  3. Upgraded Vera Edge, MySensorsv plugin can't find new devices
2 Posts 2 Posters 1.1k Views 2 Watching
  • J
    J
    jlieffort
    I upgraded Vera Edge to the newest firmware. After that I could no longer connect to the Vera. Had to call customer service they worked on it for an hour, got it upgraded and all the mysensor devices working again.
    The problem now is the vera plugin does not seem to work. I can't add any new devices. MYSController sees the new device, the serial output from the Arduino looks like it's working properly. But when I try to add it the the Vera using the plugin it never discovers the new device.
    It's a new relay and I've built many before and had no problem adding them with the plugin.
    Any help would be appreciated.
    dbemowskD 1 Reply Last reply
    • J jlieffort
      dbemowskD
      dbemowskD
      @jlieffort If you want to follow this thread, I have a brand new vera plus having the same kind of issue. I cannot get device discovery to work.
      https://forum.mysensors.org/topic/5553/brand-new-vera-controller/2
