  3. Update to Version 2 / !TSP:MSG:SEND Problem [Solved]
5 Posts 3 Posters 1.9k Views 4 Watching
  • TakeroT
    TakeroT
    Takero
    wrote on last edited by Takero
    Hello There,
    i updated my Gateway, my Repeater and my Node to MySensors Version 2. At startup everythink is OK. But after some times i get no updates from my nodes.
    In the Log i see the following Message:
    Log :!TSP:MSG:SEND 0-0-20-20 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
    The Node 20 is an sleeping node, so it is (in my opinion) normal the gateway cant connect the Node.
    It is needed to connect the IRQ to the NRF24?
    What is the TSP Message?
    Thanks!
    • alexsh1A
      alexsh1A
      alexsh1
      st=fail is a RF problem. Did you try to change nrf24l01+?
      • TakeroT
        TakeroT
        Takero
        The Sensors are works perfectly together before i update the lib . . .
        My Gateway use an NRF24I01 +PA +LNA and my Sensor an normal NRFI01+ SMD
          @Takero
          Try lowering the transmission power level. You are probably not feeding the module enough (or need to shield it better) .
          • TakeroT
            TakeroT
            Takero
            Thanks!
            I dont know why, it works before update.
            I just increase the capacitor to 500uF and it works like a charm. :satisfied:
