  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.7k Views 42 Watching
  • A andreground
    @tekka
    First of all, thanks for working so hard on the new version of the BL.
    My setup:
    • MYSBootloader 1.3.0-beta3 (md5 49ef3dc263110613c9c25ac21a8c3d83)
    • MYSController 1.0.0.beta (updated to latest version)
    • GW on Arduino Nano
    • Node on Arduino Pro Mini @ 5V 16 Mhz with MockMySensors sketch running
    What I did:
    • Flashed latest bootloader version from github on the Pro Mini ATMEGA328P (using AVRDUDESS 2.4 & USBasp, fuses L: 0xFF, H: 0xDA, E: 0x05)
    • Flashed latest mysensors lib on both node & gw (tested with both 2.0.0 & 2.1) on the Nano
    What I got:
    • FW upgrade through MYSController: Working
    • Reboot through MYSController: Working
    • Serial flashing with Arduino IDE: Working
    • Request presentation through MYSController: Working
      Request heartbeat through MYSController: Working
    But...
    Reassign ID through MYSController: NOT WORKING (the node reboots but still preserves the old ID)
    (MY_NODE_ID IS NOT DEFINED / THUS SET AS AUTO AS PER MYSENSORS DEFAULTS)
    Clear EEPROM through MYSController: NOT WORKING (the node reboots but still holds the value saved in EEPROM using saveState)
    Node bootlog after Clear EEPROM from MYSBootloader (you can see my debug LOADSTATE which still loads the value 123 from EEPROM):
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=4)
    TSM:FPAR
    TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 150-150-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSP:MSG:BC
    TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=4)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-4 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    GW Started
    LOADSTATE
    123
    And...is it expected that the "Info" tab on my node shows bootloader version 1.2?
    Is there anything I'm missing to have these features working?
    Thanks in advance
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    #48
    @andreground Yes, re-assigning can be done nowadays with the MySensors framework, i.e. send a C_INTERNAL/I_ID_RESPONSE/<NEW ID> message to the (active) node.
    A 1 Reply Last reply
    • Mark SwiftM
      Mark SwiftM
      Mark Swift
      @tekka is it okay to use the bootloader on the gateway?
      tekkaT 1 Reply Last reply
      • Mark SwiftM Mark Swift
        tekkaT
        tekkaT
        tekka
        @Mark-Swift That depends on the use case - what do you have in mind?
        Mark SwiftM 1 Reply Last reply
        • tekkaT tekka
          Mark SwiftM
          Mark SwiftM
          Mark Swift
          wrote on last edited by Mark Swift
          #51
          @tekka I'd like to put my gateway in quite an isolated place and update the sketches OTA, but I presume that's not possible as without the gateway live, there's nothing to action the OTA :(
          I've tried the ESP as it allows OTA updates, but the ESP still has blocking code and it can't handle all my nodes without dropping messages.
            I don't know if it the right place to ask, but I am planning to make a wired sensor network (I already have cables) like an RS485 or whatever better technology, so is there any good solution to implement OTA updates? Thanks
            • tekkaT tekka
              andreground
              @tekka thanks, it works.
              2 more questions:
              1. Should the clearing eeprom function in MYSBootloader be working?
              2. From what I understand, Watchdog is enabled by default (8S timeout) in the bootloader; that means that I've to either call wdt_reset in my loop or call wdt_disable in setup to prevent unexpected reboots. Am i right?
              tekkaT Mark SwiftM 2 Replies Last reply
              • A andreground
                2 more questions:
                tekkaT
                tekkaT
                tekka
                @andreground said in MYSBootloader 1.3.0-beta.3:
                2 more questions:
                No, this has also been moved to the MySensors framework:
                Add:
                If MY_DEBUG is disabled, you can add
                #define MY_SPECIAL_DEBUG
                and then send a C_INTERNAL / I_DEBUG / E to the node. For the sake of completeness, here are the special debug commands:
                E: Clear EEPROM (node replies with OK and reboots)
                V: Report CPU voltage in mV (if supported)
                F: Report frequency in cHz
                M: Report free memory
                R: Report routing table (if node is a repeater/gateway)
                1. From what I understand, Watchdog is enabled by default (8S timeout) in the bootloader; that means that I've to either call wdt_reset in my loop or call wdt_disable in setup to prevent unexpected reboots. Am i right?
                wdt_reset() is called within the framework, so no need to call it unless you have blocking code of >8s. Alternatively, you can also disable it (AVR: if the wdton fuse is cleared).
                • A andreground
                  2 more questions:
                  Mark SwiftM
                  Mark SwiftM
                  Mark Swift
                  @tekka
                  I've never used the clear EEPROM feature but would like to.
                  I've added:
                  To my sketches. Using the latest MYSController, will the menu option 'Clear EEPROM' still do the trick, or does the application need some updates?
                  • J
                    J
                    jacikaas
                    Is there going to be 1 and 8MHz MySBootloader hex files? :)
                    • J
                      J
                      jkandasa
                      @tekka, I tested this bootloader and facing an issue.
                      https://github.com/mysensors/MySensorsBootloaderRF24/issues/7
                      • AndurilA
                        AndurilA
                        Anduril
                        How do I do a remote reboot of a node? Node is not responding to MYSController command (I think due to changed things as with reassigning node-ID). DO I have to write a receive event or enable it somehow? Node is sleeping most time, maybe that's a problem.
