  3. Help to Build a Sensor with Arduino Pro 3V
5 Posts 2 Posters 1.6k Views 2 Watching
  • S
    sindrome73
    Hello!!
    I tried to build a first battery sensor with an Arduino Pro Mini 3V but feeding it with 2 1.5V batteries the sensor will not work !!
    But do I need to use a Step Up Boost Module or do I just follow the directions on this page ???
    link text
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      depends on the sensors, some works with 3v some does not and they require boost converter. You will find everything in sensor datasheet.
      • S
        sindrome73
        No firm !! What does not work and Arduino Pro Mini at 3V.
        Do not start with two 1.5V batteries.
        To work it requires at least 3.3V
        How do I do it to make it work with two 3v batteries?
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          wrote on last edited by rozpruwacz
          arduino should work with 3v without any modifications, something other must be wrong.
          • S
            sindrome73
            Discovered the problem !! I fed through the "RAW" pin while feeding through the VCC
            Ok is now working
