  3. Ethernet Gateway code for UNO with plugged-in ethernet shield
3 Posts 3 Posters 2.2k Views 3 Watching
  • A
    A
    ArduiSens
    Dear all,
    The MySensor program of the Ethernet gateway didn't work.
    I saw a few posts saying to change background code / hardware if you work with UNO / Ethernet shield.
    The comments about that are not clear for me, the reason way I post this issue.
    The goal is to connect with Domoticz (on Synology) via the MySensor Ethernet gateway.
    Can someone gives me a hint or link to a solved post?
    thanks in advance ;-)
    MySensors 2.3.2; contr:Domoticz; layer: RS485, nRF24; gw: Ethernet, Serial
    gohanG Boots33B 2 Replies Last reply
    • A ArduiSens
      Dear all,
      @ArduiSens
      You want to build a gateway but for which of the supported interfaces?
      • A ArduiSens
        Dear all,
        Boots33B
        Boots33B
        Boots33
        @ArduiSens I have an uno with w5100 Ethernet shield connecting to Domoticz running on my Synology . So it should work for you too. Have a look at this post and see if the information there helps.
        If not post your sketch and we may be able to find the problem
