  3. Gateway do not receive info from sensor node
1 Posts 1 Posters 638 Views 1 Watching
  • Christian SimonsenC
    Christian SimonsenC
    Christian Simonsen
    wrote on last edited by Christian Simonsen
    Hi guys,
    I feel Im getting closer.
    I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. I've managed to add the Raspberry Pi as a controller in MyController.
    Next step is to be able to send something from a Arduino based sensor node. I have an Arduino Uno, with an NRF24L01 module connected.
    I uploaded the
    "hard_signing_whitelisting_full_debug_nrf24_rsa" sketch and the result was this in the Serial Monitor.
    Starting sensor (RNNNAA, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    Seem to fail, but not sure why... any suggestions?
