  3. [RESOLVED] Problems connecting node to gateway
9 Posts 4 Posters 3.0k Views 3 Watching
  • firstof9F
    firstof9F
    firstof9
    wrote on last edited by firstof9
    Greetings,
    After much searching in the forums and google I've been unable to resolve the issue on my own. Any assistance is welcomed.
    My gateway is a Ardunio Uno with an Ethernet Shield and a RFM69HCW radio set to 915Mhz
    My node is an Arudino Nano and a RFM69HCW radio set to 915Mhz (currently no sensors connected for troubleshooting)
    I am using an Adafruit breakout board that has a level shifter build in.
    Below are the outputs of the node and gw:
    GW Debug:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.1.204
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: 0;255;3;0;2;
    0;255;3;0;9;Eth: 255;255;3;0;20;
    0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Node Debug:
    0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
    3 TSM:INIT
    4 TSF:WUR:MS=0
    6 TSM:INIT:TSP OK
    8 TSM:INIT:STATID=1
    10 TSF:SID:OK,ID=1
    11 TSM:FPAR
    142 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2149 !TSM:FPAR:NO REPLY
    2151 TSM:FPAR
    2281 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4288 !TSM:FPAR:NO REPLY
    4290 TSM:FPAR
    4420 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6427 !TSM:FPAR:NO REPLY
    6429 TSM:FPAR
    6559 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8566 !TSM:FPAR:FAIL
    8567 TSM:FAIL:CNT=1
    8569 TSM:FAIL:PDT
    GW Sketch:
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
    #define MY_RFM69_FREQUENCY RF69_915MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
    #define MY_RF69_SPI_CS 4
    #define MY_RF69_IRQ_PIN 2
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,204   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 5  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  7  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    Node sketch:
    // Enable debug prints
    #define MY_SPECIAL_DEBUG
    #define MY_NODE_ID 1
    #define MY_RF69_SPI_CS 10
    #define MY_RF69_IRQ_PIN 3
    #define MY_RF69_IRQ_NUM 1
    #define MY_DEFAULT_TX_LED_PIN 13
    #include <DHT.h>
    #define DHTPIN 4
    #define DHTTYPE DHT22
    #define SENSOR_TEMP_OFFSET 0
    // static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    // Motion Detection
    #define CHILD_ID_PIR 2   // Id of the sensor child
    // Initialize motion message
    MyMessage msg(CHILD_ID_PIR, V_TRIPPED);
    // DHT22 Stuff
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = false;
    DHT dht(DHTPIN, DHTTYPE);
    // LUX Sensor
    #define LIGHT_SENSOR_ANALOG_PIN 3
    #define CHILD_ID_LIGHT 3
    int lastLightLevel;
      sendSketchInfo("MultiSensor", "0.1");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_PIR, S_MOTION);
      //metric = getControllerConfig().isMetric;
      Serial.println("Setting up...");
    //  dht.setup(DHT_DATA_PIN); // set data pin of DHT sensor
      if (SLEEP_TIME <= 2000) {
      sleep(2000);
      // LUX Stuff
      int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
      //dht.readSensor(true);
      float temperature = dht.readTemperature();
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
          temperature = dht.readTemperature(true);
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      float humidity = dht.readHumidity();
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      // Read digital motion value
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    I have them both currently powered via my computer's USB. I tested with a simple sketch and I was able to get them to communicate "Hello world!" packets.
    Anyone have any thoughts?
    Thank you.
    • scalzS
      scalzS
      wrote on last edited by scalz
      you may need to set Reset state of RFM69, during initialization.
      here it is:
      https://forum.mysensors.org/topic/5954/rfm69-not-initialising-required-reset-could-be-the-cause/5
      https://forum.mysensors.org/topic/5806/solved-adafruit-rfm69hcw-breakout-doesnt-respond/20
      • firstof9F
        firstof9F
        firstof9
        The radios seem to initialize fine according to the logs. Any other ideas?
        • firstof9F firstof9
          @firstof9 - a resource i found good, if you didnt know: https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide
          • firstof9F
            firstof9F
            firstof9
            The radios are connected correctly, the issue appears to be related to this:
              See if adding
              before including MySensors.h gives any useful clues.
              • firstof9F
                firstof9F
                firstof9
                Nothing new is being reported on the serial monitor. :(
                IP: 192.168.1.204
                • firstof9F
                  firstof9F
                  firstof9
                  Got it working it was this bit causing issues:
                  removing that fixed it
                  Also as my gateway was having issues freaking out when receving radio packets I also modified my ethernet.h per this post:
                  https://forum.mysensors.org/topic/5109/solved-rfm69-based-nodes-unable-to-report-lib-version/26
                  and changed the following:
                  #define MY_DEFAULT_ERR_LED_PIN A0  // Error led pin
                  #define MY_DEFAULT_RX_LED_PIN  A1  // Receive led pin
                  #define MY_DEFAULT_TX_LED_PIN  A2  // Transmit led pin
                  Thank you all for your suggestions.
                    @firstof9 great work! Thanks for reporting back on your solution.
