  3. Need a bid of help...
15 Posts 3 Posters 3.7k Views 3 Watching
  • R
    R
    Rene046
    Hi there i'm working on my first project.
    got some code working fine, but would like to try to add an BMP180 or 280 into the sketch.
    I.m working with the latest version of my sensors. 2.1
    It would be nice to include a forecast but that a bid to hard for me at this moment.
    so far i found a sample of a weather station, ith forecast, but im not shure if i need more sensors like a dht then.
    Maybe some could give a sample or advice.
    #include <BH1750.h>
    #include <Wire.h>
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    int SOLAR_SENSE_PIN = A1;  // select the input pin for the solar sense point
    #define CHILD_ID_BATTERY 4
    #define CHILD_ID_SOLAR 6
    #define CHILD_ID_LIGHT 1
    BH1750 lightSensor;
    int oldBatteryPcnt = 0;
    MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
    MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE);
    uint16_t lastlux;  //lux
    void setup(){
    	analogReference(INTERNAL1V1);
    #else
    	analogReference(INTERNAL);
    	sendSketchInfo("Battery Meter", "2.0");
    	// get the battery Voltage
    	int sensorValue2 = analogRead(BATTERY_SENSE_PIN);
      delay(1000);
      int sensorValue1 = analogRead(BATTERY_SENSE_PIN);
      delay(100);
      delay(1000);
      int sensorValueS = analogRead(SOLAR_SENSE_PIN);
      delay(1000);
    #ifdef MY_DEBUG
    	Serial.print("Battery Voltage2: ");
      Serial.println(sensorValue2);
      Serial.print("Battery Voltage1: ");
      Serial.println(sensorValue1);
      Serial.println(sensorValue);
      Serial.print("Solar Voltage: ");
      Serial.println(sensorValueS);
      const float vRef = 4.200/ 1.05/ 1023 ;
      float batteryV  = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt
      float batteryS  = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt
    #ifdef MY_DEBUG
    	Serial.print(batteryV);
    	Serial.println(" V");
    send(msgbatt.set(batteryV ,2));
      Serial.print(batteryS);
    send(msgsolar.set(batteryS ,2));
    	Serial.print(batteryPcnt);
    	Serial.println(" %");
    		// Power up radio after sleep
    		oldBatteryPcnt = batteryPcnt;
      uint16_t lux = lightSensor.readLightLevel();// Get Lux value
      Serial.println(lux);
      if (lux != lastlux) {
          send(msg.set(lux));
          lastlux = lux;
    	sleep(SLEEP_TIME);
    R 1 Reply Last reply
    • R Rene046
      #include <BH1750.h>
      #include <Wire.h>
      BH1750 lightSensor;
      void setup(){
      #else
        delay(1000);
        delay(100);
        delay(1000);
        delay(1000);
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
            send(msg.set(lux));
            lastlux = lux;
      	sleep(SLEEP_TIME);
      R
      R
      Rene046
      @Rene046 said in Need a bid of help...:
      #include <BH1750.h>
      #include <Wire.h>
      BH1750 lightSensor;
      void setup(){
      #else
        delay(1000);
        delay(100);
        delay(1000);
        delay(1000);
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
            send(msg.set(lux));
            lastlux = lux;
      	sleep(SLEEP_TIME);
      i forget to tell i have an bmp180 and a bme280 available
      • R
        R
        Rene046
        What are the read command for an bme280
        float temperature = bme.readTemperature();
        float humidity = bme.readHumidity();
        float pressure= bme.readPressure()
        • R
          R
          Rene046
          wrote on last edited by Rene046
          this is what i got s far...
          mysensor.readTempC() and bmp.readTemperature(); both not working.
          now i got it accepted but my working sketch peaces give problems.
          #include <BH1750.h>
          #include <Wire.h>
          //#include <Adafruit_BME280.h>
          //#include <SparkFunBME280.h>
          #include <BME280_MOD-1022.h>
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 2
          #define CHILD_ID_BARO 3
          BH1750 lightSensor;
          MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP);
          MyMessage msgHum(CHILD_ID_HUM,V_HUM);
          MyMessage msgPres(CHILD_ID_BARO,V_PRESSURE);
          void setup(){
          #else
            present(CHILD_ID_BARO, S_BARO);
            present(CHILD_ID_HUM, S_HUM);
            delay(1000);
            delay(100);
            delay(1000);
            delay(1000);
            // Read out the data - must do this before calling the getxxxxx routines
            BME280.readMeasurements();
            // get temperature from BME280
            float temperature = BME280.getTemperatureMostAccurate();
            // get humidity from BME280
            float humidity = BME280.getHumidityMostAccurate();
            // get pressure from BME280
            float pressure = BME280.getPressureMostAccurate();
          #ifdef MY_DEBUG
          Serial.print("Buiten Temp: ");
            Serial.print(temperature);
            Serial.println(" Celcius");
          Serial.print("Vochtigheid: ");
            Serial.print(humidity);
            Serial.println(" ?");
          Serial.print("Buiten Druk: ");
            Serial.print(pressure);
          send(msgPres.set(pressure, 2));
                send(msg.set(lux));
                lastlux = lux;
          	sleep(SLEEP_TIME);
            Take a look at nodemanager, it will simplify your life ☺️
              R
              R
              Rene046
              @gohan
              Hi Gohan.
              Im still learning .. nodemanager ????
              Features
              Manage all the aspects of a sleeping cycle by leveraging smart sleep
              Allow configuring the sleep mode and the sleep duration remotely
              Allow waking up a sleeping node remotely at the end of a sleeping cycle
              Allow powering on each connected sensor only while the node is awake to save battery
              Report battery level periodically and automatically
              Calculate battery level without requiring an additional pin and the resistors
              Report battery voltage through a built-in sensor
              Can report battery level on demand
              Allow rebooting the board remotely
              Provide out-of-the-box sensors personalities and automatically execute their main task at each cycle
              it looks intresting but i just started...
                For beginners it's easier, it cuts down code quite a lot
                  R
                  R
                  Rene046
                  @gohan
                  Do you have a sample or could you help me starting with the sketch i already have ?
                  • R Rene046
                    @gohan
                    R
                    R
                    Rene046
                    @gohan
                    i installed nodemanager i think ...lol
                    • R
                      R
                      Rene046
                      This post is deleted!
                        maybe you set the something wrong in the sleep settings, but without seeing your code it's hard to give you an answer :)
                        • R
                          R
                          Rene046
                          Found it i connected the BME280 in the BH1750 line after removing i worked again....
                          the sketch could not work without Seeing the BH1750.
                          my code is in my first post on top of this topic.
                            Yes, but I wanted to see if you made the modifications to run the nodemanager
                            • R
                              R
                              Rene046
                              nope i dont even know where to start....
                              • alowhumA
                                alowhumA
                                alowhum
                                Try this code:
                                https://github.com/flatsiedatsie/MySensorsArduinoExamples/blob/5c84100098352bab6db4b9c86e76db79842131ec/examples/WeatherStationSensor/WeatherStationSensor.ino
