  3. ESP8266 + RFM69HW MQTT Gateway program persists
1 Posts 1 Posters 764 Views 2 Watching
  • mppM
    mppM
    mpp
    wrote on last edited by mpp
    When I press the reset button after reprogramming my Node MCU, it seems to be running the old script again. I'm seeing this behavior on 2 different NodeMCU's. What am I doing wrong here?
    My ESP Node MCU seem to behave weird:
    • install the Gateway script
    • reprogram with the Blink script => it's blinking
    • press reset
      And it seems to be running the gateway script again?
    ⸮% ⸮=c⸮⸮MCO:BGN:INIT NODE,CP=RRNNE--,VER=2.1.1
    TSM:INIT
    TSF:WUR:MS=0
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 3
    cnt
    !TSM:INIT:TSP FAIL
    TSM:FAIL:CNT=1
    connected with Airport, channel 6
    dhcp client start...
    TSM:FAIL:PDT
    After installing the ping pong script and then the mqtt gateway, I noticed the node started with a dhcp but then asked the node id (0 2) which is part of the ping pong script?
    f r-1, scandone
    .............ip:192.168.0.219,mask:255.255.255.0,gw:192.168.0.1
    .IP: 192.168.0.219
    0;255;3;0;9;MCO:BGN:STP
    IP: 192.168.0.219
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: mpp-mygateway1-out/0/255/0/0/18
    pm open,type:2 0
    => This last line seems to come from the previous ping/pong script?
    Why do I keep getting traces of previous scripts? Do I need to run the clear eeprom script every time before I program the node?
    MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
