  3. BME280 How to use it outdoors
36 Posts 9 Posters 35.8k Views 10 Watching
  • K Offline
    K Offline
    karl261
    I've been playing around with the bme280 for a while. I like this sensor, it seems to be very accurate and it is easy to install.
    Now, one of them is running outdoors. It is in a plastic box, I made a little hole of 4 mm diameter in the box and placed the sensor behind the hole. I thought like this it is well protected. The sensor points north and it sits in an open bird house 2 m above ground. No rain should be able to reach the box and sensor.
    However, recently I brought it into the house and noticed that the humidity is off by 15 %. Too high compared to all other bme280 and other sensors I have.
    Could it have been damaged sitting outside?
    I tried to recondition the sensor like written in the specs, but the humidity value is still too high.
    That is bad news, because I cannot put a new bme280 every 3 weeks... That gets too expensive.
    So, what to do? The Bosch specs clearly say it's ideal for outdoor weather monitoring. That is great, but how do I prevent this thing from showing wrong values?.
    Or maybe it is just bad luck?
    What do you suggest?!
    A 1 Reply Last reply
    • K karl261
      A Offline
      A Offline
      AWI
      @karl261 Is the photo upside down? It is probably bad luck but you you should take care that the box is well ventilated. Most commercial housings look like the one below. The ventilation makes sure that there is limited condensation. When a closed box (or one with only a small hole inside) cools down in high humidity there will likely be condensation which is not good for the sensor.
      So, my advice would be to dril some more holes and protect it agains rain. Also cover the holes with some fabric (i.e fiberglass) to protect it against insects.
      0_1474476662149_upload-55749161-dbba-4941-bbfe-c38322980283
      K 1 Reply Last reply
      • A AWI
        K Offline
        K Offline
        karl261
        @AWI No, it's standing on a table on the photo...
        Hm.... I did not find any moisture in the box. So you think I need plenty of more holes? Hm, the sensor was directly behind the hole. On the picture one cannot see the sensor.
        Rain normally cannot reach the box. But ok, I could think of something more special.
        The housing on your photo, where can you buy it?
        Another thing: if I protect the holes against insects, what would I use? Because I don't want to measure wet tissue or so. So it would be some synthetics. Or a fine mesh of something. But in this moment I have no idea...
        Thanks for the advice!
        • K Offline
          K Offline
          karl261
          R 1 Reply Last reply
          • K karl261
            R Offline
            R Offline
            r-nox
            @karl261
            You can use window screen from the hardware store.
            • R r-nox
              @karl261
              K Offline
              K Offline
              karl261
              @r-nox window screen? What is that? Do you have a link?
              Ah, now I know: these anti insect meshes, one puts in front of the window... They should be good...
              Now the box is full of 2 mm holes...
              • R Offline
                R Offline
                r-nox
                Your fine then.
                Window screen is a mesh material that doesn't absorb water. It is sometimes made from metal.
                • R Offline
                  R Offline
                  r-nox
                  Here's a link
                  http://www.affordablewindowscreens.com/products/custom-window-screens.html?page=shop.product_details&flypage=vmj_naru.tpl&product_id=40&category_id=1
                  • R r-nox
                    Your fine then.
                    K Offline
                    K Offline
                    karl261
                    @r-nox ok, thanks. I try to google it. Somehow I can't picture the material.
                    @AWI Maybe it has to do with the box. Hm. Because I had another node out there, same sensor, and it was just hanging in the bird house protected against rain. And it still works fine. Still, there was no sign of any moisture in the box...
                    • R r-nox
                      Here's a link
                      K Offline
                      K Offline
                      karl261
                      @r-nox ok, thanks. It is exactly what I was talking about. Insect protection! :smiley:
                      • K Offline
                        K Offline
                        karl261
                        Why are all my photos upside down? That's weird. They display right on the tablet, but on the PC in FireFox they are upside down...
                        • K Offline
                          K Offline
                          karl261
                          By the way: This is the sketch I use. It is made for a 1 MHz Atmega328p. If anyone has some code suggestions... :-)
                          I use a board that looks like this:
                          /* Sketch with Si7021 and battery monitoring.
