  3. Domoticz
  4. sending messages not working for some reason
1 Posts 1 Posters 949 Views 1 Watching
  • eriE Offline
    eriE Offline
    eri
    I am trying to build a board connected to a relay and a switch. I have something up and running. the only issue is that for some reason when i send a message to the controller, it seems to never get there. I never get a response from the controller and on its logs i never see that the message arrived.
    I am using a eth W5100 and it is connected directly to my arduino, i.e. there is no relay or wifi involved, when i push the button i do get the print outs in the console, so the button is working.
    here is my code:
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    //#ifndef MY_RF24_CE_PIN
    //  #define MY_RF24_CE_PIN 5
    //#endif
    //#ifndef MY_RF24_CS_PIN
    //  #define MY_RF24_CS_PIN 6
    //#endif
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,177   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    // Enabled repeater feature for this node
    #define MY_REPEATER_FEATURE
    #include <Ethernet.h>
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Bounce2.h>
    #define RELAY_PIN  5  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  2  // Arduino Digital I/O pin number for button
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    long max_on_time = 100000;
    long last_on_time = 0;
    int ledState = HIGH;         // the current state of the output pin
    int buttonState;             // the current reading from the input pin
    int lastButtonState = LOW;   // the previous reading from the input pin
    long lastDebounceTime = 0;  // the last time the output pin was toggled
    long debounceDelay = 50;    // the debounce time; increase if the output flickers
    MyMessage msg(CHILD_ID,V_STATUS);
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(50);
      pinMode(RELAY_PIN, OUTPUT);
      state = loadState(CHILD_ID);
      send(msg.set(true));
      send(msg.set(false));
    void presentation()  {
      sendSketchInfo("Relay & Button", "1.0");
      present(CHILD_ID, S_LIGHT);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          send(msg.set(state?false:true), true); // Send new state and request ack back
          //send(msg.set(true)); // Send new state and request ack back
          Serial.println(value);
          Serial.println(state);
      oldValue = value;
      Serial.println("got message");
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         saveState(CHILD_ID, state);
         // Write some debug info
         Serial.print(message.sensor);
