  3. BME280 How to use it outdoors
36 Posts 9 Posters 36.3k Views 10 Watching
  • R r-nox
    Are you over working it? Is that even possible?
    karl261K
    karl261K
    karl261
    @r-nox You mean too many readings per time unit?
    • R
      R
      r-nox
      That's my line of thought.
      karl261K 1 Reply Last reply
      • R r-nox
        karl261K
        karl261K
        karl261
        @r-nox Hm, it is reading every 15 seconds at the moment. Do you think this is too much?
        The current sensor is not completely broken, it seems. Sometimes it is showing "normal" values. I brought it into the house to test it, and in the house it seems to show normal values. I will know more tomorrow morning.
        According to its specs it is supposed to be good for weather monitoring. But then, it seems it does not like "weather" too much.
        I also found it strange that in the past 30 days the maximum humidity it read was 87 %. And for sure there were plenty of nights here with 100 %. But ok, I could live with that. But it has started to show far too low values for humidity, down to 0 %. I'll leave it in the house for 1-2 days and then see how it behaves outside.
        • R
          R
          r-nox
          I don't know the specs for reading it off hand. Perhaps your housing is holding humidity. I plan to add a fan to mine. Spin the fan for a few moments before reading to cycle the air.
          • karl261K
            karl261K
            karl261
            So, this story also continues. After having these problems, I brought the sensor into the house and left it running for the past several weeks in the living room. Actually it is working fine. No more problems.
            Now, for Christmas, I have brought it back outside to the birdhouse. And it is still working fine, even at -10 °C. Let's see how long it will last this time.
            What I also noticed is that now I have a second of these in the greenhouse where the humidity is definitely from time to time 100%. At 4°C. But both outdoor sensors somehow never reach 100%, but stop somewhere between 85-90%. It seems they are not made to detect 100% humidity.
            • karl261K
              karl261K
              karl261
              Now after 2-3 month more outside the sensor seems to be finally dead. No reaction anymore. Also the 2nd one in the greenhouse does not reply anymore. I'll have to check. The one in the living room is fine.
              It seems that at least the ones I bought are not really lasting long outdoors.
              parachutesjP 1 Reply Last reply
              • R
                R
                r-nox
                Time to try something else.
                • ferroF
                  ferroF
                  ferro
                  What about to use PTFE (teflon) tape to protect the sensor board, see this project. It seems, characteristics of the material (PTFE) enables it to use it for this purpose, it is mentioned also link text here
                  • karl261K
                    karl261K
                    karl261
                    wrote on last edited by karl261
                    #29
                    Interesting idea, the ptfe tape. I will try it with the next sensor!
                    So, only the outdoor sensors fail. It is now more than one that failed.
                    I have one in the living room -- perfect.
                    And, very strange: I have one in the green house. Huge T differences, sometimes very hot, and often 100% humidity. Actually conditions should be worse for this sensor compared to the outdoor sensor. But: it is just fine.
                    Weird.
                    • D
                      D
                      DavidZH
                      @karl261 Do you happen to live near te sea? Because salty air wreaks havoc on anything sooner or later. Tiny electronics rather sooner...
                      I have a BME280 outside and that's been running for over a year now. It's pretty well protected though, but it catches a few hours of direct sunlight per day.
                      • karl261K
                        karl261K
                        karl261
                        #31
                        Hi, no, I live rather far from the sea. I don't know what is killing the outdoor sensor. The same in the greenhouse survives much weirder temperatures and humidities.
                        ร 1 Reply Last reply
                        • karl261K karl261
                          ร
                          ร
                          รอเรือ
                          @karl261 Any update on this topic?
                          Are you still struggling with that your BME280s don't seem to last long time outdoors?
                          • ร รอเรือ
                            ร
                            ร
                            รอเรือ
                            Anyway. My crappy BME280 clone that I bought on ebay for $8.98 (in December 2016) lasted only for 4 days.
                            Now I will have to take down my weather station and repair it.
                            I will now buy an original Adafruit BME280 for 289 SEK (32$) + postage. I hope that one will last.
                            skywatchS 1 Reply Last reply
                            • ร รอเรือ
                              skywatchS
                              skywatchS
                              skywatch
                              @รอเร-อ
                              I got 2x "BME280" from China today - they are not bosch sensors. If you are having problems, check carefully the markings with magnifying glass or microscope.
                              This may be the problem.....??
                              • karl261K karl261
                                parachutesjP
                                parachutesjP
                                parachutesj
                                @karl261 said in BME280 How to use it outdoors:
                                Quite old thread, but wanted to provide an update:
                                I have a BME280 up and running since about 1 year now. It is in the weather station outside on the roof. It is vented very well but protected from direct exposure to sun, wind and rain. Readings are reliable. What I did is treating the whole board except the sensor chip with this:
                                https://de.aliexpress.com/item/2pcs-lot-Genuine-Kafuter-k-705-RTV-Silicone-Rubber-Electronic-Glue-Sealant-Transparent-Organosilicon-45g/32649754904.html?spm=a2g0s.9042311.0.0.27424c4d0W1ssb
                                Nca78N 1 Reply Last reply
                                • parachutesjP parachutesj
                                  Nca78N
                                  Nca78N
                                  @parachutesj thank you for the link I never noticed those before.
