  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.7k Views 42 Watching
  • Mark SwiftM Mark Swift
    @tekka It seems to work? I guess if there was an issue it wouldn't work at all?
    Please can you conform my fuses look okay in the boards.txt I posted above? Also, do I need to change the fuses in the makefile and make a file for each device, or just 1 x 16Mhz and 1 x 8Mhz for example?
    tekkaT
    tekkaT
    tekka
    @Mark-Swift I'm not at my workstation right now - you have to adjust the fuse settings according to your HW configurations and preferences. The fuse settings in the makefile are obsolete if you use the Arduino IDE / boards.txt for flashing. Please use the AVR fuse calculator to calculate to correct fuse settings:
    http://www.engbedded.com/fusecalc/
    • Mark SwiftM
      Mark SwiftM
      Mark Swift
      I @tekka, I thought as much, so basically I just need a bootloader with the right Mhz and then set fuses in the Arduino IDE boards.txt.
      I used the fuse settings from the original boards.txt included with the Arduino IDE, but adjusted the extended one to 0x06 (Adjust BOD).
      I noticed you used slightly different fuses to the Arduino IDE, you're using fuses that indicate a floating crystal or something?
      • A
        andreground
        wrote on last edited by andreground
        #47
        @tekka
        First of all, thanks for working so hard on the new version of the BL.
        My setup:
        • MYSBootloader 1.3.0-beta3 (md5 49ef3dc263110613c9c25ac21a8c3d83)
        • MYSController 1.0.0.beta (updated to latest version)
        • GW on Arduino Nano
        • Node on Arduino Pro Mini @ 5V 16 Mhz with MockMySensors sketch running
        What I did:
        • Flashed latest bootloader version from github on the Pro Mini ATMEGA328P (using AVRDUDESS 2.4 & USBasp, fuses L: 0xFF, H: 0xDA, E: 0x05)
        • Flashed latest mysensors lib on both node & gw (tested with both 2.0.0 & 2.1) on the Nano
        What I got:
        • FW upgrade through MYSController: Working
        • Reboot through MYSController: Working
        • Serial flashing with Arduino IDE: Working
        • Request presentation through MYSController: Working
          Request heartbeat through MYSController: Working
        But...
        Reassign ID through MYSController: NOT WORKING (the node reboots but still preserves the old ID)
        (MY_NODE_ID IS NOT DEFINED / THUS SET AS AUTO AS PER MYSENSORS DEFAULTS)
        Clear EEPROM through MYSController: NOT WORKING (the node reboots but still holds the value saved in EEPROM using saveState)
        Node bootlog after Clear EEPROM from MYSBootloader (you can see my debug LOADSTATE which still loads the value 123 from EEPROM):
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=4)
        TSM:FPAR
        TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSP:MSG:READ 150-150-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
        TSP:MSG:BC
        TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSP:MSG:PAR OK (ID=0, dist=1)
        TSM:FPAR:OK
        TSM:ID
        TSM:CHKID:OK (ID=4)
        TSM:UPL
        TSP:PING:SEND (dest=0)
        TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
        TSP:MSG:READ 0-0-4 s=255,c=3,t=25,pt=1,l=1,sg=0:1
        TSP:MSG:PONG RECV (hops=1)
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        GW Started
        LOADSTATE
        123
        And...is it expected that the "Info" tab on my node shows bootloader version 1.2?
        Is there anything I'm missing to have these features working?
        Thanks in advance
        tekkaT 1 Reply Last reply
        • A andreground
          @tekka
          My setup:
          What I did:
          What I got:
          But...
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSP:MSG:BC
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=4)
          TSM:UPL
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          GW Started
          LOADSTATE
          123
          Thanks in advance
          tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          #48
          @andreground Yes, re-assigning can be done nowadays with the MySensors framework, i.e. send a C_INTERNAL/I_ID_RESPONSE/<NEW ID> message to the (active) node.
          A 1 Reply Last reply
          • Mark SwiftM
            Mark SwiftM
            Mark Swift
            @tekka is it okay to use the bootloader on the gateway?
              tekkaT
              tekkaT
              tekka
              @Mark-Swift That depends on the use case - what do you have in mind?
              Mark SwiftM 1 Reply Last reply
              • tekkaT tekka
                Mark SwiftM
                Mark SwiftM
                Mark Swift
                wrote on last edited by Mark Swift
                #51
                @tekka I'd like to put my gateway in quite an isolated place and update the sketches OTA, but I presume that's not possible as without the gateway live, there's nothing to action the OTA :(
                I've tried the ESP as it allows OTA updates, but the ESP still has blocking code and it can't handle all my nodes without dropping messages.
