  3. DualOptiboot Bootloader (Solved)
17 Posts 3 Posters 4.4k Views 1 Watching
  • TakeroT
    TakeroT
    Takero
    wrote on last edited by Takero
    Hello Again,
    i am going crazy . . .where can i find the DualOptiboot Bootloader. I found the normal Optiboot, but i want to use OTA via seperate SPI Flash.
    I found this: https://github.com/mysensors/DualOptiboot
    But is doesnt work.
    Thanks!
    • scalzS
      scalzS
      https://www.mysensors.org/about/ota
      • TakeroT
        TakeroT
        Takero
        Jupp, i know this side, but i am looking dir the Hex File. Anyway i found it already.
        But my ota does Not work. Transfer Starts only if i Push Reset and after the Transfer nothing happens. I dont know if i Set up the Flash corect in my Sketch. Use pin 8 for cs. Bootloader is sensbrender Micro.
        • tbowmoT
          tbowmoT
          tbowmo
          Have you run basic tests against your flash, and checked that you are able to communicate with it? F. Ex with a test sketch, that tries to read the id of the flash.
          Next step would be to setup the mysensors sketch, with Ota enabled. I haven't used it myself yet, as I usually just go around to all nodes and reprogram them manually (even though they are sensebender micros with onboard flash)
          • TakeroT
            TakeroT
            Takero
            Hey, thanks for Respons...
            how can i test it? I try this sketch but it is hanging around init. . .
              |        Diagnostics.ino        |
              |                                                               SPIFlash library        |
              |        v 2.4.0        |
              |        Marzogh        |
              |        11.09.2016        |
              |                                  For a full diagnostics rundown - with error codes and details of the errors                                  |
              |                                uncomment #define RUNDIAGNOSTIC in SPIFlash.cpp in the library before compiling                                |
              |                                             and loading this application onto your Arduino.                                                   |
            #include<SPIFlash.h>
            #include<SPI.h>
            #define WINBOND     0xEF
            #define MICROCHIP   0xBF
            char printBuffer[128];
            SPIFlash flash;
              Serial.begin(115200);
              Serial.print(F("Initialising Flash memory"));
              for (int i = 0; i < 10; ++i)
                Serial.print(F("."));
              Serial.println();
              flash.begin();
              Serial.println();
              Serial.println();
              randomSeed(analogRead(A0));
              getID();
              diagnose();
            //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~Serial Print Functions~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~//
            void clearprintBuffer()
              for (uint8_t i = 0; i < 128; i++) {
                printBuffer[i] = 0;
            void printLine() {
              Serial.println(F("---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------"));
            void printPass() {
              Serial.print(F("Pass"));
            void printFail() {
              Serial.print(F("Fail"));
            void printTab(uint8_t a, uint8_t b) {
              for (uint8_t i = 0; i < a; i++) {
                Serial.print(F("\t"));
              if (b > 0) {
                Serial.print("||");
                for (uint8_t i = 0; i < b; i++) {
            void printTime(uint32_t _wTime, uint32_t _rTime) {
              printTab(2, 1);
              printTimer(_wTime);
              printTab(2, 1);
              printTimer(_rTime);
            void printTimer(uint32_t _us) {
              if (_us > 1000000) {
                float _s = _us / (float)1000000;
                Serial.print(_s, 4);
                Serial.print(" s");
              else if (_us > 10000) {
                float _ms = _us / (float)1000;
                Serial.print(_ms, 4);
                Serial.print(" ms");
              else {
                Serial.print(_us);
                Serial.print(F(" us"));
            I use AT25DF512C-SSHN-B
            • tbowmoT
              tbowmoT
              tbowmo
              Hangs around init, of which module?
              What does the serial output tell you in that sketch?
              There is one example here
              https://github.com/mysensors/MySensorsArduinoExamples/blob/master/libraries/SPIFlash/examples/SPIFlash_ReadWrite/SPIFlash_ReadWrite.ino
              • TakeroT
                TakeroT
                Takero
                I found that Sketch now . . SPIFlash_ReadWrite.ino
                Start...Init FAIL!
                • scalzS
                  scalzS
                  wrote on last edited by scalz
                  Search -> https://forum.mysensors.org/topic/3503/sensebender-dualoptiboot-ota-howto-in-mysensors/11
                  TakeroT 1 Reply Last reply
                  • scalzS scalz
                    TakeroT
                    TakeroT
                    Takero
                    @scalz
                    That works, i think ;-)
                    Init OK!
                    Start...Init OK!
                    Flash content:
                    0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.
                    Erasing Flash chip ... DONE
                    DeviceID: 0
                    But OTA does not work . . .
                    My Test-Sketch:
                     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                     * http://www.mysensors.org/build/temp
                    #define MY_BAUD_RATE 115200
                    #define MY_NODE_ID 50
                    #define MY_RF24_CHANNEL 105
                    #define MY_OTA_FIRMWARE_FEATURE
                    #define MY_OTA_FLASH_SS   8     // EEprom CS pin
                    //#define OTA_WAIT_PERIOD 300
                    //#define ATSHA204_PIN      12    // A3 Arduino Digital I/O pin number for ATSHA204A sot23 ic (for authentication)
                    //#define MY_SIGNING_SOFT
                    //#define MY_SIGNING_ATSHA204
                    //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
                    //#define MY_SIGNING_REQUEST_SIGNATURES
                    //#ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN
                    //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
                    //#endif
                    //#ifndef MY_SIGNING_ATSHA204_PIN
                    //#define MY_SIGNING_ATSHA204_PIN 17
                    //#endif
                    #include <OneWire.h>
                    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
                    int numSensors=0;
                    bool receivedConfig = false;
                    bool metric = true;
                    MyMessage msg(0,V_TEMP);
                    void before()
                      sensors.begin();
                    void presentation() {
                      sendSketchInfo("Temperature Sensor", "1.1");
                         present(i, S_TEMP);
                      //sleep(conversionTime);
                        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                        #if COMPARE_TEMP == 1
                        #else
                          send(msg.setSensor(i).set(temperature,1));
                    MYSController log Node 50:
                    21.10.2016 12:25:37	NODE	New node discovered, node id=50
                    21.10.2016 12:25:37	CHILD	New child discovered, node id=50, child id=internal
                    21.10.2016 12:25:37	INFO	BL version=768
                    21.10.2016 12:25:37	INFO	No FW assigned
                    21.10.2016 12:25:37	RX	50;255;4;0;0;0A000200B004B6D30300
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:READ 50-50-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-50-50 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:READ 50-50-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                    21.10.2016 12:25:37	DEBUG	Update child id=255, type=ARDUINO_NODE
                    21.10.2016 12:25:37	RX	50;255;0;0;17;2.0.0
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:READ 50-50-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    21.10.2016 12:25:37	TX	50;255;3;0;6;M
                    21.10.2016 12:25:37	RX	50;255;3;0;6;0
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-50-50 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=ok:M
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:READ 50-50-0 s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Sensor
                    21.10.2016 12:25:37	RX	50;255;3;0;11;Temperature Sensor
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:READ 50-50-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                    21.10.2016 12:25:37	RX	50;255;3;0;12;1.1
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:READ 50-50-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
                    21.10.2016 12:25:37	CHILD	New child discovered, node id=50, child id=0
                    21.10.2016 12:25:37	DEBUG	Update child id=0, type=TEMP
                    21.10.2016 12:25:37	RX	50;0;0;0;6;
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:READ 50-50-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-50-50 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                    21.10.2016 12:25:37	RX	0;255;3;0;9;TSP:MSG:READ 50-50-0 s=0,c=1,t=0,pt=7,l=5,sg=0:25.3
                    If i assigning new FW, following in log, but nothing happens . . ..
                    21.10.2016 12:28:43	INFO	FW "Test02" assigned to node 50
                    21.10.2016 12:28:43	INFO	Send FW info to node 50: type=A, version=2, blocks=0x04B0, CRC=0xD3B6
                    21.10.2016 12:28:43	TX	50;0;4;0;1;0A000200B004B6D3
                    21.10.2016 12:28:43	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-50-50 s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=ok:0A000200B004B6D3
                    • TakeroT
                      TakeroT
                      Takero
                      OK . . . The Upload is successful right now, dont know why but it works.
                      Now i have the Problem after transfer Data it stops at "Ongoing 100%" and nothing happens anymore. The Node needs Powercycle, Resetbutton has no effect.... (scalz Rollershutter HW)
                      • TakeroT
                        TakeroT
                        Takero
                        Works right now. . . my faulty was to flash the first Programm with the wrong Bootloader. :rage:
                        • scalzS
                          scalzS
                          why i told you to read the howto, because you would have burnt the right BL (sensebender in boards) ;)
                          great you got it working :)
                          • scalzS scalz
                            TakeroT
                            TakeroT
                            Takero
                            @scalz yahh i know. I dit but i dont found the right bootloader and arduinos ide folder structure is horrorbil.
