  3. How to create a fake local sensor on Ethernet Gateway
5 Posts 3 Posters 3.0k Views 4 Watching
  • darkdudeD Offline
    darkdudeD Offline
    darkdude
    I need some help in understanding the basics of MySensors library.
    To make the long story short I'm a beginner in both programming and Arduino. In most cases I'm able to understand how things work by looking at a working example and then modyfing it to do what I want it to. However after a lot of searching and reading I still can't get what goes where in MySensors.
    I want to make a thermostate based on Domoticz + Ethernet Gateway with locally attached sensors and one relay. For now I installed an example of 2.0 Ethernet Gateway that connects to Domoticz but obviously has nothing to present.
    Is it possible to present a simple static value as a fake reading of a temp sensor so I can see how the message is formatted, what goes into presentation() etc. ?
    I know it's all written in API section but I just don't get it.
    Thanks in advance
    • darkdudeD darkdude
      Thanks in advance
      @darkdude hi and welcome to the MySensors community.
      Funny thing, @martim asked a similar question yesterday, which got me thinking.
      Here is a simple example that will report the running time in seconds, once per second. So basically it will be a counter. Feedback is welcome.
         The MySensors Arduino library handles the wireless radio link and protocol
         between your home built sensors/actuators and HA controller of choice.
         The sensors forms a self healing radio network with optional repeaters. Each
         repeater and gateway builds a routing tables in EEPROM which keeps track of the
         network topology allowing messages to be routed to nodes.
         Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
         Copyright (C) 2013-2015 Sensnology AB
         Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
         Documentation: http://www.mysensors.org
         Support Forum: http://forum.mysensors.org
         This program is free software; you can redistribute it and/or
         modify it under the terms of the GNU General Public License
         version 2 as published by the Free Software Foundation.
         REVISION HISTORY
         Version 1.0 - Henrik EKblad
         DESCRIPTION
         This sketch provides an example how to implement a distance sensor using HC-SR04
         http://www.mysensors.org/build/distance
      // Enable debug prints
      #define CHILD_ID 1
      unsigned long SLEEP_TIME = 1000; // Sleep time between sends (in milliseconds)
      MyMessage msg(CHILD_ID, V_TEXT);
      void presentation() {
        sendSketchInfo("Dummy sensor", "1.0");
        present(CHILD_ID, S_INFO);
        unsigned int seconds = millis() / 1000;
        Serial.print("Seconds since start: ");
        Serial.println(seconds);
        send(msg.set(seconds));
        sleep(SLEEP_TIME);
      • darkdudeD Offline
        darkdudeD Offline
        darkdude
        Thanks for your answer!
        I combined your code with my gateway setup:
         * Version 1.0 - Henrik EKblad
         * Contribution by Tomas Hozza <thozza@gmail.com>
         * LED purposes:
        //#define MY_RADIO_NRF24
        #define MY_GATEWAY_W5100
        //#define MY_W5100_SPI_EN 4
        // radio on the same spi bus.
          #define MY_SOFTSPI
        #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
        #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
        // Enable to UDP
        //#define MY_USE_UDP
        #define MY_IP_ADDRESS 192,168,1,122   // If this is disabled, DHCP is used to retrieve address
        #define MY_PORT 5003
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 105
        // Flash leds on rx/tx/err
        #define MY_LEDS_BLINKING_FEATURE
        // Set blinking period
        // Enable inclusion mode
        //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
        //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
        //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
        #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
        #include <Ethernet.h>
        #define CHILD_ID 1
          sleep(SLEEP_TIME);
        I had to enable client mode (it just restarted after every loop without it). However it still does nor register as a sensor in Domoticz.
        In Domoticz log there is:
        2016-10-18 13:10:17.041 MySensors: connected to: 192.168.1.122:5003
        In Devices i have
        MySensors Gateway with LAN interface
        Version: ?
        Serial monitor gives:
        0;255;3;0;9;Starting gateway (1
        Seconds since start: 1
        0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0)
        IP: 192.168.1.122
        I added
        seconds ++
        to your code and it now counts correctly but still does not register as a sensor.
        Regarding a need for a "Dummy" example.
        In my case here the problem is in using libraries or understanding how they work. For now it's like:
        CHILD_ID - OK, it's defined allright
        V_TEXT - it's not edfined in this sketch and I don't know where it comes from
        It's the same with
        After finishing some basic projects I would try to define S_INFO and send sensor data there...
        However after seeing a dummy sensor actually register and "work" in Domoticz I should be able to play with it for a bit, change its value and then connect a real sensor. And that should give me enough knowledge to try other sensor types.
        I asked especially for a dummy temp sensor because temp sensors are easy to use, they are a basic example in many Arduino courses.
        Regards
           * LED purposes:
            #define MY_SOFTSPI
          // Enable to UDP
          #define CHILD_ID 1
            sleep(SLEEP_TIME);
          In Devices i have
          Version: ?
          IP: 192.168.1.122
          I added
          seconds ++
          It's the same with
          Regards
          @darkdude V_TEXT and S_INFO are described in the API documentation, https://www.mysensors.org/download/serial_api_20#presentation
          Switch from
          to
          MyMessage msg(CHILD_ID, V_TEMP);
          present(CHILD_ID, S_TEMP);
          to simulate a temperature sensor instead. This is shown in the temperature example.
          I don't know why the sensor doesn't show up in Domoticz. I have no experience with ethernet gateway and I have never used V_TEXT/S_INFO, it could be that Domoticz handles them in a special way.
          Having to add seconds++ is seriously strange. I don't have a clue why the millis function doesn't work on your device, and adding seconds++ should not work since the variable is re-initilaized each time the loop is run.
          • Silviu NegoitaS Offline
            Silviu Negoita
            wrote on last edited by Silviu Negoita
            I tried to create an ethernet gateway + one dummy sensor , like in above exemple. My controller is domoticz for windows.
            I tried this code :
             * LED purposes:
              #define MY_SOFTSPI
            // Enable to UDP
            #define MY_IP_ADDRESS 192,168,0,125  // If this is disabled, DHCP is used to retrieve address
            #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 100
            #define CHILD_ID 1
            unsigned int seconds = 0;
              seconds = seconds + 1;
              send(msg.set(seconds, 1));
              sleep(SLEEP_TIME);
            Controller seems to connect to gateway but no devices were found:
            Also, serial monitor gives:
            Any ideas why my dummy sensor is not recognized ?
            UPDATE: I managed to make above code run by removing
            Regards
            12.2k
