  3. [Solved] MySensors WiFi Gateway with NODE-MCU ESP8266 and Capacitive Soil Moisture Sensor : first steps, first errors
5 Posts 2 Posters 2.8k Views 2 Watching
  • N Offline
    N Offline
    Neo Mod
    wrote on last edited by Neo Mod
    Hi everyone,
    here I am (again, sorry :-p ) asking for your guidance.
    After my initial post about “general ideas” with MySensors and I moved on to the next phase: buying all the components.
    I bought two things to start familiarize with this project:
    • A NODE-MCU ESP8266 Development Board vers. 1.0 T
    • A Capacitive Soil Moisture Sensor by DFROBOT V. 1.0
    The idea is to use the NODE-MCU ESP8266 as a WiFi Gateway to collect data from sensor and send it to a controller.
    I divided the project in various stages so to easily troubleshoot problems:
    1st stage: Setting up the NODE-MCU with Capacitive Sensor and reading data
    2nd stage: Setting up the MySensors Wi-Fi Gateway on the NODE-MCU and obtaining “calibrated” data from sensor
    3rd stage: Acquiring the data from stage 2 remotely.
    Thanks to all the guides and tutorial here I’ve been able to set-up my Arduino IDE software with the library to use the NODE-MCU ESP8266 board.
    Following the DFROBOT product tutorial I’ve been able to obtain RAW data from the sensor with this sketch:
      // put your setup code here, to run once:
    Serial.begin(9600); // open serial port, set the baud rate as 9600 bps
      // put your main code here, to run repeatedly:
      int val;
      val = analogRead(0); //connect sensor to Analog 0
      Serial.print(val); //print the value to serial port
      delay(1000);
    Now the problem, for me that I’m a total novice to this, is how to set-up the gateway for doing the same thing.
    I tried with this sketch, also including the calibration needed to obtain usable values from the sensor but I only come up with an error that I could not understand.
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "mywifissid"
    #define MY_ESP8266_PASSWORD "mywifipassword"
    // Enable UDP communication
    #define MY_USE_UDP
    #define MY_ESP8266_HOSTNAME "sensor-gateway"
    #define MY_IP_ADDRESS 192,168,0,200
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 75
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    ///#define MY_INCLUSION_MODE_DURATION 60
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    #define CHILD_ID 0
    // values needed for calibrating the sensor output
    int AirValue = 694;
    int WaterValue = 344;
    int intervals = (AirValue - WaterValue)/3;
    int soilMoistureValue = 0;
    MyMessage msg(CHILD_ID, V_LEVEL);
    unsigned long SLEEP_TIME = 30000;
    int sensorPin = A0;
      present(CHILD_ID, S_MOISTURE);
    int soilMoistureValue;
    soilMoistureValue = analogRead(sensorPin);
    if(soilMoistureValue > WaterValue && soilMoistureValue < (WaterValue + intervals))
      send(msg.set("Very WET"));
    else if(soilMoistureValue > (WaterValue + intervals) && soilMoistureValue < (AirValue - intervals))
      send(msg.set("Wet"));
    else if(soilMoistureValue < AirValue && soilMoistureValue > (AirValue - intervals))
        send(msg.set("Dry"));;
    sleep(SLEEP_TIME);
    When compiling this code using the MySensors Library v. 2.1.1 ,I receive an error code: I'm sure it's because I'm doing something wrong out of inexperience so I hope if someone among the most experienced users here could help me out...
    • N Neo Mod
      Hi everyone,
        int val;
        delay(1000);
      #define MY_USE_UDP
      #define CHILD_ID 0
      int AirValue = 694;
      int sensorPin = A0;
      sleep(SLEEP_TIME);
      @Neo-Mod posting the actual error could be very useful ;-)
      N 1 Reply Last reply
      • mfalkviddM Offline
        Was the error
        error: no match for 'operator[]' (operand types are 'inputBuffer' and 'int')
        in that case, my google-fu took me to https://github.com/mysensors/MySensors/issues/369 which has been fixed in 2.2.0-beta.
        Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Micke\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
        Using library MySensors at version 2.2.0-beta in folder: R:\Documents\Arduino\libraries\MySensors
        Using library EEPROM at version 1.0 in folder: C:\Users\Micke\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM
        Sketch uses 236,893 bytes (22%) of program storage space. Maximum is 1,044,464 bytes.
        Global variables use 32,944 bytes (40%) of dynamic memory, leaving 48,976 bytes for local variables. Maximum is 81,920 bytes.
        So either use 2.2.0-beta or wait for the next stable release.
        • N Offline
          N Offline
          Neo Mod
          Oh my...sorry, my mistake! I forgot to paste it on the message, thank you for your patience.
          Here it is the error: there are some small parts in italian at the end regarding the WiFi Library used. If needed I can translate those.
          Arduino:1.8.3 (Windows 10), Scheda:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, 9600, 4M (3M SPIFFS)"
          In file included from D:\NeoMod\Documents\Arduino\libraries\MySensors/MySensors.h:200:0,
                           from D:\NeoMod\Documents\Arduino\prova_gateway\prova_gateway.ino:135:
          D:\NeoMod\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportAvailable()':
          D:\NeoMod\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:302:35: error: no match for 'operator[]' (operand types are 'inputBuffer' and 'int')
             _ethernetServer.read(inputString[0].string, MY_GATEWAY_MAX_RECEIVE_LENGTH);
          D:\NeoMod\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:303:14: error: no match for 'operator[]' (operand types are 'inputBuffer' and 'int')
             inputString[0].string[packet_size] = 0;
          In file included from D:\NeoMod\Documents\Arduino\libraries\MySensors/MySensors.h:28:0,
          D:\NeoMod\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:304:55: error: no match for 'operator[]' (operand types are 'inputBuffer' and 'int')
             debug(PSTR("UDP packet received: %s\n"), inputString[0].string);
          D:\NeoMod\Documents\Arduino\libraries\MySensors/core/MySensorsCore.h:90:40: note: in definition of macro 'debug'
           #define debug(x,...) hwDebugPrint(x, ##__VA_ARGS__)   //!< debug, to be removed (follow-up PR)
          D:\NeoMod\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:305:58: error: no match for 'operator[]' (operand types are 'inputBuffer' and 'int')
             const bool ok = protocolParse(_ethernetMsg, inputString[0].string);
          Più di una libreria trovata per "WiFiUdp.h"
          Usata: C:\Users\deimo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
          Non usata: C:\Program Files (x86)\Arduino\libraries\WiFi
          exit status 1
          Errore durante la compilazione per la scheda NodeMCU 1.0 (ESP-12E Module).
            N Offline
            N Offline
            Neo Mod
            @mfalkvidd thank you! I didn't noticed that among the whole log, my ignorance about this just kicked-in. Thank you again fo your help, I'll read on how to set the beta library and compile again.
            12.2k
