  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.5k Views 42 Watching
  • Mark SwiftM Mark Swift
    @tekka, started a windows VM, run via MinGW and got this when running makefile, does it look okay?
    C:\MySensorsBootloaderRF24-development>mingw32-make.exe
    rm *.o
    process_begin: CreateProcess(NULL, rm *.o, ...) failed.
    make (e=2): The system cannot find the file specified.
    Makefile:40: recipe for target 'clean' failed
    mingw32-make.exe: [clean] Error 2 (ignored)
    rm *.elf
    process_begin: CreateProcess(NULL, rm *.elf, ...) failed.
    rm *.hex
    process_begin: CreateProcess(NULL, rm *.hex, ...) failed.
    "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -funsigned-char -funsigned-bitfields
     -DF_CPU=16000000L -Os -ffunction-sections -fdata-sections -fpack-struct -fshort
    -enums -mrelax -Wall -Wextra -Wundef -pedantic -mmcu=atmega328p -c -std=gnu99 -M
    D -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o"  -IC:/Ardu
    ino/hardware/tools/avr/avr/include/avr MYSBootloader.c -o MYSBootloader.o
    In file included from Core.h:40:0,
                     from MYSBootloader.c:69:
    HW.h:51:2: warning: #warning is a GCC extension
     #warning BAUD_RATE error greater than 2%
    HW.h:51:2: warning: #warning BAUD_RATE error greater than 2% [-Wcpp]
    In file included from Core.h:42:0,
    MyMessage.h:292:3: warning: ISO C99 doesn't support unnamed structs/unions [-Wpe
    dantic]
    "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -nostartfiles -Wl,-s -Wl,-static -Wl
    ,-Map=".map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-se
    ction-start=.text=0x7800 -mmcu=atmega328p   -o MYSBootloader.elf MYSBootloader.o
     -lm
    "C:/Arduino/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom MYSBootloader
    .elf MYSBootloader.hex
    "C:/Arduino/hardware/tools/avr/bin/avr-size" MYSBootloader.elf
       text    data     bss     dec     hex filename
       2036       6      72    2114     842 MYSBootloader.elf
    tekkaT
    tekkaT
    tekka
    @Mark-Swift What changes did you make to the bootloader - the code size seems increased
    Mark SwiftM 1 Reply Last reply
    • tekkaT tekka
      Mark SwiftM
      Mark SwiftM
      Mark Swift
      wrote on last edited by Mark Swift
      #42
      @tekka None that I'm aware of? :(
      I just changed the fuses in the makefile to match the ones in my boards.txt, not sure if that's required, can you take a look at my questions above, I really want to be sure I'm doing all of this right before deploying.
      To recap with regards the bootloader.
      1. Installed Windows 7
      2. Installed mingw (core and c++ compiler)
      3. Installed Arduino IDE and MySensors library (Installed at the same location as you, at c drive root)
      4. Downloaded bootloader from github
      5. Edited the fuses and clock speed at the top of the makefile to match my boards.txt
      6. Ran makefile from cmd
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @Mark-Swift ok, most probably a false alarm. I assume you tested it after compilation?
        • Mark SwiftM
          Mark SwiftM
          Mark Swift
          @tekka It seems to work? I guess if there was an issue it wouldn't work at all?
          Please can you conform my fuses look okay in the boards.txt I posted above? Also, do I need to change the fuses in the makefile and make a file for each device, or just 1 x 16Mhz and 1 x 8Mhz for example?
            tekkaT
            tekkaT
            tekka
            @Mark-Swift I'm not at my workstation right now - you have to adjust the fuse settings according to your HW configurations and preferences. The fuse settings in the makefile are obsolete if you use the Arduino IDE / boards.txt for flashing. Please use the AVR fuse calculator to calculate to correct fuse settings:
            http://www.engbedded.com/fusecalc/
            • Mark SwiftM
              Mark SwiftM
              Mark Swift
              I @tekka, I thought as much, so basically I just need a bootloader with the right Mhz and then set fuses in the Arduino IDE boards.txt.
              I used the fuse settings from the original boards.txt included with the Arduino IDE, but adjusted the extended one to 0x06 (Adjust BOD).
              I noticed you used slightly different fuses to the Arduino IDE, you're using fuses that indicate a floating crystal or something?
              • A
                A
                andreground
                wrote on last edited by andreground
                #47
                @tekka
                First of all, thanks for working so hard on the new version of the BL.
                My setup:
                • MYSBootloader 1.3.0-beta3 (md5 49ef3dc263110613c9c25ac21a8c3d83)
                • MYSController 1.0.0.beta (updated to latest version)
                • GW on Arduino Nano
                • Node on Arduino Pro Mini @ 5V 16 Mhz with MockMySensors sketch running
                What I did:
                • Flashed latest bootloader version from github on the Pro Mini ATMEGA328P (using AVRDUDESS 2.4 & USBasp, fuses L: 0xFF, H: 0xDA, E: 0x05)
                • Flashed latest mysensors lib on both node & gw (tested with both 2.0.0 & 2.1) on the Nano
                What I got:
                • FW upgrade through MYSController: Working
                • Reboot through MYSController: Working
                • Serial flashing with Arduino IDE: Working
                • Request presentation through MYSController: Working
                  Request heartbeat through MYSController: Working
                But...
