  3. Double Pir sensors
Double Pir sensors
7 Posts 2 Posters 3.2k Views 4 Watching
  • R
    R
    Rene046
    Hi there i could use some help, i tried to expand the mysensors motion sketch but i would like to use 2 pir sensors.
    I changed the sketch and get a strange message;
    #define digitalPinToInterrupt(p) ((p) == 2 ? 0 : ((p) == 3 ? 1 : NOT_AN_INTERRUPT))
    exit status 1
    redefinition of 'MyMessage msg'
    i thought nr 2 and 3 are with interrupt.
    Than i think i'll have to change:
    sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    Well maybe someone have some time to help me.
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    // Enable debug prints
    // #define MY_DEBUG
    #define MY_NODE_ID 9
    unsigned long SLEEP_TIME = 5000 ; // 120000 Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR1 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define DIGITAL_INPUT_SENSOR2 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define CHILD_ID_PIR1 21   // Id of the sensor child
    #define CHILD_ID_PIR2 22   // Id of the sensor child
    #define MY_REPEATER_FEATURE
    // Initialize motion message
    MyMessage msg(CHILD_ID_PIR1, V_TRIPPED);
    MyMessage msg(CHILD_ID_PIR2, V_TRIPPED);
    	pinMode(DIGITAL_INPUT_SENSOR1, INPUT);      // sets the motion sensor digital pin as input
      pinMode(DIGITAL_INPUT_SENSOR2, INPUT);      // sets the motion sensor digital pin as input
    	sendSketchInfo("PIR Sensor", "3.0");
    	present(CHILD_ID_PIR1, S_MOTION);
      present(CHILD_ID_PIR2, S_MOTION);
    	// Read digital motion value
    	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR1) == HIGH;
      bool tripped2 = digitalRead(DIGITAL_INPUT_SENSOR2) == HIGH;
    	Serial.println(tripped);
    	send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      Serial.println(tripped2);
      send(msg.set(tripped2?"1":"0"));  // Send tripped value to gw
    • R Rene046
      exit status 1
      // #define MY_DEBUG
      @Rene046 see https://www.mysensors.org/download/sensor_api_20#sleeping for how to use the sleep function with two interrupts.
      int8_t sleep(uint8_t interrupt1, uint8_t mode1, uint8_t interrupt2, uint8_t mode2, unsigned long ms=0);
      • R
        R
        Rene046
        thx for helping with last problem
        only problem left is with why
        is not accepted.
        // #define MY_DEBUG
        	sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR1), CHANGE, (DIGITAL_INPUT_SENSOR2), CHANGE, SLEEP_TIME);
        • R Rene046
          is not accepted.
          // #define MY_DEBUG
          @Rene046 there can't be two variables with the same name
          You can change all occurrences of the first msg to msg1 and all occurrences of the second msg to msg2
            You'll need to use digitalPinToInterrupt for sensor 2 as well (the code you posted only uses digitalPinToInterrupt for the first sensor)
            • R
              R
              Rene046
              thx.
              Aha i missed those
              sketch is accepted, waiting for second pir sensor to test in real time.
              thx again learned something new again...
              Starting to have fun with Mysensors ...
              For other users who like to try.
              // #define MY_DEBUG
              MyMessage msg1(CHILD_ID_PIR1, V_TRIPPED);
              MyMessage msg2(CHILD_ID_PIR2, V_TRIPPED);
              	send(msg1.set(tripped?"1":"0"));  // Send tripped value to gw
                send(msg2.set(tripped2?"1":"0"));  // Send tripped value to gw
              • R Rene046
                thx.
                Aha i missed those
                // #define MY_DEBUG
                Great work @Rene046! Thanks for sharing your finished sketch.
