  3. Can't load from Codebender :-(
27 Posts 4 Posters 11.5k Views 1 Watching
  • D Offline
    Dean
    wrote on last edited by Dean
    My first go in a long while at making sensors and playing with Arduino. I have build the Ethernet Gateway, and am trying to upload the sketch using my Chrome browser and the Codebender Plugin. I Clone and edit the sketch, and it asked me if I want to use the libraries, and I say yes. I ask it to verify the code, and I get this message:
    Looks like your project uses header files or libraries that do not exist in our system, in your personal libraries or in your sketch. More info
    In file included from libraries/16221_cb_personal_lib_MySensors/Relay.cpp:12:
    In file included from libraries/16221_cb_personal_lib_MySensors/Relay.h:15:
    libraries/16221_cb_personal_lib_MySensors/Sensor.h:23:10: fatal error: 'EEPROM.h' file not found
    #include <EEPROM.h>
    1 error generated.
    Can someone tell me what the problem is?
    • D Offline
      daulagari
      wrote on last edited by daulagari
      Which browser do you use?
      See http://www.mysensors.org/build/arduino:
      Some browsers might need some extra care to get the plugin working.
      I also read:
      The code compiles on cloud server with all libraries installed and ready to use.
      So did you get the code from http://www.mysensors.org/build/ethernet_gateway ?
      • D Offline
        Dean
        I'm using Chrome on my Mac, and it should be working.
        And yes, I used the code from the link you provided.
        I'd say someone has changed the libraries.
        • hekH Offline
          hekH Offline
          I can clone and verify sketch without any problems on my mac with chrome (just tested).
          But if you want to use the Ethernet sketch with the W5100 you still have to use the download Arduino IDE and modify things in sourcecode according to instructions.
          D 1 Reply Last reply
            Dean
            Ok cool, thanks for checking this for me :-)
            I am trying to use the W5100. I am having troubles trying to understand how to follow the instructions on how to edit. Can I edit and then still use the Codebender Plugin?
            hekH 1 Reply Last reply
            • D Dean
              hekH Offline
              hekH Offline
              @Dean
              Probably easier to use the IDE and pull the libraries to your computer.
              • D Offline
                Dean
                :-( I'm hopeless..... I had this working months ago with the same parts, but it won't work. Last time I used the Codebender plugin, because it just wouldn't work on the computer. Now that I have to edit stuff, i am trying to do it on the computer, but it won't work. This is what I get:
                enabled in File > Preferences.
                Arduino: 1.0.6 (Mac OS X), Board: "Arduino Uno"
                EthernetGateway:75: error: 'MyGateway' does not name a type
                EthernetGateway:81: error: 'MAX_RECEIVE_LENGTH' was not declared in this scope
                EthernetGateway.ino: In function 'void setup()':
                EthernetGateway:87: error: 'gw' was not declared in this scope
                EthernetGateway:87: error: 'RF24_PA_LEVEL_GW' was not declared in this scope
                EthernetGateway:87: error: 'RF24_CHANNEL' was not declared in this scope
                EthernetGateway:87: error: 'RF24_DATARATE' was not declared in this scope
                EthernetGateway.ino: In function 'void loop()':
                EthernetGateway:116: error: 'MAX_RECEIVE_LENGTH' was not declared in this scope
                EthernetGateway:121: error: 'inputString' was not declared in this scope
                EthernetGateway:126: error: 'gw' was not declared in this scope
                EthernetGateway:132: error: 'inputString' was not declared in this scope
                EthernetGateway:141: error: 'gw' was not declared in this scope
                • D Offline
                  Dean
                  I just did what the output suggested. Here is what I get:
                  /Users//Desktop/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -I/Users//Desktop/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino -I/Users//Desktop/Arduino.app/Contents/Resources/Java/hardware/arduino/variants/standard -I/Users//Desktop/Arduino.app/Contents/Resources/Java/libraries/SPI -I/Users/*****/Desktop/Arduino.app/Contents/Resources/Java/libraries/Ethernet /var/folders/b6/mgvw5s257pd5pyz73nwwt4_r0000gn/T/build8097901850594856372.tmp/EthernetGateway.cpp -o /var/folders/b6/mgvw5s257pd5pyz73nwwt4_r0000gn/T/build8097901850594856372.tmp/EthernetGateway.cpp.o
                  EthernetGateway.ino:41:90: warning: DigitalIO.h: No such file or directory
                  EthernetGateway.ino:43:22: warning: MySensor.h: No such file or directory
                  EthernetGateway.ino:44:25: warning: MyGateway.h: No such file or directory
                  • D Offline
                    Dean
                    I think I have fixed it!!!
