  3. node stalled
node stalled
11 Posts 2 Posters 3.0k Views 2 Watching
  • jjkJ
    jjkJ
    jjk
    Hi there,
    I've been encountering a strange issue with one my nodes and can't seem to figure out how to fix it. The node is built with an arduino nano, nrf24, and a HC-SR04 distance sensor. Things worked out o.k. for a while, then I updated the sketch so the sensor would only send a measurement every 5 minutes. Now, every time I restart the node and check via serial monitor, I only get a few lines, then the whole thing stalls.
    3 TSM:INIT
    4 TSF:WUR:MS=1
    11 TSM:INIT:TSP OK
    12 TSM:INIT:STATID=151
    15 TSF:SID:OK,ID=15
    I've tried to clear the eeprom, and uploaded the sketch again, but that won't change a thing. My sketch is included below.
    Any idea is welcome at this point...
    Thanks,
    JJK
    // Enable debug prints
    #define MY_DEBUG_VERBOSE
    #define MY_TRANSPORT_WAIT_READY_MS 1
    // define node specific configuration
    #define MY_NODE_ID 151
    #define MY_PARENT_NODE_ID 21
    //#define MY_PARENT_NODE_IS_STATIC
    #include <NewPing.h>
    #define CHILD_ID 1
    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    unsigned long SLEEP_TIME = 300000; // Sleep time between reads (in milliseconds)
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage msg(CHILD_ID, V_DISTANCE);
    int lastDist;
    bool metric = true;
    void presentation() {
      sendSketchInfo("Distance Sensor", "1.0");
      present(CHILD_ID, S_DISTANCE);
      int dist = metric?sonar.ping_cm():sonar.ping_in();
      Serial.print("Ping: ");
      Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      Serial.println(metric?" cm":" in");
      if (dist != lastDist) {
          send(msg.set(dist));
          lastDist = dist;
      wait(5000);
      smartSleep(SLEEP_TIME);
    gohanG 1 Reply Last reply
    • jjkJ jjk
      Hi there,
      3 TSM:INIT
      4 TSF:WUR:MS=1
      11 TSM:INIT:TSP OK
      15 TSF:SID:OK,ID=15
      Thanks,
      JJK
      #define CHILD_ID 1
      int lastDist;
      bool metric = true;
            lastDist = dist;
        wait(5000);
      @jjk is there a specific reason to use MY_PARENT_NODE_ID? Do you have also a log on gateway or gateway doesn't receive anything? Have you checked the repeater that it seems you are using?
      jjkJ 1 Reply Last reply
        jjkJ
        jjkJ
        jjk
        @gohan: the reason I'm using MY_PARENT_NODE_ID is to ensure connection to the repeater. The sensor in question is outside in the yard and I won't get it to connect to the gateway otherwise.
        Yes, I have checked, both the repeater node and the gateway and both are talking to each other (gw and repeater), but neither is getting any signals from the node in question. Strangely enough, this setup had worked before I updated the sketch in this particular node...
          Have you updated boards definitions and Arduino ide?
            jjkJ
            jjkJ
            jjk
            @gohan yeah, it's all up to date - plus other node work as desired even after updating today...
              wrote on last edited by gohan
              Did you try to swap radios on the nodes? Or swap the Arduinos? Or power supplies? Just try to move things around and see if the problem follows something you moved
                jjkJ
                jjkJ
                jjk
                @gohan no, I have not et swapped hardware... That's on my to-do for the next days, but I was hoping that the problem is a known one with a more or less easy fix. If i's a bad piece of hardware, I guess I will have to got through the swapping exercise... It's just strange that the issue showed up after updating the sketch?!
                  Try downgrading the board definitions like to 1.6.11 or mysensors to 2.1.0
                    jjkJ
                    jjkJ
                    jjk
                    @gohan, hm not sure I get what you're suggesting...?! I had not changed anything before updating the sketch, so should that really make a difference? The ide and libraries are the same I have used a day or two ago to install the initial sketch - the one that worked?!
                      Oh ok, I thought more time has passed. Never mind then. Maybe could be a faulty electronics: it can happen that faulty components break after few hours or days
                      • jjkJ
                        jjkJ
                        jjk
                        o.k., quick update... contrary to what I reported yesterday, it now looks like my gateway is getting sensor readings from the node in question at irregular intervals. strangely enough, when I connect my Mac and launch the serial monitor, the sensor printout still stops after just the few lines above. Has anybody ever experienced something like this before?
                        Still need to do the hardware swapping to see if this is related to a malfunction of any of the components.
