  3. Create relay free potential free switch.
14 Posts 3 Posters 4.1k Views 3 Watching
  • R
    R
    Rene046
    wrote on last edited by Rene046
    Hi there,
    i need some help with an idea i need...
    I looking far a way to control a potential free contact to control an water lock, but without using a relay. if my water lock sees 10K on its connection it keeps it closed so no watering, if it sees 0 ohm it will have permission to water. my plants
    i was thinking to use an opto coupler but those i now need a voltage going tru on the output... or am i wrong.
    or maybe some kind of hal sensor with internal coil controlled by an arduino
      I didn't get what's the problem with the relay
      • R
        R
        Rene046
        battery powered project....
        Nca78N 1 Reply Last reply
          Transistor? Latching relay? I am just throwing ideas since I haven't fully understood your project.
          • R Rene046
            Nca78N
            Nca78N
            @Rene046 said in Create relay free potential free switch.:
            Why not just use a latching relay ?
            • R
              R
              Rene046
              because i dont want the water lock stay open after power lost.
              • R
                R
                Rene046
                Ok i explain.
                i have and Gardena Watering computer, here i want to connect a controller on battery to
                All this controller has to do via Mysensors is open or close a an switch (the 2 wires of this switch go inside the gardena computer that is looking for an 10k resistance to stop watering the plants, and an open switch 0 ohm to water the plants.
                Some distance further i have an other node that's measuring soil moisture,
                I have this now running by using normal relays, but using 2 of them (2 garden computers ) they use allot of battery power while watering so i was hoping there are some more better options.
                  If you are afraid of wasting too much water, just run a command in setup function that checks the status of latching relay and turns it off. In addition there are many arduino projects for watering plants you can look for inspiration
                  • Nca78N
                    Nca78N
                    And there are also some latching relays with 2 latches, one to switch on, one to switch off.
                    You can just switch off at the beginning of your sketch.
                    It's even possible to do that with hardware, to send a pulse to the "switch off" latch when the system is started. So even if your sketch fails to start, your relay will be off.
                    • R
                      R
                      Rene046
                      will give it a try.
                      this is the sketch i want to implement this in:
                      It will be a repeater node,
                      I would like to have 2 Relays on pins D3,D4
                      And a temperature sensor on D5 (DS1820)
                      Eventually an voltage sense pin A3
                      // Enabled repeater feature for this node
                      #define MY_REPEATER_FEATURE
                      #define MY_NODE_ID 1
                      #include <Bounce2.h>
                      #include <OneWire.h>
                      #define RELAY_PIN1  3  // Arduino Digital I/O pin number for relay
                      #define BUTTON_PIN  7  // dont need this one remove
                      #define CHILD_ID 1
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      Bounce debouncer = Bounce();
                      bool state = false;
                      bool initialValueSent = false;
                      MyMessage msg(CHILD_ID, V_STATUS);
                        // Setup the button
                        //pinMode(BUTTON_PIN, INPUT_PULLUP);
                        //debouncer.attach(BUTTON_PIN);
                        //debouncer.interval(10);
                        digitalWrite(RELAY_PIN1, RELAY_OFF);
                        pinMode(RELAY_PIN1, OUTPUT);
                        state = loadState(CHILD_ID);
                        digitalWrite(RELAY_PIN1, state?RELAY_ON:RELAY_OFF);
                      void presentation()  {
                        // Startup initialize MySensors library. Set callback for incoming messages.
                        sendSketchInfo("Lamp", "1.0");
                        present(CHILD_ID, S_BINARY);
                        if (!initialValueSent) {
                          send(msg.set(state?RELAY_ON:RELAY_OFF));
                          Serial.println("Requesting initial value from controller");
                          request(CHILD_ID, V_STATUS);
                          wait(2000, C_SET, V_STATUS);
                        if (debouncer.update()) {
                          if (debouncer.read()==LOW) {
                            state = !state;
                            send(msg.set(state?RELAY_ON:RELAY_OFF), true); // Send new state and request ack back
                        if (message.isAck()) {
                            Serial.println("Receiving initial value from controller");
                            initialValueSent = true;
                          // Change relay state
                          state = (bool)message.getInt();
                          // Store state in eeprom
                          saveState(CHILD_ID, state);
                          // Write some debug info
                          Serial.print(message.sensor);
                          Serial.println(message.getInt());
                      • R
                        R
                        Rene046
                        So far 1 relay works perfect adding a second one will be a bid harder because the sketch samples i found use more than 2 i would like to know how to add just a second one.
                        also in this sketch in need to find out hoe to remove the button function.
                        Adding the temperature sensor seems for me very hard, because i would like to call it every 5 minutes without interrupting the repeater. (No Sleep can be used).
                        if i know how to call every 5 minutes the temperature, i think i'll be able to add the also the adc code.
                        I someone could point me to some code sample i would be very happy...
                          Just use wait() instead of sleep
                          • R
                            R
                            Rene046
                            Thanks Gohan,
                            Will the repeater function keep working...... ? more like an interrupt when something is seen ?
                              The wait is specific for keeping the communications going while pausing the loop