                          by m26872, 20151109
                          modified for BME280 by karl261 using Sparkfun library
                          // MIN, LOW, HIGH, MAX
                          #define MY_PARENT_NODE_ID 99
                          #define MY_NODE_ID 6
                          //#define MY_DEBUG
                          #define MY_BAUD_RATE 9600
                          #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
                          #include <RunningAverage.h>
                          #include <SparkFunBME280.h>
                          //#define DEBUG   // local debug
                          #ifdef DEBUG
                          #define DEBUG_SERIAL(x) Serial.begin(x)
                          #define DEBUG_PRINT(x) Serial.print(x)
                          #else
                          // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                          #define CHILD_ID_HUM 0
                          #define CHILD_ID_TEMP 1
                          #define CHILD_ID_PRES 2
                          #define SLEEP_TIME 15000 // 15s for DEBUG
                          //#define SLEEP_TIME 300000   // 5 min
                          #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                          #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                          #define VMIN 1900
                          #define VMAX 3300
                          #define HUMI_TRANSMIT_THRESHOLD 3.0  // THRESHOLD tells how much the value should have changed since last time it was transmitted.
                          #define TEMP_TRANSMIT_THRESHOLD 0.5
                          #define PRES_TRANSMIT_THRESHOLD 1.0
                          #define AVERAGES 2
                          int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                          int measureCount = 0;
                          float lastTemperature = -100;
                          float lastPressure = -100;
                          int lastHumidity = -100;
                          RunningAverage raHum(AVERAGES);
                          //SI7021 humiditySensor;
                          BME280 mySensor;
                          // MyMessage to controler
                          MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP); // Initialize temperature message
                          MyMessage msgHum(CHILD_ID_HUM,V_HUM);
                          MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
                            sendSketchInfo("OUTSIDE P&T&H", "1.2");
                            present(CHILD_ID_PRES, S_BARO);
                            present(CHILD_ID_HUM, S_HUM);
                            DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
                            DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                            DEBUG_PRINTLN("Serial started");
                            DEBUG_PRINT("Voltage: ");
                            DEBUG_PRINT(readVcc());
                            DEBUG_PRINTLN(" mV");
                            delay(500);
                            DEBUG_PRINT("Internal temp: ");
                            DEBUG_PRINT(GetInternalTemp()); // Probably not calibrated. Just to print something.
                            DEBUG_PRINTLN(" *C");
                            mySensor.settings.commInterface = I2C_MODE;
                            mySensor.settings.I2CAddress = 0x77;
                            //runMode can be:
                            //  0, Sleep mode
                            //  1 or 2, Forced mode
                            //  3, Normal mode
                            mySensor.settings.runMode = 1;
                            mySensor.settings.filter = 0;
                            mySensor.settings.tempOverSample = 1;
                            mySensor.settings.pressOverSample = 1;
                            mySensor.settings.humidOverSample = 1;
                            delay(500); // Allow time for radio if power used as reset
                            if (!mySensor.begin())
                              Serial.println("BME init failed!");
                              while (1);
                            else Serial.println("BME init success!");
                            raHum.clear();
                            measureCount ++;
                            batteryReportCounter ++;
                            bool forceTransmit = false;
                            if (measureCount > FORCE_TRANSMIT_CYCLE) {
                              forceTransmit = true;
                            mySensor.begin();
                            // Read and print internal temp
                            float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                            DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                            // Check battery
                            if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                              long batteryVolt = readVcc();
                              DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                              uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                              DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                              batteryReportCounter = 0;
                            sleep(SLEEP_TIME);
                          //if(isTransportOK()){
                          //    sleep(SLEEP_TIME);  // transport is OK, node can sleep
                          //  else {
                          //    wait(5000); // transport is not operational, allow the transport layer to fix this
                          // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                          // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                          long readVcc() {
                            long result = (high<<8) | low;
                            result = 1178053L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                            //Node 6 = 1178053L
                          // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                          double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                            unsigned int wADC;
                            double t;
                            // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                            ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                            ADCSRA |= _BV(ADEN);  // enable the ADC
                            delay(20);            // wait for voltages to become stable.