                          Samuel235
                          #59
                          I'm very interested in testing your development for the latest MYSBootloader as the bootloader for OTA updates on my new hardware designs that i'm starting to design, but i would like a stable one first to make sure my system and setup are working fine with the stable. Is the stable bootloader the one in the master branch of https://github.com/mysensors/MySensorsBootloaderRF24/tree/master. The MYSBootloader.hex file or does this still need to be compiled for use?
                          Or do you happen to have a download link for the stable version, should we be using the one that you bundle together with MYSController?
                          Also, @tekka - Do you advise a stable one that works for MyController.org please?
                          MySensors 2.1.1
                          • Nicolas CharrierN
                            Nicolas CharrierN
                            Nicolas Charrier
                            With this bootloader, i can not upload scetch with serial or USB.
                            Where does i made a mistake?
                            Is there a configuration that is specific to the bootloader?
                            • Nicolas CharrierN Nicolas Charrier
                              tekkaT
                              tekkaT
                              tekka
                              @Nicolas-Charrier Welcome to MySensors. Please do not post the same question in different threads. Maybe you can give additional information that help to understand what you tried so far (logs, screenshots, HW configuration, CPU frequency, etc.). Did you follow the OTA/bootloader instructions here?
                              Nicolas CharrierN AffordableTechA 2 Replies Last reply
                              • tekkaT tekka
                                Nicolas CharrierN
                                Nicolas CharrierN
                                Nicolas Charrier
                                @tekka
                                I can now program my board with serial line. It's work perfectly.
                                It's an issue with my serial converteur and an usb hub. The usb hub add a delay that is not compatible with the bootloader.
                                Sorry for the question.
                                Nico
                                  @tekka
                                  Nico
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Nicolas-Charrier Good to know, thanks for your feedback :)
                                  • kk02067K
                                    kk02067K
                                    kk02067
                                    Excuse me for beeing an idiot. But how do you compile the bootloader from source? Do you do it from Atmel studio or from Arduino IDE. And how is it done? When I compile it in Atmel studio it gets an base adress of 0x0000 which is wrong.
                                    I am used to program in assembler in Atmel studio and when I program in C i don't touch anyting else than the .c file. So some form of tutorial kind of thing would be helpful.
                                    Thank you
                                    • R
                                      R
                                      rvweert
                                      Hey all,
                                      I've compiled the bootloader and was able to install it with Arduino as ISP to a Nano. I couldn't find the lines necessary for the Nano in boards.txt so I created this:
                                      nanomysbootloader.name=Arduino Nano MYSBootloader
                                      nanomysbootloader.upload.tool=avrdude
                                      nanomysbootloader.upload.protocol=arduino
                                      nanomysbootloader.bootloader.tool=avrdude
                                      nanomysbootloader.bootloader.unlock_bits=0x3F
                                      nanomysbootloader.bootloader.lock_bits=0x0F
                                      nanomysbootloader.build.f_cpu=16000000L
                                      nanomysbootloader.build.board=AVR_NANO
                                      nanomysbootloader.build.core=arduino
                                      nanomysbootloader.build.variant=eightanaloginputs
                                      ## Arduino Nano w/ ATmega328
                                      nanomysbootloader.menu.cpu.atmega328=ATmega328
                                      nanomysbootloader.menu.cpu.atmega328.upload.maximum_size=30720
                                      nanomysbootloader.menu.cpu.atmega328.upload.maximum_data_size=2048
                                      nanomysbootloader.menu.cpu.atmega328.upload.speed=115200
                                      nanomysbootloader.menu.cpu.atmega328.bootloader.low_fuses=0xFF
                                      nanomysbootloader.menu.cpu.atmega328.bootloader.high_fuses=0xDA
                                      nanomysbootloader.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
                                      nanomysbootloader.menu.cpu.atmega328.bootloader.file=MySensors/MYSBootloader.hex
                                      nanomysbootloader.menu.cpu.atmega328.build.mcu=atmega328p
                                      Is this correct? Besides, on some devices I cannot program over serial anymore now, only through another ISP. Could that be caused by incorrect settings? Is it possible to recover from that?
                                      The error I'm getting is this one:
                                      avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x32
                                      Thanks and happy easter!
                                      Rene
                                      • tekkaT tekka
                                        AffordableTechA
                                        AffordableTechA
                                        AffordableTech
                                        Hi All,
                                        I'm currently upgrading to MySensors 2.0.0 and it would make sense to change over to the MYSBootloader as I upgrade each node. (I'd like to be able to use the remote re-boot command from MYSController).
                                        I have been reading about the MYSBootloader and have some questions . . .
                                        Q1 - My nodes are a mixture of Pro-Micro's, Leonardo's, Mega 2560's and the odd UNO. From what I can see, the MYSbootloader.hex file is for the Mega328p, is this correct, or can the same bootloader be adjusted (fuse settings etc) for others like the Leonardo processor?
                                        Q2 - One post I read seemed to imply that to use the remote reboot feature you needed 'either' the MYSBootloader OR OptiBoot. In the OptiBoot readme, it doesn't mention reboot as a feature, so I am wondering if it really does support reboot - can anyone please confirm?
                                        Many thanks,
                                        Paul
                                          Q1) Yes, correct.
                                          Q2) The reboot is handled automatically when new firmware has been downloaded by the library. Note: When using DualOptiboot you must also enable the MY_OTA_FIRMWARE_FEATURE when compiling the sketch to allow updates.
