  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
  • jmkhaelJ
    jmkhaelJ
    jmkhael
    @tekka : fair enough, i should read better next time :)
    i'll try the way you suggest. thank you.
    • kleinerDracheK
      kleinerDracheK
      kleinerDrache
      hi tekka
      I had to change the channel of the NRF from 76 to 0 here because of massive disturbances . Unfortunately, no OTA works now. Is it possible to create a modified bootloader that works with 0 instead of 76? Sorry for the bad english it is translated with google.
      • LorenzoL
        LorenzoL
        Lorenzo
        Hi, thank for the great work.
        I also use a different Channel, in fact I have 3 area with 3 differents Channels.
        Do you have a plan about source code release date ?
        • techRHT
          techRHT
          techRH
          wrote on last edited by techRH
          #44
          Is there a way to debug the bootloader should it print debug information and how to see this?
          • Suresh MaliS
            Suresh MaliS
            Suresh Mali
            This post is deleted!
            • TetnobicT
              TetnobicT
              Tetnobic
              wrote on last edited by Tetnobic
              #46
              I just start to test this bootloader...
              I use an ATmega328p on breadboard with no external clock, with nRF24 and somes sensors.
              Firmware Upload (by usbasp) and Run is ok, Send/Receive Data is ok too , but when I ask a reboot (with MYSController 1.0.0beta), my node enter in sort of strange start loop...
              My Fuse settings :
              bootloader.unlock_bits=0x3F
              bootloader.lock_bits=0x0F
              bootloader.low_fuses=0x62
              bootloader.high_fuses=0xDA
              bootloader.extended_fuses=0x07
              Node debug Trace :
              TSP:MSG:READ 0-0-4 s=2,c=1,t=0,pt=7,l=5,sg=0:28.18
              TSP:MSG:READ 0-0-4 s=1,c=1,t=1,pt=7,l=5,sg=0:38.28
              TSP:MSG:READ 0-0-4 s=0,c=3,t=13,pt=0,l=1,sg=0:0
              StartiStartiStartiStartiþStartiþStartiþStartiStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþ
              The "Startiþ" text is the first char of the first text printed by bootloader at start : "Starting sensor....."
              Have you an idea ?
              • tekkaT
                tekkaT
                tekka
                Please provide additional information such as library version, full debug log of your GW and node. Which bootloader/version are you using?
                TetnobicT 1 Reply Last reply
                • tekkaT tekka
                  TetnobicT
                  TetnobicT
                  Tetnobic
                  @tekka Thanks for you response
                  For gateway :
                  Raspberrry PI Gateway in Ethernet mode
                  Protocol version : 2.0.1-beta
                  For Node :
                  I use bootloader : MYSBL13pre_atmega328_1Mhz.hex
                  Inital Sketch do nothing :) :
                  #define MY_BAUD_RATE 9600
                  #define MY_OTA_FIRMWARE_FEATURE
                  #define MY_NODE_ID 1
                  void presentation(){
                    sendSketchInfo("MyFirstBoard", "0.0.2", true);
                    wait(5000);
                  Test Case: Start Gateway, Connect MYSController 1.0.0beta, then start my sensor, after init complete, click reboot in MYSController
                  Gateway Log :
                  mysgw: Starting gateway...
                  mysgw: Protocol version - 2.0.1-beta
                  mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSM:INIT:TSP OK
                  mysgw: TSM:INIT:GW MODE
                  mysgw: TSM:READY
                  mysgw: Listening for connections on 0.0.0.0:5003
                  mysgw: MCO:REG:NOT NEEDED
                  mysgw: MCO:BGN:STP
                  mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                  mysgw: New connection from 10.31.10.59
                  mysgw: Client 0 connected
                  mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:FPAR REQ,ID=1
                  mysgw: TSF:PNG:SEND,TO=0
                  mysgw: TSF:CKU:OK
                  mysgw: TSF:MSG:GWL OK
                  mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  mysgw: TSF:MSG:PINGED,ID=1,HP=1
                  mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  mysgw: Client 0: 1;255;3;0;6;M
                  mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                  mysgw: TSF:MSG:ACK REQ
                  mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:MyFirstBoard
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                  mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=OK:0.0.2
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysgw: Client 0: 1;0;3;0;13;0
                  mysgw: TSF:MSG:SEND,0-0-1-1,s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=OK:0
                  NodeLog :
                  Starting sensor (RNONA-, 2.0.0)
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=1)
                  TSM:FPAR
                  TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  TSP:MSG:PAR OK (ID=0, dist=1)
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=1)
                  TSM:UPL
                  TSP:PING:SEND (dest=0)
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                  TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  TSP:MSG:PONG RECV (hops=1)
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  TSP:MSG:SEND 1-1-0-0 s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=ok:FFFFFFFFFFFFFFFF0300
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                  TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                  TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:MyFirstBoard
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=ok:0.0.2
                  Request registration...
