  3. Analog power meter reading TCRT 5000
7 Posts 3 Posters 3.7k Views 2 Watching
  • mikeeM
    mikeeM
    mikee
    Hi Guys,
    Does somebody have working pulse meter with TCRT5000 on analog power meter (Aluminum rotating wheel). I´m fighting with it right now and I need some help. Do I need to modify the sketch? I´ve adjusted pulse count according to power meter specs. The sensor is on all the time (while white / Al part of wheel) and turns off during the black part of wheel. During on time sends the sensor loooot of impulses, so I had my consumption up to 300 kWh a day and usage up to 100kW. Had someone same issue? Thanks a lot
    • mikeeM mikee
      Hi Guys,
      @mikee this part in the example sketch
            if (interval<500000L) {
              // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
              return;
      stops the sensor from triggering too often. Do you have this part in your sketch? If so, maybe increasing to 1 second or so will take care of the problem?
      • mikeeM
        mikeeM
        mikee
        Yes I´m using example sketch. So my interval could be up to the fastest theoretical revolution ?
        • mikeeM mikee
          @mikee that's correct
          • karlheinz2000K
            karlheinz2000K
            karlheinz2000
            Most of these cheap boards do not have any hysteresis and tend to oscillate during output switching.
            Populate a resistor (100k...330k) for hysteresis and remove a capacitor. I my case this did help.
            Unfortunately in German, see the picture:
            https://forum.fhem.de/index.php/topic,54408.msg459962.html#msg459962
            • mikeeM
              mikeeM
              mikee
              Thanks Guys!
              I have edit the sketch and modified the sensor. Records made during night are finally closer to real situation. I need to correct pulse count.
              @karlheinz2000 - are you using digital or analog output as on FHEM forum? (Danke, fuer Deine Anweisung)
              • karlheinz2000K
                karlheinz2000K
                karlheinz2000
                I use digital output. The R&C modification works only with digital output.