                  I don't know if it the right place to ask, but I am planning to make a wired sensor network (I already have cables) like an RS485 or whatever better technology, so is there any good solution to implement OTA updates? Thanks
                  • tekkaT tekka
                    andreground
                    @tekka thanks, it works.
                    2 more questions:
                    1. Should the clearing eeprom function in MYSBootloader be working?
                    2. From what I understand, Watchdog is enabled by default (8S timeout) in the bootloader; that means that I've to either call wdt_reset in my loop or call wdt_disable in setup to prevent unexpected reboots. Am i right?
                    tekkaT Mark SwiftM 2 Replies Last reply
                    • A andreground
                      2 more questions:
                      tekkaT
                      tekkaT
                      tekka
                      @andreground said in MYSBootloader 1.3.0-beta.3:
                      2 more questions:
                      No, this has also been moved to the MySensors framework:
                      Add:
                      If MY_DEBUG is disabled, you can add
                      #define MY_SPECIAL_DEBUG
                      and then send a C_INTERNAL / I_DEBUG / E to the node. For the sake of completeness, here are the special debug commands:
                      E: Clear EEPROM (node replies with OK and reboots)
                      V: Report CPU voltage in mV (if supported)
                      F: Report frequency in cHz
                      M: Report free memory
                      R: Report routing table (if node is a repeater/gateway)
                      1. From what I understand, Watchdog is enabled by default (8S timeout) in the bootloader; that means that I've to either call wdt_reset in my loop or call wdt_disable in setup to prevent unexpected reboots. Am i right?
                      wdt_reset() is called within the framework, so no need to call it unless you have blocking code of >8s. Alternatively, you can also disable it (AVR: if the wdton fuse is cleared).
                      • A andreground
                        2 more questions:
                        Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        @tekka
                        I've never used the clear EEPROM feature but would like to.
                        I've added:
                        To my sketches. Using the latest MYSController, will the menu option 'Clear EEPROM' still do the trick, or does the application need some updates?
                        • J
                          J
                          jacikaas
                          Is there going to be 1 and 8MHz MySBootloader hex files? :)
                          • J
                            J
                            jkandasa
                            @tekka, I tested this bootloader and facing an issue.
                            https://github.com/mysensors/MySensorsBootloaderRF24/issues/7
                            • AndurilA
                              AndurilA
                              Anduril
                              How do I do a remote reboot of a node? Node is not responding to MYSController command (I think due to changed things as with reassigning node-ID). DO I have to write a receive event or enable it somehow? Node is sleeping most time, maybe that's a problem.
                                Samuel235
                                #59
                                I'm very interested in testing your development for the latest MYSBootloader as the bootloader for OTA updates on my new hardware designs that i'm starting to design, but i would like a stable one first to make sure my system and setup are working fine with the stable. Is the stable bootloader the one in the master branch of https://github.com/mysensors/MySensorsBootloaderRF24/tree/master. The MYSBootloader.hex file or does this still need to be compiled for use?
                                Or do you happen to have a download link for the stable version, should we be using the one that you bundle together with MYSController?
                                Also, @tekka - Do you advise a stable one that works for MyController.org please?
                                MySensors 2.1.1
                                • Nicolas CharrierN
                                  Nicolas CharrierN
                                  Nicolas Charrier
                                  With this bootloader, i can not upload scetch with serial or USB.
                                  Where does i made a mistake?
                                  Is there a configuration that is specific to the bootloader?
                                  • Nicolas CharrierN Nicolas Charrier
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Nicolas-Charrier Welcome to MySensors. Please do not post the same question in different threads. Maybe you can give additional information that help to understand what you tried so far (logs, screenshots, HW configuration, CPU frequency, etc.). Did you follow the OTA/bootloader instructions here?
                                    Nicolas CharrierN AffordableTechA 2 Replies Last reply
                                    • tekkaT tekka
                                      Nicolas CharrierN
                                      Nicolas CharrierN
                                      Nicolas Charrier
                                      @tekka
                                      I can now program my board with serial line. It's work perfectly.
                                      It's an issue with my serial converteur and an usb hub. The usb hub add a delay that is not compatible with the bootloader.
                                      Sorry for the question.
                                      Nico
                                        @tekka
                                        Nico
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Nicolas-Charrier Good to know, thanks for your feedback :)
                                        • kk02067K
                                          kk02067K
                                          kk02067
                                          Excuse me for beeing an idiot. But how do you compile the bootloader from source? Do you do it from Atmel studio or from Arduino IDE. And how is it done? When I compile it in Atmel studio it gets an base adress of 0x0000 which is wrong.
                                          I am used to program in assembler in Atmel studio and when I program in C i don't touch anyting else than the .c file. So some form of tutorial kind of thing would be helpful.
                                          Thank you
