  3. NExtion and I2C
NExtion and I2C
1 Posts 1 Posters 1.8k Views 1 Watching
  • B Offline
    B Offline
    Bos Video
    He i have Nextion screen. I need show on Nextion data from I2C sensors.. I have ESP8266 devkit. Here is my sketch but this sketch no showing temp and hum on the Nextion. I need alternative wire.h. ? Thanks.
    #include <ESP8266WiFi.h>
    #include <BlynkSimpleEsp8266.h>
    #include <SimpleTimer.h>
    #include <DHT.h>
    #include <Wire.h>
    #include <SI7021.h>
    float temp, hum;
    bool SI7021_present = true;
    #define I2C_SCL 12      // Barometric Pressure Sensor (BMP085)
    #define I2C_SDA 13
    SI7021 sensor;
    #include <Nextion.h>
    #include <SoftwareSerial.h>
    #define DHTPIN 2 //D4
    #define DHTTYPE DHT22   // DHT 22 Change this if you have a DHT11
    DHT dht(DHTPIN, DHTTYPE);
    // You should get Auth Token in the Blynk App.
    // Go to the Project Settings (nut icon).
    char auth[] = "";  // Put your Auth Token here. (see Step 3 above)
    SoftwareSerial HMISerial(4,5,false,256);//RX-D1 , TX-D2
    Nextion myNextion(HMISerial, 9600);
    SimpleTimer timer;
     Wire.begin();
      sensor.begin(SDA,SCL);
      Wire.begin(I2C_SDA, I2C_SCL);
      Serial.begin(9600); // See the connection status in Serial Monitor
      Blynk.begin(auth, "", ""); //insert here your SSID and password
      myNextion.init();
      // Setup a function to be called every second
      timer.setInterval(10000L, sendUptime);
    void sendUptime()
      // You can send any value at any time.
      // Please don't send more that 10 values per second.
       //Read the Temp and Humidity from DHT
      float h = dht.readHumidity();
      float t = dht.readTemperature();
      Blynk.virtualWrite(12, t); // virtual pin
      Blynk.virtualWrite(13, h); // virtual pin
     float temperature = sensor.getCelsiusHundredths()/100;
     float humidity = sensor.getHumidityPercent();
     Blynk.virtualWrite(5, temperature);
     Blynk.virtualWrite(6, humidity); // virtual pin
      myNextion.setComponentText("t1", String(temperature));
      myNextion.setComponentText("t2", String(humidity));
      myNextion.setComponentText("t3", String(t));
      myNextion.setComponentText("t4", String(h));
      delay(1000);
      String dim = "dim=50";         //pro podsvíceni
      myNextion.sendCommand(dim.c_str()); //pro podsvícení
      Blynk.run();
      timer.run();
