  2. Feature Requests
  3. Add a structure level under My Project?
4 Posts 3 Posters 1.8k Views 3 Watching
  • Martin TellblomM
    Martin TellblomM
    Martin Tellblom
    Not so much a request as wishing.
    Would it be possible to add a structure under My Project to collect all the SenseBender, Slim Node projects, Easy/Newbie PCB and so on so it would be simpler to find?
    A structure like this for example:
    My Project
        SenseBender
        Slim Node
        Easy/Newbie PCB
    Or to pin a topic for containing links to all projects
    This maybe already been up for discussion ?
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
      Nice idea.
      An alternative way to achieve the same goal might be to use tags. Example: https://forum.mysensors.org/tags/sensebender
      Not sure which is best but tags might be easier to get going.
        wrote on last edited by hek
        Well, I kind of created openhardware.io to allow you to present your project (not only pcbs) in a more controlled manner. Over there you can tag it with relevant information (Sensebender, Slim Node, Motion Sensor, ....) and it will get a discussion thread here in the forum.
        We can also lift/present cool ideas/projects on mysensors.org if they have been created in the project platform.
        • Martin TellblomM
          Martin TellblomM
          Martin Tellblom
          wrote on last edited by Martin Tellblom
          I was thinking if I created for example a Slim Node project, I should put it in that area.
          Not only the creator of the PCB that the project is based on.
          Just to get it simpler to find project based on a specific PCB
          Or as I said a pinned topic like this
          Example:
          Below is sensors based on My Slim 2AA Battery Slim Node found on openhardware.io
          Slim Node as a Mini 2AA Battery PIR Motion Sensor
          Slim Node Si7021 sensor example