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                  TSP:MSG:READ 0-0-1 s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                  TSP:MSG:READ 0-0-1 s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                  TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  Node registration=1
                  Init complete, id=1, parent=0, distance=1, registration=1
                  TSP:MSG:READ 0-0-1 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                  StartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiþStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStarti
                  Need others infos ?
                  Thanks for your time
                  tekkaT 1 Reply Last reply
                  • TetnobicT Tetnobic
                    For gateway :
                    For Node :
                      wait(5000);
                    Gateway Log :
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSM:READY
                    mysgw: MCO:BGN:STP
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:CKU:OK
                    NodeLog :
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=1)
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    Node registration=1
                    Need others infos ?
                    tekkaT
                    tekkaT
                    tekka
                    @Tetnobic
                    Your node is running MySensors 2.0.0 (your GW is at 2.0.1, please consider updating), also, there is no sign of MYSBootloader in your GW log - please double-check if you followed the correct procedure.
                    One more thing: the startup message indicates that you enabled OTA firmware features (RNONA-) - this is not required with MYSBootloader.
                    Please have a look at @scalz's OTA guide for additional information.
                    • tekkaT tekka
                      @Tetnobic
                      TetnobicT
                      TetnobicT
                      Tetnobic
                      @tekka Thanks for your response
                      What are the sign of MYSBootloader in GW log ?
                      Can I also see any sign of MYSBootloader in Node Log ?
                      I remove OTA firmware features, I now have :
                      but same problem, after receive reboot message I have a "StartiStartiStartiStartiS...." loop :(:(
                        tekkaT
                        tekkaT
                        tekka
                        @Tetnobic No, you won't see anything in the node log - but in the GW log you should see somehting like:
                        1;255;4;0;0;64000200C803948D0105
                        • tekkaT tekka
                          TetnobicT
                          TetnobicT
                          Tetnobic
                          @tekka Hi, I found my mistake ! You were absolutely right when you said there is no sign of MYSBootloader in my GW log...
                          But now I know why :) :
                          I use an USBasp Programmer with Arduino IDE for upload my bootloader and my sketch..., and I mistakenly thought that when I upload bootloader then sketch, it keep bootloader.....but NOT, it overwrite bootloader :(
                          I fix it by uploading the xxx.with_bootloader.hex file generated by Arduino IDE when compile.
                          Sorry for the inconvenience and thank you for your help
                          AndurilA 1 Reply Last reply
                            AndurilA
                            AndurilA
                            Anduril
                            @Tetnobic can this be done within the IDE? I have some nodes where I have to upload with ISP and thought to still have the bootloader, but this explains why OTA didn't work afterwards...
                            • AndurilA Anduril
                              TetnobicT
                              TetnobicT
                              Tetnobic
                              @Anduril I think you can do this without Arduino IDE...
                              but how compile you code for generate sketch+bootloader ( the xxx.with_bootloader.hex file) in command line I don't know....
                              For upload this file on my ATMega, I use avrdude, the same command line that ardunio IDE use, but change the .hex file...
                              • TigroenotT
                                TigroenotT
                                Tigroenot
                                Tried this bootloader.
                                Have two nodes 8MHz internal, two nodes 1MHz. All run beautifully, the OTA firmware update around a minute with binaryButton sketch. But the node startup is around 7-8 seconds. And no problems uploading the sketch via serial.
                                I use an UNO as an ASP to burn the bootloader and a simple USB_TTL FTDI converter to upload sketches.
                                • jerseyguy1996J
                                  jerseyguy1996J
                                  jerseyguy1996
                                  This may be a stupid question, but I'm using the mysgateway on a Raspberry Pi as my controller which is described here:
                                  Building a Raspberry Pi Gateway
                                  The Raspberry pi runs headless and I do everything through ssh. Is there any way to use MYSBootloader using the mysgateway and initiating the OTA update using the command line?
                                  RedferneR 1 Reply Last reply
                                  • RedferneR
                                    RedferneR
                                    Redferne
                                    Shall we all join hands and give a warm applause to @tekka for his work and pray that he'll find the time to give us a lovely christmas present. The MYSBootloader 1.3+ pushed to github 😃
                                    pkuP 1 Reply Last reply
                                    • J
                                      J
                                      jacikaas
                                      • RedferneR Redferne
                                        pkuP
                                        pkuP
                                        pku
                                        @tekka pleeeease.... :pray:
                                        • Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          It's been asked that the source is uploaded multiple times over the last year +, I guess it will not happen anytime soon... :disappointed:
