  3. 💬 Arduino Pro Mini Shield for RFM69(H)W
atmega328patmega328pressureinterstitialhumiditywirelesspcbrfm69hwsensorbme280rfm69temperaturearduinosi7021
53 Posts 13 Posters 17.8k Views 11 Watching
  • zboblamontZ Offline
    zboblamontZ Offline
    zboblamont
    @pepson If you go to 3v Arduino, the answer seems likely to be a 3v relay, either a package as @gohan suggested or roll your own, no ?
    FYI, I have a 3v3 node with a RFM69 which has to run a 5v sensor but the number of spare pins is limited, so after many trials and tribulations, am using a 5v Arduino to run and task the sensor with the results being passed back via I2C to the 3.3 device via level converter, all initiated via a single DPDT relay which switches the booster and 5v unit on and off after each cycle..
    "Radio works ok." is today, tomorrow is another day...
    • M Offline
      M Offline
      muguran
      According to this connection guide https://www.mysensors.org/build/connect_radio the pro mini D2 will connect to RFN69's DI00.
      But the shield seems to connect D4 to DI00.
      Is it OK? Or we need to adapt our sketches?
      N 1 Reply Last reply
      • M muguran
        N Offline
        N Offline
        #43
        @muguran said in 💬 Arduino Pro Mini Shield for RFM69(H)W:
        Actually, no. DIO0 does connect to D2 on this shield, so there should be no issues. :)
        • M Offline
          M Offline
          muguran
          It seems that I've got another board: it have 4 holes above GND, D2, D3 and D4, and DI00 is connected to the one for D4.
          Is this an old version?
          I've ordered at the beginning of this year.
          gohanG 1 Reply Last reply
          • M muguran
            @muguran post a picture if you can
            • M Offline
              M Offline
              muguran
              N pepsonP 2 Replies Last reply
              • M muguran
                N Offline
                N Offline
                @muguran
                Yes, that's an older version. A fix is discussed in the comments above.
                • M muguran
                  pepsonP Offline
                  pepsonP Offline
                  pepson
                  @muguran
                  Hi
                  Where i can buy this pcb to connect RFM69HW with Arduino Mini Pro ?
                  • pepsonP pepson
                    @muguran
                    Hi
                    N Offline
                    N Offline
                    @pepson said in 💬 Arduino Pro Mini Shield for RFM69(H)W:
                    @muguran
                    Hi
                    Click "buy" at this link: https://www.openhardware.io/view/268/Arduino-Pro-Mini-Shield-for-RFM69HW
                    pepsonP 1 Reply Last reply
                    • N NeverDie
                      @muguran
                      Hi
                      pepsonP Offline
                      pepsonP Offline
                      pepson
                      @neverdie
                      • TmasterT Offline
                        TmasterT Offline
                        Tmaster
                        wrote on last edited by Tmaster
                        #51
                        hi.i know that discoussion have some months ,buti'm only doing my rfm69 conversion from nrf24 ,now.
                        second this picture here, i can leave digital pin 2 from arduino direct to rfm69 d0 pin. Without anylevel converter when use a 5v arduino
                        is that true? will not fry because that?
                        i will use a ams1117 3.3v regulator for power rfm69c from my 5v pro minis
                        sorce:https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide
                        i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                          If I remeber right that pin is used as input so the RFM69 is not receiving any 5v signal. In addition there are people claming they have the RFM69 module working on 5v on data pins and 3.3v on vcc, but I hardly suggest to do it.
                          • TmasterT Offline
                            TmasterT Offline
                            Tmaster
                            @gohan said in 💬 Arduino Pro Mini Shield for RFM69(H)W:
                            thank you just what i thought .
                            about direct 5v on data...well... i seen a big red sign saying n :DONT do it! lol
                            Level converters are so cheap...that i ordered 5 or 10 thoguether with rfm69 board.
                            sorry about hijack this topic, i though i was on general discussion
                            12.2k