                    It tells me that it is done compiling, so I hope that means it worked!! :-)
                    • D Offline
                      Dean
                      Nope, looks like I celebrated too early....Vera can't communicate with the gateway, and I can't ping it. After uploading the sketch again I dug a little more and a find this:
                      n file included from /Users//Documents/Arduino/libraries/DigitalIO/DigitalIO.h:34,
                      from EthernetGateway.ino:35:
                      /Users/
                      /Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h: In member function 'bool SoftI2cMaster::writeScl(bool)':
                      /Users//Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:146: warning: no return statement in function returning non-void
                      /Users/
                      /Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h: In member function 'bool SoftI2cMaster::writeSda(bool)':
                      /Users/*/Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:159: warning: no return statement in function returning non-void
                      At this stage I have no idea what I need to do to fix this, but I'll look and see what I find. Fingers crossed...
                      • D Offline
                        Dean
                        Nope, can't work out what is wrong..... :-( I have no idea why I am getting this error.
                        • D Offline
                          Dean
                          OK, I am starting to feel really dumb... Many months ago I had the Ethernet Gateway working great, but I left it to pursue other stuff until now. I figure I would update stuff, but I should have left it all alone...
                          Anyways, I am tired of trying to do this on my computer and not getting anywhere, so I am trying again using Codebender. For everyones info, this is what Codebender tells me:
                          In file included from libraries/16221_cb_personal_lib_MySensors/Sensor.h:18:
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:47:3: error: unknown type name 'uint8_t'
                          uint8_t ce_pin; /< "Chip Enable" pin, activates the RX or TX role */
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:48:3: error: unknown type name 'uint8_t'
                          uint8_t csn_pin; /
                          < SPI Chip select /
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:51:3: error: unknown type name 'uint8_t'
                          uint8_t payload_size; /< Fixed size of payloads */
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:53:3: error: unknown type name 'uint64_t'
                          uint64_t pipe0_reading_address; /
                          < Last address set on pipe 0 for reading. /
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:73:8: error: unknown type name 'uint8_t'
                          RF24(uint8_t _cepin, uint8_t _cspin);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:73:24: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:139:25: error: unknown type name 'uint8_t'
                          void read( void
                          buf, uint8_t len );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:162:32: error: unknown type name 'uint8_t'
                          bool write( const void
                          buf, uint8_t len );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:182:24: error: unknown type name 'uint64_t'
                          void openWritingPipe(uint64_t address);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:208:24: error: unknown type name 'uint8_t'
                          void openReadingPipe(uint8_t number, uint64_t address);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:208:40: error: unknown type name 'uint64_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:217:26: error: unknown type name 'uint8_t'
                          void closeReadingPipe( uint8_t pipe ) ;
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:245:18: error: unknown type name 'uint8_t'
                          bool available(uint8_t* pipe_num);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:279:32: error: unknown type name 'uint8_t'
                          bool write( const void* buf, uint8_t len, const bool multicast );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:312:36: error: unknown type name 'uint8_t'
                          bool writeFast( const void* buf, uint8_t len );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:325:36: error: unknown type name 'uint8_t'
                          bool writeFast( const void* buf, uint8_t len, const bool multicast );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:355:40: error: unknown type name 'uint8_t'
                          bool writeBlocking( const void* buf, uint8_t len, uint32_t timeout );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:355:53: error: unknown type name 'uint32_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:403:19: error: unknown type name 'uint32_t'
                          bool txStandBy(uint32_t timeout);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:419:24: error: unknown type name 'uint8_t'
                          void writeAckPayload(uint8_t pipe, const void* buf, uint8_t len);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:419:55: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:485:41: error: unknown type name 'uint8_t'
                          void startFastWrite( const void* buf, uint8_t len, const bool multicast );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:511:37: error: unknown type name 'uint8_t'
                          void startWrite( const void* buf, uint8_t len, const bool multicast );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:537:3: error: unknown type name 'uint8_t'
                          uint8_t flush_tx(void);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:607:19: error: unknown type name 'uint8_t'
                          void setRetries(uint8_t delay, uint8_t count);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:607:34: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:614:19: error: unknown type name 'uint8_t'
                          void setChannel(uint8_t channel);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:628:23: error: unknown type name 'uint8_t'
                          void setPayloadSize(uint8_t size);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:637:3: error: unknown type name 'uint8_t'
                          uint8_t getPayloadSize(void);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:650:3: error: unknown type name 'uint8_t'
                          uint8_t getDynamicPayloadSize(void);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:699:20: error: unknown type name 'uint8_t'
                          void setAutoAck( uint8_t pipe, bool enable ) ;
