  3. [SOLVED] No Serial prints for loop(), using MySensors 2.1.1
4 Posts 2 Posters 1.8k Views 2 Watching
  • HenryWhiteH
    HenryWhiteH
    HenryWhite
    wrote on last edited by HenryWhite
    I'm getting all the debug messages if I define #MY_DEBUG, but none of my Serial prints in the loop functions are shown.
    However, Serial prints in the receive function are shown.
    Example sketch:
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 20
    #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before()
    		pinMode(pin, OUTPUT);
    		present(sensor, S_BINARY);
      Serial.println("This doesn't print :(");
      delay(1000);
    	if (message.type==V_STATUS) {
    		Serial.println("This does print!");
    It would be really nice if someone could help me with this problem.
    • HenryWhiteH
      HenryWhiteH
      HenryWhite
      I found the problem, but not the solution.
      First, I added #define MY_TRANSPORT_WAIT_READY_MS 1 to the sketch.
      Now the loop()-Function gets executed.
      Problem: My node isn't registered by the gateway:
      New Motion State: 1
      80949 !MCO:SND:NODE NOT REG
      81582 TSF:MSG:READ,0-0-20,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      81588 TSF:MSG:FPAR OK,ID=0,D=1
      82950 TSM:FPAR:OK
      82952 TSM:ID
      82952 TSM:ID:OK
      82954 TSM:UPL
      82958 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      84967 TSM:UPL
      84969 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      :arrow_right: My Gateway is running on an old version of MySensors, I believe it's 1.5.4
      Do I have to update the gateway? I thought I could leave it at 1.5.4.
      • korttomaK
        korttomaK
        korttoma
        I think that 1.5.x GW does not work with 2.x nodes but 2.x GW works with 1.5.x nodes.
        Please update your GW ;)
        • Tomas
        HenryWhiteH 1 Reply Last reply
        • korttomaK korttoma
          HenryWhiteH
          HenryWhiteH
          HenryWhite
          @korttoma thanks! It works now. :)
          Could have saved me hours of troubleshooting if I knew that prior :/
