  2. Bug Reports
  3. [solved] Moteino Mega -> cannot compile 2.2.0 beta
6 Posts 4 Posters 3.2k Views 2 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    I cannot compile any sketches:
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/old/RFM69_old.h:139:67: error: 'digitalPinToInterrupt' was not declared in this scope
            uint8_t interruptNum=digitalPinToInterrupt(MY_RFM69_IRQ_PIN))
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/old/RFM69_old.h:44:76: error: 'digitalPinToInterrupt' was not declared in this scope
     #define DEFAULT_RFM69_IRQ_NUM   digitalPinToInterrupt(DEFAULT_RFM69_IRQ_PIN)  //!< DEFAULT_RFM69_IRQ_NUM
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/MyConfig.h:894:29: note: in expansion of macro 'DEFAULT_RFM69_IRQ_NUM'
     #define MY_RFM69_IRQ_NUM    DEFAULT_RFM69_IRQ_NUM
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/hal/transport/MyTransportRFM69.cpp:151:61: note: in expansion of macro 'MY_RFM69_IRQ_NUM'
     RFM69 _radio(MY_RFM69_CS_PIN, MY_RFM69_IRQ_PIN, MY_RFM69HW, MY_RFM69_IRQ_NUM);
    Using library MySensors at version 2.2.0-beta in folder: C:\Users\Alex\Documents\Arduino\libraries\MySensors
    Using library SPI at version 1.0 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI
    exit status 1
    Error compiling for board MoteinoMEGA.
    @scalz Do you know what the prolem is please?
    • alexsh1A alexsh1
      exit status 1
      @alexsh1 seems like digitalPinToInterrupt isn't defined by the Moteino Mega board. How did you install support for that board? Maybe there is an update available?
      An alternative could be to manually map the pin to interrupt number using the pinout picture at https://lowpowerlab.com/shop/product/119
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @mfalkvidd Yes, I have it installed and it does compile under 2.1.1 stable. No, there is no update for the board. It seems that it has to be defined manually for now
        tekkaT 1 Reply Last reply
        • alexsh1A alexsh1
          tekkaT
          tekkaT
          tekka
          @alexsh1 see here: https://github.com/mysensors/MySensors/issues/665
          • scalzS
            scalzS
            wrote on last edited by scalz
            it compiles ok for me. I've just tried with latest dev branch..but for the moment i have 1.6.11 avr boards
            edit: forget what i said!! i compiled for mega2560 whereas it's moteino, 1284p,.. lol
            tekka is right :+1:
            • scalzS scalz
              tekka is right :+1:
              alexsh1A
              alexsh1A
              alexsh1
              @scalz My avr is 1.6.18 (newest)
              I'll pull the latest dev and try again.
              EDIT: Thanks @tekka - I have corrected pins_arduino.h for Moteino Mega (attached)
              pins_arduino.h
