  3. distance + relay node
6 Posts 3 Posters 2.5k Views 2 Watching
  • carlekiC
    carlekiC
    carleki
    Hello, I'm trying to aggregate 2 sketches : distance and relay actuator node ...
    But I think I'm going the wrong way because it doesn't work ...
    Here is my code :
    // Sketch pour commander un relai en mode impultionnel.
    #include <NewPing.h>
    // relais
    int node_id = 9;
    // distance
    #define CHILD_ID 1
    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage msg(CHILD_ID, V_DISTANCE);
    int lastDist;
    boolean metric = true;
      //gw.begin(incomingMessage, AUTO, true);
      gw.begin(NULL, node_id);
      gw.sendSketchInfo("RelaisPulDist", "1.1");
      // Fetch relay status
        gw.present(RELAY_1, S_LIGHT);
        gw.present(CHILD_ID, S_DISTANCE);
        boolean metric = gw.getConfig().isMetric;
        pinMode(RELAY_1, OUTPUT);
        digitalWrite(RELAY_1, RELAY_OFF);
      gw.process();
       int dist = metric?sonar.ping_cm():sonar.ping_in();
      Serial.print("Ping: ");
      Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      Serial.println(metric?" cm":" in");
      if (dist != lastDist) {
          send(msg.set(dist));
          lastDist = dist;
      if (message.type==V_LIGHT) {
         // Change relay state
        digitalWrite(RELAY_1, RELAY_ON);
        delay(500);
    Can you see what's going wrong ?
    thanls !
      Could you share any details on "it doesn't work"?
      carlekiC 1 Reply Last reply
        carlekiC
        carlekiC
        carleki
        The distance stays at 0 cm on my controller, and the relay actuator isn't triggered when I click it on my controller (I use my sensors with Jeedom)
        • carlekiC carleki
          @carmelo24 this is my motion and distance sketch:
          https://github.com/sundberg84/MySensors-2.0/blob/master/Padd13/MotionDistNoSleepAs.ino
          Note its for 2.0 and not using sleep()
          0 distance is (for me) an error value or fail to read the distance, i have used
          if (dist == 0){
              return;
          To force the distance senor to do a new calculation and it works for me.
          It could be a issue with your sensor, power or hardware if you get it all the time.
          Look at your serial output and see for the node.
          • carlekiC
            carlekiC
            carleki
            So this is my sketch right now. The relay works ok, but I have only 0cm or 1cm with for the distance (and I can hear a sound coming from the distance sensor ...) :
            #define node_id 66
            #define CHILD_ID 1
            //int lastDist;
              gw.begin(incomingMessage, node_id, true);
              gw.sendSketchInfo("RelayDistance", "1.1");
              gw.process();
             // if (dist != lastDist) {
               //   gw.send(msg.set(dist));
                //  lastDist = dist;
                delay(100);
                 delay(100);
                delay(100);
                 delay(100);
                delay(100);
                 delay(100);
                delay(100);
            • carlekiC carleki
              #define node_id 66
              #define CHILD_ID 1
              //int lastDist;
                gw.process();
                  //  lastDist = dist;
                  delay(100);
                   delay(100);
                  delay(100);
                   delay(100);
                  delay(100);
                   delay(100);
                  delay(100);
              carlekiC
              carlekiC
              carleki
              @carmelo24 it's ok now :)
              here is my sketch :
              #define node_id 66
              #define CHILD_ID 1
              unsigned long SLEEP_TIME = 500; // Sleep time between reads (in milliseconds)
              long temps;
                  temps = millis();
                gw.process();
              // mesure de la distance si ça fait plus de 10 secondes qu'on ne l'a pas fait
               if((millis() - temps) > 10000) {
                     Serial.print(dist);
                     Serial.print("toto");
               temps = millis();
              // action du relais (avec impulsion, pour action comme un bouton poussoir)
                  delay(100);
                   delay(100);
