  3. nRF5 action!
nRF5 action!
  • mtiutiuM
    mtiutiuM
    mtiutiu
    For measuring small currents I'm using Texas Instruments EnergyTrace piece of technology and it works pretty well. You just need one of their development boards with energytrace special microcontroller embedded which is very cheap. More infos here: http://43oh.com/2015/09/how-to-measure-an-energia-applications-power-usage-with-energytrace/
    It can be used to measure other boards power usage also - you just need to take of some jumpers and plug in your external board.
    It gives you real time energy measurements and with plotting too(and battery life estimation is displayed real time too). No need to worry about burden voltage and other external factors which affect the measurements.
    NeverDieN 1 Reply Last reply
    • mtiutiuM mtiutiu
      NeverDieN
      NeverDieN
      @mtiutiu
      I think maybe the nRF52 DK also has some energy measurement capability, but I haven't looked into it.
      T 1 Reply Last reply
      • NeverDieN NeverDie
        @mtiutiu
        Toyman
        @NeverDie
        https://devzone.nordicsemi.com/tutorials/28/
        • NeverDieN
          NeverDieN
          #584
          Looks like I was wrong earlier about the voltage reference being Vcc when doing an analog read on a pin. Instead, it seems to be a fixed reference. In any case, I'm getting better results with an expression like this, which is independent of Vcc:
          millivolts = (analogRead(PIN)*3000/4095)
          What are others here doing in this case?
          rmtuckerR 1 Reply Last reply
            rmtuckerR
            rmtuckerR
            rmtucker
            @NeverDie
            As mentioned earlier by someone the nrf52 is preset to 0.6v internal ref and a 1/5 divider so 0 - 3v is the max input so your calculation is correct.
            The nrf51 is different because the ref can be set to a few different settings but the default is vdd.
            • rmtuckerR
              rmtuckerR
              rmtucker
              Is RSSI reporting implemented in the NRF5 setup yet?
              If so how is it done?
              • scalzS
                scalzS
                I don't think sendSignalStrength function is implemented yet, but you should be able to get this info with:
                int16_t transportGetSendingRSSI(void)
                int16_t transportGetReceivingRSSI(void)
                rmtuckerR 2 Replies Last reply
                • T
                  Toyman
                  How can I redefine UART pins in nrf51822? For example, if I want to have p13 as uart tx?
                  scalzS 1 Reply Last reply
                  • T Toyman
                    scalzS
                    scalzS
                    @Toyman
                    it has been explained above in the topic ;)
                    you have to follow
                    • https://github.com/mysensors/ArduinoBoards
                    • https://github.com/mysensors/ArduinoHwNRF5
                    • scalzS scalz
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      @scalz
                      Rssi works really well.
                      Thank you.
                      • rmtuckerR rmtucker
                        @scalz
                        Thank you.
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        So range test.
                        Using esp8266 with standard nrf24 not amplified gateway at one end of the house.
                        Nrf51822 node in garage which is not fastened to house so at a guess 15m through 3 brick walls is reporting -86db.
                        I think that is quite respectable.;-)
                        • scalzS scalz
                          @Toyman
                          you have to follow
                          Toyman
                          @scalz thx.
                          • O
                            O
                            Omemanti
                            Regarding the PCB/KiCad comments.
                            I was trying out KiCad and copied the NRF52832 DC/DC schematic from the datasheet.
                            It might be of help for someone.
                            https://github.com/Omemanti/KiCAD/tree/master/NRF52832
                            PS. been at KiCad for a couple of hours, been used to Eagle, so please double check.
                              @NeverDie
                              NeverDieN
                              NeverDieN
                              #594
                              @rmtucker said in nRF5 Bluetooth action!:
                              @NeverDie
                              I've lately found that I seem to get a more accurate measurement if I multiply by 3131 instead of 3000. Just an empirical result with no real theory behind it.
                                I don't know if it is actually related, but I'll post the link to this programmer :)
                                adafruit.com/product/3571
                                Nca78N 1 Reply Last reply
                                • NeverDieN
                                  NeverDieN
                                  #596
                                  What's going to be the best way to reduce the sleep current and Tx current on the nRF52? Since I'm feeding off a supercap for power, it's noticeably worse (by an order of magnitude) on the same task than the atmega328p+rfm69 combo. I've already increased the datarate to 2mbps, and it's inherently lower Tx current should give it a natural advantage.
                                  I guess I'll try reducing Tx power and see if that makes much of a dent....
                                  I suppose reducing 3 separate packets to one single packet, and maybe turning off ACK requests might also help. Then, maybe all of the LONG_WAIT's can be eliminated. Is the radio still awake even if the CPU is sleeping during a "wait" period? If so, that might be a large chunk of the wasted power.
                                  I wonder if the mysensors mesh networking (which I don't intend to use) might be getting in the way, and possibly keeping it awake longer than it otherwise would be? Can I disable the mysensors meshnetworking just to be sure?
                                  Sorry for the shotgun blast of questions, but I'm trying to get a sense of what will yield the highest payoff.
                                  • NeverDieN
                                    NeverDieN
                                    #597
                                    Since I'll be reducing Tx power in an attempt to reduce current consumption, I'll be using a scanner program to try to find empty channels. The only one I know of is: https://github.com/nRF24/RF24/tree/master/examples/scanner
                                    for the nRF24L01, but it seems to work well enough if you let it run awhile. Anyone else using one that they like?
                                      NeverDieN
                                      NeverDieN
                                      #598
                                      Nevermind. I see now that there's an entire entry on it:
                                      https://forum.mysensors.org/topic/2454/node-cant-see-gateway-less-than-10m-away/11
                                        Nca78N
                                        Nca78N
                                        @gohan said in nRF5 Bluetooth action!:
                                        Not sure it's even legal to use this if you ever plan to sell PCBs on openhardware.io ...
                                        You may use the J-Link EDU for non profit educational purposes only! Non-profit educational purposes means that you >may not use the J-Link EDU and its J-Link software.
                                        • direct or indirect in or for a profit organization or business purposes or other undertaking intended for profit
                                        • direct or indirect in any other commercial environment (e.g. office)
                                        • to develop, debug, program or manufacturer a commercial product (or parts thereof)
                                        • to use it to either earn money or reasonably anticipate the receipt of monetary gain from it.
                                        gohanG 1 Reply Last reply
                                        • Nca78N Nca78
                                          wrote on last edited by gohan
                                          #600
                                          @Nca78 Educational versions of many things can not be used for commercial purposes, maybe they got an agreement as it will be sold primarily to hobbyists.
