  3. Vera
  4. Plugin not working..... error: unexpected symbol near '<' <0x2ba1d680>
4 Posts 2 Posters 2.6k Views 2 Watching
  • otolosaO
    otolosaO
    otolosa
    wrote on last edited by otolosa
    first...My serial gateway was working fine. One day it stopped woring and i decided to upgrade to latest versions.
    Now i cant make it work again!!!
    I can configure the serial port and create the My Sensors Plugin device, however always getting error when engine starts (Lua startup failure).
    im seeing this error on log
    50 02/24/17 11:20:22.545 luup_log:101: Arduino plugin: loading library L_Arduino ... LEAK this:966656 start:2011136 to 0x104f000 <0x2ba1d680>
    01 02/24/17 11:20:22.602 luup_require [string "..."]:5: unexpected symbol near '<' <0x2ba1d680>
    01 02/24/17 11:20:22.605 luup_log:101: Arduino plugin: plugin is not installed correctly. Library L_Arduino cannot be loaded. <0x2ba1d680>
    01 02/24/17 11:20:22.606 LuaInterface::CallFunction_Startup-2 device 101 function startup failed (null) with return false <0x2ba1d680>
    just fyi...my nano has the ftdi chip
    thanks for your help
    blaceyB 1 Reply Last reply
    • otolosaO otolosa
      blaceyB
      blaceyB
      blacey
      @otolosa I looks like the Vera plugin files are not installed correctly... I suggest that you remove the existing plugin files and reinstall following the instructions here - https://www.mysensors.org/controller/vera Make sure that you install the correct version - either UI5 or UI7.
      otolosaO 1 Reply Last reply
      • blaceyB blacey
        otolosaO
        otolosaO
        otolosa
        @blacey thanks for your reply
        Thats exactly what i did (well didnt remove old files)
        Downloaded latest library, latest arduino ide, and the vera files ...that arent exactly new
        Uploaded the 9 files to vera, uploaded the serial gateway sketch to my nano
        Actually... I tried 3 different mysensors library versions with the same result.
        Any ideas?
        • otolosaO
          otolosaO
          otolosa
          FIXED!!!!
          i used I_Arduino1.xml and L_Arduino.lua from development branch and now the plugin its working!!!!
          I'll include some sensors and check if everything works
