  3. RF24 PA LOW or HIGH
RF24 PA LOW or HIGH
8 Posts 4 Posters 7.8k Views 6 Watching
  • A
    A
    Affe
    Hi Guys
    ¨Can someone explain for me when should i use Low and HIGH for RF 24
    If a use high
    should i feed with extern 3 v ?
    Is there a difference with an external antenna LNA?:flushed:
    • A
      A
      Affe
      Hi
      Can someone please explanin for me ?
      how should i do ?
      If I 'm building a reapeter
      #define MY_RF24_PA_LEVEL RF24_PA_LOW *or HIGH *
      #define MY_REPEATER_NODE
      Should I change to wait insted of sleep ? or only include **#define MY_REPEATER_NODE **
      I use a PA+LNA ,
      Is it better to use standard NRF24L01+?
      http://www.elecfreaks.com/wiki/index.php?title=2.4G_Wireless_nRF24L01p_with_PA_and_LNA
      • BartEB
        BartEB
        BartE
        @Affe when you use MY_RF24_PA_LEVEL HIGH you needs external radio power.
        A standard Arduino power regulator is not powerfull enough for high RF24 power.
        Disregarding which type of antenna one uses.
        The LNA antenna is more sensitive and thus will give a better reception
        A 1 Reply Last reply
        • BartEB BartE
          A
          A
          Affe
          @BartE Thanks
          So i need too feed extern with 3 volt or select standard NRF24L01+
          Can you also explain reapeter funtion ?
          If i should change to wait insted of sleep
          BartEB Boots33B 2 Replies Last reply
          • A Affe
            @BartE Thanks
            BartEB
            BartEB
            BartE
            wrote on last edited by BartE
            @Affe No you need too feed with external 3.3 volt OR select LOW power
            the repeater mode is used for resending message from one node to the gateway, in case a node is not in reach of the GW.
            https://en.wikipedia.org/wiki/Repeater
            • A Affe
              @BartE Thanks
              Boots33B
              Boots33B
              Boots33
              @Affe you should use wait if it is a repeater node
              • A
                A
                Affe
                Thanks @Boots33 and @BartE
                summation :+1: Use extern 3,3V feed when you use
                #define **MY_RF24_PA_LEVEL RF24_PA_HIGH **
                and
                When I build Repeater
                ex
                unsigned long **WAIT_TIME **= 30000; // Sleep time between reads (in milliseconds)
                int numSensors=0;
                bool receivedConfig = false;
                bool metric = true;
                MyMessage msg(0,V_TEMP);
                and
                wait(conversionTime);
                sleep(WAIT_TIME);
                • A Affe
                  and
                  ex
                  int numSensors=0;
                  bool metric = true;
                  and
                  sleep(WAIT_TIME);
                  @Affe - And use a good 3.3v regulator, that can feed alof of mA.
                  The standard LE33A we suggest for the normal radio at Mysensors.org might be a bit weak.
                  ld1117v33 for example.