                Reassign ID through MYSController: NOT WORKING (the node reboots but still preserves the old ID)
                (MY_NODE_ID IS NOT DEFINED / THUS SET AS AUTO AS PER MYSENSORS DEFAULTS)
                Clear EEPROM through MYSController: NOT WORKING (the node reboots but still holds the value saved in EEPROM using saveState)
                Node bootlog after Clear EEPROM from MYSBootloader (you can see my debug LOADSTATE which still loads the value 123 from EEPROM):
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=4)
                TSM:FPAR
                TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSP:MSG:READ 150-150-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                TSP:MSG:BC
                TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSP:MSG:PAR OK (ID=0, dist=1)
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=4)
                TSM:UPL
                TSP:PING:SEND (dest=0)
                TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:READ 0-0-4 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                TSP:MSG:PONG RECV (hops=1)
                TSP:CHKUPL:OK
                TSM:UPL:OK
                TSM:READY
                GW Started
                LOADSTATE
                123
                And...is it expected that the "Info" tab on my node shows bootloader version 1.2?
                Is there anything I'm missing to have these features working?
                Thanks in advance
                • A andreground
                  @tekka
                  My setup:
                  What I did:
                  What I got:
                  But...
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSP:MSG:BC
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=4)
                  TSM:UPL
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  GW Started
                  LOADSTATE
                  123
                  Thanks in advance
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #48
                  @andreground Yes, re-assigning can be done nowadays with the MySensors framework, i.e. send a C_INTERNAL/I_ID_RESPONSE/<NEW ID> message to the (active) node.
                  A 1 Reply Last reply
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    @tekka is it okay to use the bootloader on the gateway?
                      tekkaT
                      tekkaT
                      tekka
                      @Mark-Swift That depends on the use case - what do you have in mind?
                      • tekkaT tekka
                        Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        #51
                        @tekka I'd like to put my gateway in quite an isolated place and update the sketches OTA, but I presume that's not possible as without the gateway live, there's nothing to action the OTA :(
                        I've tried the ESP as it allows OTA updates, but the ESP still has blocking code and it can't handle all my nodes without dropping messages.
                          I don't know if it the right place to ask, but I am planning to make a wired sensor network (I already have cables) like an RS485 or whatever better technology, so is there any good solution to implement OTA updates? Thanks
                          • tekkaT tekka
                            A
                            A
                            andreground
                            @tekka thanks, it works.
                            2 more questions:
                            1. Should the clearing eeprom function in MYSBootloader be working?
                            2. From what I understand, Watchdog is enabled by default (8S timeout) in the bootloader; that means that I've to either call wdt_reset in my loop or call wdt_disable in setup to prevent unexpected reboots. Am i right?
                            tekkaT Mark SwiftM 2 Replies Last reply
                            • A andreground
                              2 more questions:
                              tekkaT
                              tekkaT
                              tekka
                              @andreground said in MYSBootloader 1.3.0-beta.3:
                              2 more questions:
                              No, this has also been moved to the MySensors framework:
                              Add:
                              If MY_DEBUG is disabled, you can add
                              #define MY_SPECIAL_DEBUG
                              and then send a C_INTERNAL / I_DEBUG / E to the node. For the sake of completeness, here are the special debug commands:
                              E: Clear EEPROM (node replies with OK and reboots)
                              V: Report CPU voltage in mV (if supported)
                              F: Report frequency in cHz
                              M: Report free memory
                              R: Report routing table (if node is a repeater/gateway)
                              1. From what I understand, Watchdog is enabled by default (8S timeout) in the bootloader; that means that I've to either call wdt_reset in my loop or call wdt_disable in setup to prevent unexpected reboots. Am i right?
                              wdt_reset() is called within the framework, so no need to call it unless you have blocking code of >8s. Alternatively, you can also disable it (AVR: if the wdton fuse is cleared).
                              • A andreground
                                2 more questions:
                                Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @tekka
                                I've never used the clear EEPROM feature but would like to.
                                I've added:
                                To my sketches. Using the latest MYSController, will the menu option 'Clear EEPROM' still do the trick, or does the application need some updates?
                                • J
                                  J
                                  jacikaas
                                  Is there going to be 1 and 8MHz MySBootloader hex files? :)
                                  Thanks!
                                  • J
                                    J
                                    jkandasa
                                    @tekka, I tested this bootloader and facing an issue.
                                    https://github.com/mysensors/MySensorsBootloaderRF24/issues/7
                                    • AndurilA
                                      AndurilA
                                      Anduril
                                      How do I do a remote reboot of a node? Node is not responding to MYSController command (I think due to changed things as with reassigning node-ID). DO I have to write a receive event or enable it somehow? Node is sleeping most time, maybe that's a problem.
                                      • S
                                        Samuel235
                                        #59
                                        I'm very interested in testing your development for the latest MYSBootloader as the bootloader for OTA updates on my new hardware designs that i'm starting to design, but i would like a stable one first to make sure my system and setup are working fine with the stable. Is the stable bootloader the one in the master branch of https://github.com/mysensors/MySensorsBootloaderRF24/tree/master. The MYSBootloader.hex file or does this still need to be compiled for use?
                                        Or do you happen to have a download link for the stable version, should we be using the one that you bundle together with MYSController?
                                        Also, @tekka - Do you advise a stable one that works for MyController.org please?
                                        MySensors 2.1.1
                                        • Nicolas CharrierN
                                          Nicolas CharrierN
                                          Nicolas Charrier
                                          With this bootloader, i can not upload scetch with serial or USB.
                                          Where does i made a mistake?
                                          Is there a configuration that is specific to the bootloader?