                            ADCSRA |= _BV(ADSC);  // Start the ADC
                            while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                            wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                            t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                            return (t);   // The returned temperature in degrees Celcius.
                           * * Sends temperature and humidity from Si7021 sensor
                           * Parameters
                           * - force : Forces transmission of a value (even if it's the same as previous measurement)
                          void sendTempHumidityMeasurements(bool force) {
                            bool tx = force;
                            float temperature = mySensor.readTempC();
                            DEBUG_PRINT("T: ");DEBUG_PRINTLN(temperature);
                            float diffTemp = abs(lastTemperature - temperature);
                            DEBUG_PRINT(F("TempDiff :"));DEBUG_PRINTLN(diffTemp);
                            if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                              send(msgTemp.set(temperature,1));
                              lastTemperature = temperature;
                              measureCount = 0;
                              DEBUG_PRINTLN("T sent!");
                            int humidity = mySensor.readFloatHumidity();
                            DEBUG_PRINT("H: ");DEBUG_PRINTLN(humidity);
                            raHum.addValue(humidity);
                            humidity = raHum.getAverage();  // MA sample imply reasonable fast sample frequency
                            float diffHum = abs(lastHumidity - humidity);
                            DEBUG_PRINT(F("HumDiff  :"));DEBUG_PRINTLN(diffHum);
                            if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                              send(msgHum.set(humidity));
                              lastHumidity = humidity;
                              measureCount = 0;
                              DEBUG_PRINTLN("H sent!");
                            float pressure = mySensor.readFloatPressure()/100.0;
                            DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
                            float diffPress = abs(lastPressure - pressure);
                            DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
                            if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
                              send(msgPres.set(pressure,1));
                              lastPressure = pressure;
                              measureCount = 0;
                              DEBUG_PRINTLN("P sent!");
                          • K Offline
                            K Offline
                            karl261
                            Well, I guess then I will change the BME280 to a new one and see how it goes. Let's see how long it lasts. If it is made for weather monitoring, it should withstand normal weather conditions if not exposed to rain???
                            • K Offline
                              K Offline
                              karl261
                              wrote on last edited by karl261
                              Ok, I changed the BME280. Now it is better.
                              I like this sensor, I have right now 3 of them running next to each other:
                              T    20.8        21.2       21.1
                              H    60%         60%        60%
                              P    1015.3      1015.0     1014.9
                              Isn't that great? Now let's see how long the outdoor sensor lasts. I don't know what else to improve...
                              • K karl261
                                T    20.8        21.2       21.1
                                H    60%         60%        60%
                                R Offline
                                R Offline
                                r-nox
                                @karl261 hopefully a longer time.
                                • K Offline
                                  K Offline
                                  karl261
                                  It does not look that it was much longer time. But instead like the sensor before, the current one is now showing values between 0-22% humidity. T seems to be fine. That is SO disappointing. It seems that these things are not suitable for outdoor use. Lasted only a month...
                                  Buuuuh.
                                  • R Offline
                                    R Offline
                                    r-nox
                                    Seems short lived...
                                    • N Offline
                                      N Offline
                                      :( Sounds bad :(
                                      Next step for you is to try with a SHT21 with the protective film it might get a better chance than the BME280...
                                      • K Offline
                                        K Offline
                                        karl261
                                        @r-nox Somehow, doesn't it? A bit too short for my taste. It should not see any rain, I wonder what is killing it. Or, how I can protect it even better.
                                        @Nca78 I had a SI7021 with protective foil before, but it was not very accurate. Actually it was quite far off, that's why I started to look for something more accurate.
                                        When I look around online there seems to be some connection/confusion with the SI7021 and SHT21. But I did not really understand it. Does anybody know more about it?
                                        EDIT: Hm, seems to be two different sensors, but the board is always the same. So I would need to check to really get a SHT21 and with a protective cover...
                                        EDIT2: I do not seem to find any SHT21 with protective cover...
                                        • R Offline
                                          R Offline
                                          r-nox
                                          Are you over working it? Is that even possible?
