  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • R
    R
    Reza
    This post is deleted!
    • M marceloaqno
      I created the draft for the official article: https://www.mysensors.org/build/orange
      R
      R
      Reza
      @marceloaqno
      thank you. but i have error:
      root@OrangePI:~# ls /sys/class/gpio/export
      ls: cannot access /sys/class/gpio/export: No such file or directory
      root@OrangePI:~# modprobe gpio-sunxi
      in class folder i dont have gpio folder (i use a orangepi one with ubuntu os )
      i
      T 1 Reply Last reply
      • R Reza
        @marceloaqno
        i
        Tag
        @Reza
        You need to create the files after each boot.
        After the modprobe, Issue this command:
        sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
        This will get you the files.
        R 2 Replies Last reply
        • R
          R
          Reza
          root@OrangePI:~# git clone https://github.com/marceloaqno/MySensors.git orangepi               Cloning into 'orangepi'...
          remote: Counting objects: 13858, done.
          remote: Compressing objects: 100% (50/50), done.
          remote: Total 13858 (delta 17), reused 0 (delta 0), pack-reused 13808
          Receiving objects: 100% (13858/13858), 9.68 MiB | 79.00 KiB/s, done.
          Resolving deltas: 100% (8304/8304), done.
          Checking connectivity... done.
          root@OrangePI:~# cd orangepi/
          root@OrangePI:~/orangepi# git pull origin spidev
          From https://github.com/marceloaqno/MySensors
           * branch            spidev     -> FETCH_HEAD
          Updating 570b607..63e1a81
          Fast-forward
           Makefile                                          |  16 +++
           MyConfig.h                                        |   4 +
           MySensors.h                                       |   2 +-
           configure                                         |  79 ++++++++++---
           core/MyHwLinuxGeneric.cpp                         |  17 +++
           core/MyHwLinuxGeneric.h                           |  12 +-
           core/MyHwRPi.cpp                                  |   1 +
           core/MyHwRPi.h                                    |  28 -----
           core/MyMainLinux.cpp                              |  30 ++---
           drivers/{RPi => BCM}/SPI.cpp                      |  10 +-
           drivers/{RPi => BCM}/SPI.h                        | 116 ++++++++++++-------
           drivers/{RPi => BCM}/Wire.cpp                     |   0
           drivers/{RPi => BCM}/Wire.h                       |   1 +
           drivers/Linux/Arduino.h                           |  22 +++-
           drivers/Linux/GPIO.cpp                            | 119 ++++++++++++++++++++
           drivers/Linux/GPIO.h                              |  47 ++++++++
           drivers/Linux/Stream.h                            |   1 +
           drivers/Linux/compatibility.cpp                   |  11 +-
           drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} | 144 +++++-------------------
           drivers/Linux/interrupt.h                         |  45 ++++++++
           drivers/RF24/RF24.cpp                             |   4 +-
           drivers/RF24/RF24.h                               |   2 +-
           drivers/RPi/RPi.cpp                               |  59 ++++++++++
           drivers/RPi/RPi.h                                 |  22 ++++
           drivers/RPi/piHiPri.c                             |  49 --------
           drivers/RPi/rpi_util.h                            |  76 -------------
           drivers/RPi/wiring.cpp                            |  72 ++++++++++++
           drivers/RPi/wiring.h                              |  24 ++++
           drivers/SPIDEV/SPI.cpp                            | 223 +++++++++++++++++++++++++++++++++++++
           drivers/SPIDEV/SPI.h                              | 178 +++++++++++++++++++++++++++++
           30 files changed, 1054 insertions(+), 360 deletions(-)
           rename drivers/{RPi => BCM}/SPI.cpp (100%)
           rename drivers/{RPi => BCM}/SPI.h (62%)
           rename drivers/{RPi => BCM}/Wire.cpp (100%)
           rename drivers/{RPi => BCM}/Wire.h (99%)
           create mode 100644 drivers/Linux/GPIO.cpp
           create mode 100644 drivers/Linux/GPIO.h
           rename drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} (63%)
           create mode 100644 drivers/Linux/interrupt.h
           create mode 100644 drivers/RPi/RPi.cpp
           create mode 100644 drivers/RPi/RPi.h
           delete mode 100644 drivers/RPi/piHiPri.c
           delete mode 100644 drivers/RPi/rpi_util.h
           create mode 100644 drivers/RPi/wiring.cpp
           create mode 100644 drivers/RPi/wiring.h
           create mode 100644 drivers/SPIDEV/SPI.cpp
           create mode 100644 drivers/SPIDEV/SPI.h
          root@OrangePI:~/orangepi# ./configure
          [SECTION] Detecting target machine.
            [OK] machine detected: SoC=H3, Type=unknown, CPU=armv7l.
