  3. A nEw aPProach to connection failures - FOREVER!!
1 Posts 1 Posters 709 Views 2 Watching
  • A
    A
    abrasha
    wrote on last edited by abrasha
    hi everybody
    after several connection failure issues which ends only after power cycle of the node (pull the dc adapter out and insert again),
    i thought about changing to v2.0 library ( currently 1.5.4) but it's a 2 days work with 17 nodes to reuploading after sketch updating.
    so before i decide to start this big project, i thought about daily reset command inside the sketch but i only found the watchdog solution which i didnt quite understand and it also has some errors with mysensors here.
    my setup is RPi+S-gw running domoticz controller, most of nodes are nano on io-shield(Nrf24 socket with seperate power supply) some with de-CAP and some without( it thought the shield is enough) . also all my nodes are AC-Dc powered - no batteries at all.
    i finished yesterday installing new repeaters with nano+io-shield and long range antenna like this.
    is there a solution for reconnecting in the new v2.0 library which will solve this issue? something that will serve like a hardware reset and reconnect the node again? im tired of red colored caption on domoticz dashboard and false alarms (because of unupdated values....)
