  3. Vera
  4. Stay on version 1.5 or move to 2.1.1 on my vera plus and vera 3?
6 Posts 3 Posters 3.0k Views 2 Watching
  • CorvlC
    CorvlC
    Corvl
    Hello everyone,
    I run version 1.5 on both my vera's and Ethernet gateways and someone hinted to go to version 2.x since the newer codes don't work with 1.5
    I also read on this forum there are issues with version 2.x and library.
    Is it usefull to stay on version 1.5 or I better upgrade?
    I run not that many nodes , an important one, servo actuator which is working good. And a door sensor with temperature sensor which is working not so good , it doesn't report alway , so an extra piece of code is inserted so it reports at least every 30 seconds. Maybe with the new library and codes this is solved , and it reports a change immediately?
    This is the code for the servo actuator I use , will it still work with version 2.11?
    // Example showing how to create an atuator for a servo.
    // Connect red to +5V, Black or brown to GND and the last cable to Digital pin 3.
    // The servo consumes much power and should probably have its own powersource.'
    // The arduino might spontanally restart if too much power is used (happend
    // to me when servo tried to pass the extreme positions = full load).
    // Contribution by: Derek Macias
    #include <Servo.h>
    #define SERVO_DIGITAL_OUT_PIN 3
    #define SERVO_MIN 0 // Fine tune your servos min. 0-180
    #define SERVO_MAX 180 // Fine tune your servos max. 0-180
    #define DETACH_DELAY 4000 // Tune this to let your movement finish before detaching the servo
    #define CHILD_ID 10   // Id of the sensor child
    MyMessage msg(CHILD_ID, V_DIMMER);
    Servo myservo;  // create servo object to control a servo
                    // a maximum of eight servo objects can be created Sensor gw(9,10);
    unsigned long timeOfLastChange = 0;
    bool attachedServo = false;
      // Attach method for incoming messages
      gw.begin(incomingMessage);
      gw.sendSketchInfo("Servo", "1.0");
      gw.present(CHILD_ID, S_COVER);
      // Request last servo state at startup
      gw.request(CHILD_ID, V_DIMMER);
      gw.process();
      if (attachedServo && millis() - timeOfLastChange > DETACH_DELAY) {
         myservo.detach();
      myservo.attach(SERVO_DIGITAL_OUT_PIN);
      attachedServo = true;
      if (message.type==V_DIMMER) { // This could be M_ACK_VARIABLE or M_SET_VARIABLE
         int val = message.getInt();
        val = map(val, 0, 100, 0, 180); // scale 0%-100% between 0 and 180)
            myservo.write(val);       // sets the servo position 0-180
         // Write some debug info
         Serial.print("Servo changed. new state: ");
         Serial.println(val);
       } else if (message.type==V_UP) {
         Serial.println("Servo UP command");
         myservo.write(SERVO_MIN);
         gw.send(msg.set(100));
       } else if (message.type==V_DOWN) {
         Serial.println("Servo DOWN command");
         myservo.write(SERVO_MAX);
         gw.send(msg.set(0));
       } else if (message.type==V_STOP) {
         Serial.println("Servo STOP command");
         myservo.detach();
       timeOfLastChange = millis();
    marceltrapmanM Boots33B 2 Replies Last reply
    • CorvlC Corvl
      Hello everyone,
      #include <Servo.h>
        gw.process();
           myservo.detach();
           myservo.detach();
      marceltrapmanM
      marceltrapmanM
      marceltrapman
      wrote on last edited by marceltrapman
      @Corvl Hi, I did not have many sensors until now but I am ready to add stuff ( I finally have some time again :) ).
      Because of that I decided to re-evaluate my sensors and to upgrade in the process.
      You probably guessed it but this is what I would do.
      If you are not planning to add (many) sensors and everything works well I would stay with 1.5.
      If either or both of the above conditions == false I would move to 2.2.1 (current version).
      Fulltime Servoy Developer
      • CorvlC
        CorvlC
        Corvl
        I would like to add some more stuff as well, and hopefully , with the newer version that doorsensor is working better.
        But is 2.11 working on vera?
        And the above sketch , of the servo actuator , is that one still compatible?
        Thanks,
        Cor
        • CorvlC Corvl
          Thanks,
          Cor
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          @Corvl I can't comment on the vera question.
          For 2.1.1 you have to make some changes but they are not too difficult ;)
          • CorvlC Corvl
            Hello everyone,
            #include <Servo.h>
              gw.process();
                 myservo.detach();
                 myservo.detach();
            Boots33B
            Boots33B
            Boots33
            @Corvl I am also not sure of any problems with Vera.
            Had a quick look at your sketch and it should be ok in version 2.
            V_DIMMER has been Deprecated and although it will still work at the moment you should now use V_PERCENTAGE instead
            Did a quick re-write for V2 so you can see what is different. I think I got all the changes
            I think you will find v2 easier to use once you get the hang of it
            //#define MY_REPEATER_FEATURE
            //#include <MySensor.h>
            #include <Servo.h>
            //MySensor gw;
            //MyMessage msg(CHILD_ID, V_DIMMER);  //V_DIMMER has been deprecated use V_PERCENTAGE instead
            MyMessage msg(CHILD_ID, V_PERCENTAGE);
             // gw.begin(incomingMessage);
              //gw.sendSketchInfo("Servo", "1.0");
              //gw.present(CHILD_ID, S_COVER);
              //gw.request(CHILD_ID, V_DIMMER);
              request(CHILD_ID, V_PERCENTAGE);
            void presentation()  {
             // gw.process();
                 myservo.detach();
            //void incomingMessage(const MyMessage &message) {
            void receive(const MyMessage &message){
              //if (message.type==V_DIMMER) { // This could be M_ACK_VARIABLE or M_SET_VARIABLE
              if (message.type==V_PERCENTAGE) {
                // gw.send(msg.set(100));
                   send(msg.set(100));
              //   gw.send(msg.set(0));
                   send(msg.set(0));
                 myservo.detach();
            • CorvlC
              CorvlC
              Corvl
              Thanks a lot , that is a big re-assurance , since that servo is hooked up on my heating system...... and it is still winter.
              Still , there are 2 or 3 threads here on this forum saying they cab's get version 2.x to work with vera on Ui7.
              I have a spare vera lite on Ui7 I will try this version 2.x on the vera lite first. But it will be for next week.
              Thanks a lot so far!,
              Cor