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:712:21: error: unknown type name 'uint8_t'
                          void setPALevel ( uint8_t level );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:722:4: error: unknown type name 'uint8_t'
                          uint8_t getPALevel( void );
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:3: error: unknown type name 'uint8_t'
                          uint8_t read_register(uint8_t reg, uint8_t* buf, uint8_t len);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:25: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:38: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:52: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:810:3: error: unknown type name 'uint8_t'
                          uint8_t read_register(uint8_t reg);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:810:25: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:3: error: unknown type name 'uint8_t'
                          uint8_t write_register(uint8_t reg, const uint8_t* buf, uint8_t len);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:26: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:45: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:59: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:829:3: error: unknown type name 'uint8_t'
                          uint8_t write_register(uint8_t reg, uint8_t value);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:829:26: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:829:39: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:840:3: error: unknown type name 'uint8_t'
                          uint8_t write_payload(const void* buf, uint8_t len, const uint8_t writeType);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:840:42: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:840:61: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:851:3: error: unknown type name 'uint8_t'
                          uint8_t read_payload(void* buf, uint8_t len);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:851:35: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:858:3: error: unknown type name 'uint8_t'
                          uint8_t flush_rx(void);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:865:3: error: unknown type name 'uint8_t'
                          uint8_t get_status(void);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:874:21: error: unknown type name 'uint8_t'
                          void print_status(uint8_t status);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:883:25: error: unknown type name 'uint8_t'
                          void print_observe_tx(uint8_t value);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:896:46: error: unknown type name 'uint8_t'
                          void print_byte_register(const char* name, uint8_t reg, uint8_t qty = 1);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:896:59: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:909:49: error: unknown type name 'uint8_t'
                          void print_address_register(const char* name, uint8_t reg, uint8_t qty = 1);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:909:62: error: unknown type name 'uint8_t'
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:923:3: error: unknown type name 'uint8_t'
                          uint8_t spiTrans(uint8_t cmd);
                          libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:923:20: error: unknown type name 'uint8_t'
                          #include <EEPROM.h>
                          62 errors generated.
                          Looks to me like the issue is maybe the linked libraries aren't accessable to everyone, which is why it repports that they are missing??
                          • D Offline
                            Dean
                            This is funny..... when I posted the screenshot of the error in my first post, there was only one error; now it looks like there are 62, and I didn't change a thing... Anyone know what's going on?
                            • D Offline
                              Dean
                              OK, I think there is a fault, because I even tried to verify an old sketch that did once work, and I get the same number of errors and it tells me there are missing libraries. :-( :-(
                              • D Offline
                                Dean
                                OK I really am going mad..... still trying to get this to work, and now I am getting the same error as I did in the first post. What's going on????
                                • D Offline
                                  Dean
                                  I'm still trying.... Now I am using Firefox and the errors have gone back up to a total of 62 errors. I just tried it again with Chrome, and it too is reporting the same number of errors.
                                  • D Offline
                                    Dean
                                    Time to give up for a while. Already lost a day trying to get this to work....
                                    • D Offline
                                      Dean
                                      It's annoying me that I can't get this to work lol
                                      As a test, I tried verifying the code using Codebender for the serial gateway, and I get the same result. 62 errors.
                                      When I hover the mouse over this : #include <stdarg.h> it says "file not detected"
                                      • D Offline
                                        Dean
                                        I don't think there is any point continuing to try and sort this out using Codebender. My guess is that the libraries attached to the sketches don't match anymore or something like that, because I have tried both types of gateways, as well as a couple sensors, and I'm getting errors all the time.
                                        • D Offline
                                          Dean
                                          OK, I am trying again on my computer, and I get a lot further than using Codebender. Again, the message I am getting is this:
                                          In file included from /Users//Documents/Arduino/libraries/DigitalIO/DigitalIO.h:34,
                                          from EthernetGateway.ino:34:
                                          /Users/
                                          /Users//Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:143: warning: no return statement in function returning non-void
                                          /Users/
                                          /Users/***/Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:156: warning: no return statement in function returning non-void
                                          Can anyone point me in the right direction as to how to fix this?
