  3. Serial gateway using Arduino Mega, how to set what serial to use ?
5 Posts 2 Posters 4.0k Views 3 Watching
  • RedguyR
    RedguyR
    Redguy
    I am trying to build a serial <-> RS485 gateway using an Arduino Mega 2560 R3.
    I would like to use the Mega's 4 hardware serial interfaces as follows :
    Serial0 -> debug output (and programming) - This is the USB serial
    Serial1 -> Serial interface of the gateway to the Domoticz Controller
    Serial2 -> RS485 MySensors bus interface to the sensors nodes (using a MAX485 with direction connected to D2)
    Digging through the various library files and examples, I have found settings to configure the hardware serial to use for the RS485 interface : #define MY_RS485_HWSERIAL Serial2
    The setting does not turn green in the arduini IDE like the other defines, but it seems to be accepted if I try to compile the sketch.
    Until however, I have not bee able to find how I can setup the use of hardware serial 0 for debug output and hardware serial 1 as RS232 side of the serial gateway.
    Is this even possible ?
    Current settings so far :
    #define MY_GATEWAY_SERIAL                 // Enable serial gateway
    #define MY_BAUD_RATE 115200               // Set RS232 baud rate to Controller
    #define MY_DEBUG                                     // Enable debug prints to serial monitor
    #define MY_RS485                                            // Enable RS485 transport layer
    #define MY_RS485_HWSERIAL Serial2         // Use hardware serial port 2 for RS485
    #define MY_RS485_DE_PIN 2                         // Use D2 as DE-pin for RS485
    #define MY_RS485_BAUD_RATE 9600         // Set RS485 baud rate to use
    #define MY_LEDS_BLINKING_FEATURE          // Flash leds on rx/tx/err
    #define MY_DEFAULT_LED_BLINK_PERIOD 300   // Set blinking period
    #define MY_DEFAULT_RX_LED_PIN  4  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
    #define MY_DEFAULT_ERR_LED_PIN 6  // Error led pin
    • RedguyR
      RedguyR
      Redguy
      Realy ? nobody ?
      • vikmadV
        vikmadV
        vikmad
        On my Arduino Mega works for me this:
        //#define MY_DEBUG
        //#define MY_DEBUG_HWSERIAL Serial // = Serial0 / Rx0 & Tx0 to programming & debug
        #define MY_SERIALDEVICE Serial3 // Rx3 & Tx3 to Gateway
        #define MY_RS485
        #define MY_RS485_HWSERIAL Serial1 // Rx1 & Tx1 to RS485 network
        #define MY_RS485_DE_PIN 22
        I tried to edit a library MyHwAVR.cpp for MY_DEBUG_HWSERIAL, but without any positive result.:
        #ifdef MY_DEBUG
        #ifndef MY_DEBUG_HWSERIAL
        #define MY_DEBUG_HWSERIAL MY_SERIALDEVICE
        void hwDebugPrint(const char *fmt, ... )
        	char fmtBuffer[MY_SERIAL_OUTPUT_SIZE];
        #ifdef MY_GATEWAY_FEATURE
        	// prepend debug message to be handled correctly by controller (C_INTERNAL, I_LOG_MESSAGE)
        	snprintf_P(fmtBuffer, sizeof(fmtBuffer), PSTR("0;255;%d;0;%d;"), C_INTERNAL, I_LOG_MESSAGE);
        	MY_DEBUG_HWSERIAL.print(fmtBuffer);
        #else
        	// prepend timestamp (AVR nodes)
        	MY_DEBUG_HWSERIAL.print(hwMillis());
        	MY_DEBUG_HWSERIAL.print(" ");
        	va_list args;
        	va_start (args, fmt );
        	// Truncate message if this is gateway node
        	vsnprintf_P(fmtBuffer, sizeof(fmtBuffer), fmt, args);
        	fmtBuffer[sizeof(fmtBuffer) - 2] = '\n';
        	fmtBuffer[sizeof(fmtBuffer) - 1] = '\0';
        #else
        	va_end (args);
        	MY_DEBUG_HWSERIAL.flush();
        	//MY_DEBUG_HWSERIAL.write(freeRam());
        The code above does not work!
        • RedguyR
          RedguyR
          Redguy
          Ah that My_Serialdevice setting is something i completely missed..will test that this weekend..
          i am fine with the debug going to the usb port.. it's just that i can leave the usb to my pc for programming and debugging while another serial is connected to the raspberry pi running domoticz for the mysensors gateway part.
          • RedguyR
            RedguyR
            Redguy
            Tried ir, but no change.. Serial0 was still used while serial1was defined