          [SECTION] Detecting SPI driver.
            [OK] SPI driver detected:SPIDEV.
          [SECTION] Detecting init system.
            [OK] init system detected: systemd.
          [SECTION] Saving configuration.
          [SECTION] Cleaning previous builds.
          [OK] Finished.
          root@OrangePI:~/orangepi# make
          gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
          g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
          g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
          g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
          g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
          g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
          g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
          g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
          g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
          g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
          drivers/Linux/interrupt.cpp: In function ‘void* interruptHandler(void*)’:
          drivers/Linux/interrupt.cpp:107:26: warning: ignoring return value of ‘ssize_t read(int, void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
             (void)read (fd, &c, 1) ;
          g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
          g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
          g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
          In file included from ./MySensors.h:294:0,
                           from examples_linux/mysgw.cpp:74:
          ./drivers/RF24/RF24.cpp:39:11: error: Not supported on this platform.
            hwDigitalWrite(MY_RF24_CS_PIN, level);
          ./drivers/RF24/RF24.cpp:44:11: error: Not supported on this platform.
            hwDigitalWrite(MY_RF24_CE_PIN, level);
          ./drivers/RF24/RF24.cpp:388:11: error: Not supported on this platform.
            hwPinMode(MY_RF24_CE_PIN,OUTPUT);
          ./drivers/RF24/RF24.cpp:389:11: error: Not supported on this platform.
            hwPinMode(MY_RF24_CS_PIN,OUTPUT);
          ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
           LOCAL void RF24_csn(const bool level)
          ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
           LOCAL void RF24_ce(const bool level)
          ./drivers/RF24/RF24.cpp: In function ‘uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)’:
          ./drivers/RF24/RF24.cpp:56:11: error: ‘LOW’ was not declared in this scope
            RF24_csn(LOW);
          ./drivers/RF24/RF24.cpp:99:11: error: ‘HIGH’ was not declared in this scope
            RF24_csn(HIGH);
          ./drivers/RF24/RF24.cpp: In function ‘void RF24_startListening()’:
          ./drivers/RF24/RF24.cpp:235:10: error: ‘HIGH’ was not declared in this scope
            RF24_ce(HIGH);
          ./drivers/RF24/RF24.cpp: In function ‘void RF24_stopListening()’:
          ./drivers/RF24/RF24.cpp:241:10: error: ‘LOW’ was not declared in this scope
            RF24_ce(LOW);
          ./drivers/RF24/RF24.cpp: In function ‘void RF24_powerDown()’:
          ./drivers/RF24/RF24.cpp:251:10: error: ‘LOW’ was not declared in this scope
            RF24_ce(LOW);
          ./drivers/RF24/RF24.cpp: In function ‘bool RF24_sendMessage(uint8_t, const void*, uint8_t)’:
          ./drivers/RF24/RF24.cpp:269:10: error: ‘HIGH’ was not declared in this scope
            RF24_ce(HIGH);
          ./drivers/RF24/RF24.cpp:276:10: error: ‘LOW’ was not declared in this scope
            RF24_ce(LOW);
          ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
          ./drivers/RF24/RF24.cpp:395:10: error: ‘LOW’ was not declared in this scope
            RF24_ce(LOW);
          ./drivers/RF24/RF24.cpp:396:11: error: ‘HIGH’ was not declared in this scope
            RF24_csn(HIGH);
          Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
          make: *** [build/examples_linux/mysgw.o] Error 1
          root@OrangePI:~/orangepi#```
          • T Tag
            @Reza
            R
            R
            Reza
            @Tag
            root@OrangePI:~/orangepi# sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
            -bash: syntax error near unexpected token `do'
            root@OrangePI:~/orangepi# ```
            • T Tag
              @Reza
              R
              R
              Reza
              orangepi one have 40 pins
              M 1 Reply Last reply
              • R Reza
                marceloaqno
                Code Contributor
                @Reza Is there /sys/class/gpio/export file on your OPi?
                • M marceloaqno
                  R
                  R
                  Reza
                  @marceloaqno
                  no i have not folder "gpio" in my orangepi
                    mihai.aldea
                    @marceloaqno It still doesn't work on my OPi Zero :confused:
                    root@opi-zero-1:~/orangepi# bin/mysgw -d
                    mysgw: Starting gateway...
