:SLP:WUP=-1
Requesting temperatures...DONE
Temp C: 17.87 Temp F: 64.18
Battery Voltage2: 931
Battery Voltage1: 926
Battery Voltage: 927
Solar Voltage: 393
DS1820 Temperature: 50.50 C
49545 TSF:MSG:SEND,2-2-0-0,s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:50.50
Battery Voltage: 3.95 V
49557 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.95
Solar Voltage: 4.03 V
49569 TSF:MSG:SEND,2-2-0-0,s=6,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:4.03
Battery percent: 92 %
49577 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
49584 MCO:SLP:TPD -
i dont know how but i got it now running perfect, and cleaned up a bid.
for if anyone could use ....// Enable debug prints to serial monitor #define MY_DEBUG // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #include <SPI.h> #include <MySensors.h> #include <BH1750.h> #include <Wire.h> #include <OneWire.h> #include <DallasTemperature.h> // Data wire is plugged into port 3 on the Arduino #define ONE_WIRE_BUS 3 // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) OneWire oneWire(ONE_WIRE_BUS); // Pass our oneWire reference to Dallas Temperature. DallasTemperature sensors(&oneWire); // arrays to hold device address DeviceAddress insideThermometer; unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point int SOLAR_SENSE_PIN = A1; // select the input pin for the solar sense point #define CHILD_ID_BATTERY 4 #define CHILD_ID_SOLAR 6 #define CHILD_ID_LIGHT 1 #define CHILD_ID_TEMP1 2 BH1750 lightSensor; float TempC = 50.5; int oldBatteryPcnt = 0; MyMessage msgTempC(CHILD_ID_TEMP1,V_TEMP); MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE); MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE); MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL); uint16_t lastlux; //lux void setup(void) { // use the 1.1 V internal reference #if defined(__AVR_ATmega2560__) analogReference(INTERNAL1V1); #else analogReference(INTERNAL); #endif // Send the sketch version information to the gateway and Controller sendSketchInfo("Battery Meter", "2.0"); present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); sensors.begin(); // start reading sensor // search for devices on the bus and assign based on an index. ideally, if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0"); // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions) //sensors.setResolution(insideThermometer, 9); } void loop(void) { // get the battery Voltage int sensorValue2 = analogRead(BATTERY_SENSE_PIN); delay(1000); int sensorValue1 = analogRead(BATTERY_SENSE_PIN); delay(100); int sensorValue = analogRead(BATTERY_SENSE_PIN); delay(1000); int sensorValueS = analogRead(SOLAR_SENSE_PIN); delay(1000); #ifdef MY_DEBUG Serial.print("Battery Voltage2: "); Serial.println(sensorValue2); Serial.print("Battery Voltage1: "); Serial.println(sensorValue1); Serial.print("Battery Voltage: "); Serial.println(sensorValue); Serial.print("Solar Voltage: "); Serial.println(sensorValueS); #endif // 1M, 470K divider across battery and using internal ADC ref of 1.1V // Sense point is bypassed with 0.1 uF cap to reduce noise at that point // ((1e6+470e3)/470e3)*1.1 = Vmax = 3.44 Volts // 3.44/1023 = Volts per bit = 0.003363075 const float vRef = 4.200/ 1.05/ 1023 ; int batteryPcnt = sensorValue / 10; float batteryV = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt float batteryS = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt float TempC = sensors.getTempC(insideThermometer); #ifdef MY_DEBUG Serial.print("DS1820 Temperature: "); Serial.print(TempC); Serial.println(" C"); send(msgTempC.set(TempC ,2)); Serial.print("Battery Voltage: "); Serial.print(batteryV); Serial.println(" V"); send(msgbatt.set(batteryV ,2)); Serial.print("Solar Voltage: "); Serial.print(batteryS); Serial.println(" V"); send(msgsolar.set(batteryS ,2)); Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %"); #endif if (oldBatteryPcnt != batteryPcnt) { // Power up radio after sleep sendBatteryLevel(batteryPcnt); oldBatteryPcnt = batteryPcnt; } uint16_t lux = lightSensor.readLightLevel();// Get Lux value Serial.println(lux); if (lux != lastlux) { send(msg.set(lux)); lastlux = lux; } sleep(SLEEP_TIME); } -
Can someone push me into the right direction.
I followed the "tutorial" and setup a Serial Gateway. This seems to be running just fine.Now i want to add a node with a temperature sensor.
Both are using the NRF24L radio.
On my node i get an errors in the serial monitor.
What did i do wrong?0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1 3 MCO:BGN:BFR 63 TSM:INIT 64 TSF:WUR:MS=0 71 !TSM:INIT:TSP FAIL 72 TSM:FAIL:CNT=1 74 TSM:FAIL:PDT 10077 TSM:FAIL:RE-INIT 10079 TSM:INIT 10085 !TSM:INIT:TSP FAIL 10088 TSM:FAIL:CNT=2 10089 TSM:FAIL:PDT -
