Node-Red ESPeasy and RF24 talking each other
I am using Node-Red under RPi with some ESP8266 nodes working with ESPEasy exchanging MQTT messages.
Because there still are 5 nodes out of WIFI range, i decided to use some nRF24 with PA and LNA. I know that i could use some Extended WIFI Range devices but we must forget this option for now.I was reading Mysensors and found that ESP8266 Gateway might be a bridge between RF24 telegrams and Nodered.
Am i right or am I forgetting something? -
I found a solution to my problem. Just i had to read a little more.
Node-red is working fine with ESPEasy as firmware of ESP8266-12 over WIFI.
Then i added a Bridge using a ESP8266 Gateway.
I downloaded MySensors 2.1.0 library and built each new sketchs.
I had to learn about how to program them using examples. It was easy.
Then add node-red mysensor module to RPi and I wrote the flows. Easy too.My new system is mixing ESPEasy and RF24 with MySensors and is working under Node-Red.