                    mysgw: Protocol version - 2.2.0-beta
                    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.2.0-beta
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: !TSM:INIT:TSP FAIL
                    mysgw: TSM:FAIL:CNT=1
                    mysgw: TSM:FAIL:PDT
                    mysgw: Received SIGINT
                    I do have the /sys/class/gpio/export and I ran for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
                    For the record, here's my OS:
                    BOARD=orangepizero
                    BOARD_NAME="Orange Pi Zero"
                    VERSION=5.24
                    LINUXFAMILY=sun8i
                    BRANCH=default
                    ARCH=arm
                    PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
                    NAME="Debian GNU/Linux"
                    VERSION_ID="8"
                    VERSION="8 (jessie)"
                    ID=debian
                    HOME_URL="http://www.debian.org/"
                    SUPPORT_URL="http://www.debian.org/support"
                    BUG_REPORT_URL="https://bugs.debian.org/"
                    • M mihai.aldea
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      BOARD=orangepizero
                      VERSION=5.24
                      LINUXFAMILY=sun8i
                      BRANCH=default
                      ARCH=arm
                      VERSION_ID="8"
                      ID=debian
                      marceloaqno
                      Code Contributor
                      @mihai.aldea The gateway does the exporting when needed, you don't need to run:
                      Could you send the output of this command?
                      ls -lah /dev/spidev*
                      • M marceloaqno
                        Tag
                        wrote on last edited by Tag
                        #91
                        @marceloaqno
                        Still issues here:
                        root@orangepizero:~/orangepi/bin# ll /dev/spi*
                        crw------- 1 root root 153, 0 Jan  9 22:51 /dev/spidev0.0
                        crw------- 1 root root 153, 1 Jan  9 22:51 /dev/spidev1.0
                        Then:
                        ./configure --spi-spidev-device=/dev/spidev1.0
                        added to examples_linux/mysgw.cpp
                        #define MY_RF24_CE_PIN 2
                        #define MY_RF24_CS_PIN 13
                        end enabled radio debugging:
                        output:
                        root@orangepizero:~/orangepi/bin# ./mysgw -d
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: RF24:write register, reg=0, value=14
                        mysgw: RF24:write register, reg=3, value=3
                        mysgw: RF24:write register, reg=4, value=95
                        mysgw: RF24:write register, reg=5, value=76
                        mysgw: RF24:write register, reg=6, value=39
                        mysgw: RF24:write register, reg=16, value=115
                        mysgw: RF24:write register, reg=29, value=6
                        mysgw: RF24:read register, reg=6, value=39
                        mysgw: RF24:read register, reg=5, value=76
                        mysgw: RF24:write register, reg=2, value=2
                        mysgw: RF24:write register, reg=1, value=0
                        mysgw: RF24:write register, reg=28, value=3
                        mysgw: RF24:flushRX
                        mysgw: RF24:flushTX
                        mysgw: RF24:write register, reg=7, value=112
                        mysgw: TSM:INIT:TSP OK
                        mysgw: TSM:INIT:GW MODE
                        mysgw: RF24:write register, reg=2, value=3
                        mysgw: RF24:write register, reg=1, value=1
                        mysgw: RF24:STRT LIS
                        mysgw: RF24:write register, reg=0, value=15
                        mysgw: RF24:write register, reg=10, value=0
                        mysgw: MCO:REG:NOT NEEDED
                        mysgw: RF24:read register, reg=23, value=17
                        Illegal instruction
                        Almost there?
                        • M marceloaqno
                          R
                          R
                          Reza
                          wrote on last edited by Reza
                          #92
                          @marceloaqno
                          in "orangepi one"(ubuntu os) there is not gpio folder in sys/class. but i think after run "modprobe gpio-sunxi" built a folder that name is "gpio_sw" and in this folder there are this files: normal_led,pa3,pa6,pa8 and 9,10,13,14,15,21 ,...
                          M T 2 Replies Last reply
                          • R Reza
                            @marceloaqno
                            mihai.aldea
                            @Reza Is it too complicated to switch to Debian?
                            R 1 Reply Last reply
                            • M mihai.aldea
                              R
                              R
                              Reza
                              you told me i change my os ? to armbian ?
                              • R Reza
                                @marceloaqno
                                Tag
                                #95
                                @Reza
                                More info on armbian.com
                                I use the debian jessie, works like a charm!
                                  mihai.aldea
                                  @Reza I wouldn't even dream of not using Armbian on OrangePi and NanoPi. Compared to Raspbian it's years ahead in terms of optimization and tidyness. Armbian is the reason I'm avoiding RPi when possible. So go ahead and install a proper OS for your OPi. Not sure if Xenial or Debian, maybe we should wait for @marceloaqno to respond to my comment with the running OS.
                                  • T Tag
                                    @Reza
                                    R
                                    R
                                    Reza
                                    @Tag
                                    i worked with armbiam before. but my question is with armbian my problem is resolve ?
                                      mihai.aldea
                                      That I can not say.
                                      • T Tag
                                        @Reza
                                        R
                                        R
                                        Reza
                                        ok i change my os and test again. thank you
                                          mihai.aldea
                                          I confirm it's not working on the OPi PC where TMRh20 works.
                                          S 1 Reply Last reply
