  3. MQTT 3 Door switch sketch (Single relay to be added)
1 Posts 1 Posters 2.2k Views 1 Watching
  • BrydenB
    BrydenB
    Bryden
    Hey Guys,
    After searching a ton and doing a heap of reading, I couldn't find a multiple door switch sketch that works on 2.xx at all.
    I have this sketch working on the bench on a nodeMCU, Works best when 10k external pull ups are used as well.
    Going to add a relay to the sketch as well next now I have the 3 door switch's working.
    So I'm just sharing this so others can see hows its done.
    I'm a copy paste programmer so please dont shoot any mistakes or lack of knowledge, I'm sure there is a better way of doing it like I have seen in the relay sketch with some ++ sort of thing I have yet to work out.
    This is designed to be used with Home Assistant, It will monitor a garage door with open and closed reed switches, The internal door into the house, and the relay will trigger the garage internal light. But you could use it with whatever you want.
    Enjoy.
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "ESP2-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "ESP2-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "ESP2"
    #define MY_MQTT_USER "******"
    #define MY_MQTT_PASSWORD "******"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "******"
    #define MY_ESP8266_PASSWORD "******"
    #define MY_ESP8266_HOSTNAME "ESP2"
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS ******
    #define MY_PORT 1883
    #include <ESP8266WiFi.h>
    #include <Bounce2.h>
    // Setting multiple child ID's for each switch and it's GPIO pin
    //Switch 1
    #define CHILD_ID_1 1
    #define BUTTON_PIN_1  4  // Arduino Digital I/O pin for button/reed switch
    //Switch 2
    #define CHILD_ID_2 2
    #define BUTTON_PIN_2  5  // Arduino Digital I/O pin for button/reed switch
    //Switch 3
    #define CHILD_ID_3 3
    #define BUTTON_PIN_3  10  // Arduino Digital I/O pin for button/reed switch
    //switch 1
    Bounce debouncer_1 = Bounce();
    int oldValue_1=-1;
    //switch 2
    Bounce debouncer_2 = Bounce();
    int oldValue_2=-1;
    //switch 3
    Bounce debouncer_3 = Bounce();
    int oldValue_3=-1;
    // Setting mysensor message string (ChildID, V type)
    MyMessage msg1(CHILD_ID_1,V_TRIPPED);
    MyMessage msg2(CHILD_ID_2,V_TRIPPED);
    MyMessage msg3(CHILD_ID_3,V_TRIPPED);
    //Presenting each child ID
    void presentation() {
      present(CHILD_ID_1, S_DOOR);
      present(CHILD_ID_2, S_DOOR);
      present(CHILD_ID_3, S_DOOR);
    //Setting up each GPIO pin as an input and turning on internal pull up resistor
      // Setup the button 1
      pinMode(BUTTON_PIN_1,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN_1,HIGH);
      debouncer_1.attach(BUTTON_PIN_1);
      debouncer_1.interval(5);
        // Setup the button 2
      pinMode(BUTTON_PIN_2,INPUT);
      digitalWrite(BUTTON_PIN_2,HIGH);
      debouncer_2.attach(BUTTON_PIN_2);
      debouncer_2.interval(5);
        // Setup the button 3
      pinMode(BUTTON_PIN_3,INPUT);
      digitalWrite(BUTTON_PIN_3,HIGH);
      debouncer_3.attach(BUTTON_PIN_3);
      debouncer_3.interval(5);
      // Switch 1
      debouncer_1.update();
      // Get the update value
      int value_1 = debouncer_1.read();
      if (value_1 != oldValue_1) {
         // Send in the new value
         send(msg1.set(value_1==HIGH ? 1 : 0));
         oldValue_1 = value_1;
      // Switch 2
      debouncer_2.update();
      int value_2 = debouncer_2.read();
      if (value_2 != oldValue_2) {
         send(msg2.set(value_2==HIGH ? 1 : 0));
         oldValue_2 = value_2;
      // Switch 3
      debouncer_3.update();
      int value_3 = debouncer_3.read();
      if (value_3 != oldValue_3) {
         send(msg3.set(value_3==HIGH ? 1 : 0));
         oldValue_3 = value_3;
