  3. [Solved] No heartbeat
4 Posts 2 Posters 3.0k Views 1 Watching
  • jsiddallJ
    jsiddallJ
    jsiddall
    wrote on last edited by tekka
    I am trying to implement sendHeartbeat() periodically so my gateway knows that a sensor is alive even when it doesn't have any data to send.
    The issue is that while I am pretty sure sendHeartbeat() is being called nothing is actually being sent.
    This is a node running MYS 2.0.
    Here's the sketch excerpt from loop():
    if ((millis() - last_heartbeat_time) > HEARTBEAT_TIME) {
      // If it exceeds the heartbeat time then send a heartbeat
      void sendHeartbeat();
      last_heartbeat_time = millis();
      #ifdef MY_DEBUG
        Serial.println("Sent heartbeat");
    wait(UPDATE_TIME);
    And here's the debug log:
    Sent heartbeat
    TSP:SANCHK:OK
    TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=ok:0.00
    TSP:MSG:SEND 3-3-0-0 s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:4.37
    Sent heartbeat
    I know the if clause is executing because I get the "Sent heartbeat" debug message.
    The two other messages are from child sensors 1 and 2 and those seem to be working fine.
    I would expect that if a message was being sent for the heartbeat I should see some kind of debug log showing the message was sent. However, I neither see a debug message nor receive a heartbeat message at the gateway.
    Can anyone see any reason the above code shouldn't send a heartbeat?
    Thanks,
    Jeff
    tekkaT 1 Reply Last reply
    • jsiddallJ jsiddall
        #ifdef MY_DEBUG
      wait(UPDATE_TIME);
      Sent heartbeat
      TSP:SANCHK:OK
      Sent heartbeat
      Thanks,
      Jeff
      tekkaT
      tekkaT
      tekka
      @jsiddall Yes, your code does not work, you should remove void before sendHeartbeat();
      • jsiddallJ
        jsiddallJ
        jsiddall
        @tekka Thanks, easy fix. I'm obviously not a C guy! I guess you only use "void" when you are defining a function.
          tekkaT
          tekkaT
          tekka
          @jsiddall yup, defining a function without return value :)