                            Btw.... On the nrf24 Layout you have to remove the pullup R14
                            • scalzS
                              scalzS
                              @Takero
                              why removing R14? then is avrspi still working?? it's a pull-up for CSN, and when you have multiple ic on SPI bus, it's good practice to have it, and avoid some dumb issue..it didn't work with R14?? perhaps..
                              • TakeroT
                                TakeroT
                                Takero
                                I know but i had Trouble with the nrf is it pluged. I will try it again and give you a Feedback.
                                • scalzS scalz
                                  @Takero
                                  TakeroT
                                  TakeroT
                                  Takero
                                  @scalz
                                  OK, tested with R14 again and it works :+1:
                                  Thanks again for the PCB and help!!
                                  • TakeroT
                                    TakeroT
                                    Takero
                                    I does not work again . . . i dont know why :-(
                                    After Upload new Firmware, the device wont reboot and hanging in an bootloop.
                                    Log from MYSController:
                                    [2016-10-29 14:30:37.589 Info] RX	0;255;3;0;9;TSP:MSG:SEND 0-0-50-50 s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=ok:6400020001000C941F040C941F040C9409140C941F04
                                     [2016-10-29 14:30:37.602 Info] RX	0;255;3;0;9;TSP:MSG:READ 50-50-0 s=255,c=4,t=2,pt=6,l=6,sg=0:640002000000
                                     [2016-10-29 14:30:37.612 Info] TX	50;255;4;0;3;6400020000000C94F7030C94A3190C947C190C941F04
                                     [2016-10-29 14:30:37.622 Info] RX	50;255;4;0;2;640002000000
                                     [2016-10-29 14:30:37.641 Info] RX	0;255;3;0;9;TSP:MSG:SEND 0-0-50-50 s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=ok:6400020000000C94F7030C94A3190C947C190C941F04
                                     [2016-10-29 14:30:40.031 Info] RX	0;255;3;0;9;TSP:MSG:READ 50-50-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                     [2016-10-29 14:30:40.046 Info] RX	0;255;3;0;9;TSP:MSG:BC
                                     [2016-10-29 14:30:40.060 Info] RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=50)
                                     [2016-10-29 14:30:40.069 Info] RX	0;255;3;0;9;TSP:CHKUPL:OK
                                     [2016-10-29 14:30:40.077 Info] RX	0;255;3;0;9;TSP:MSG:GWL OK
                                     [2016-10-29 14:30:40.576 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-50-50 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                                     [2016-10-29 14:30:40.594 Info] RX	0;255;3;0;9;TSP:MSG:READ 50-50-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                     [2016-10-29 14:30:40.606 Info] RX	0;255;3;0;9;TSP:MSG:BC
                                     [2016-10-29 14:30:40.615 Info] RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=50)
                                     [2016-10-29 14:30:40.624 Info] RX	0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                                     [2016-10-29 14:30:40.633 Info] RX	0;255;3;0;9;TSP:MSG:GWL OK
                                     [2016-10-29 14:30:40.643 Info] RX	0;255;3;0;9;TSP:MSG:SEND 0-0-50-50 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                     [2016-10-29 14:30:40.653 Info] RX	0;255;3;0;9;TSP:MSG:READ 50-50-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                     [2016-10-29 14:30:40.662 Info] RX	0;255;3;0;9;TSP:MSG:BC
                                     [2016-10-29 14:30:40.673 Info] RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=50)
                                     [2016-10-29 14:30:40.682 Info] RX	0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                                     [2016-10-29 14:30:40.692 Info] RX	0;255;3;0;9;TSP:MSG:GWL OK
                                     [2016-10-29 14:30:40.774 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-50-50 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                                     [2016-10-29 14:30:40.784 Info] RX	0;255;3;0;9;TSP:MSG:READ 50-50-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                     [2016-10-29 14:30:40.794 Info] RX	0;255;3;0;9;TSP:MSG:BC
                                     [2016-10-29 14:30:40.806 Info] RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=50)
                                     [2016-10-29 14:30:40.815 Info] RX	0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                                     [2016-10-29 14:30:40.825 Info] RX	0;255;3;0;9;TSP:MSG:GWL OK
                                     [2016-10-29 14:30:41.089 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-50-50 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                                     [2016-10-29 14:30:41.110 Info] RX	0;255;3;0;9;TSP:MSG:READ 50-50-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                     [2016-10-29 14:30:41.120 Info] RX	0;255;3;0;9;TSP:MSG:BC
                                     [2016-10-29 14:30:41.129 Info] RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=50)
                                     [2016-10-29 14:30:41.139 Info] RX	0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                                     [2016-10-29 14:30:41.148 Info] RX	0;255;3;0;9;TSP:MSG:GWL OK
                                    Any Tips?
