  3. Help with sleeping door sensor
5 Posts 3 Posters 1.8k Views 3 Watching
  • U Offline
    U Offline
    ustredna
    wrote on last edited by ustredna
    Hi friend i need help with my code of sleeping door sensor.
    i need add sending actual status of digital input and battery level and send this info each 7 seconds to GW.
    uint8_t NodeID = 88;
    #define MY_NODE_ID NodeID
    #define MY_PARENT_NODE_ID 0
    uint8_t RF24_Channel = 30;
    #define MY_RF24_CHANNEL RF24_Channel
    #define LED_PIN 17
    #define PRIMARY_BUTTON_PIN 3   // Arduino Digital I/O pin for button/reed switch
    #define SECONDARY_BUTTON_PIN 2 // Arduino Digital I/O pin for button/reed switch
    unsigned long SLEEP_TIME = 7000; // Sleep time between tX
    #define SKETCH_NAME "Door RF Sensor"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "1"
    #define PRIMARY_CHILD_ID 1
    #define SECONDARY_CHILD_ID 2
    MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
    MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
    void before () {
      // Setup the buttons
      pinMode(PRIMARY_BUTTON_PIN, INPUT);
      pinMode(SECONDARY_BUTTON_PIN, INPUT);
      // Activate internal pull-ups
      digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
      digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
      pinMode(LED_PIN, OUTPUT);
    	sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
    	present(PRIMARY_CHILD_ID, S_DOOR);
    	present(SECONDARY_CHILD_ID, S_DOOR);
    	uint8_t value;
    	static uint8_t sentValue=2;
    	static uint8_t sentValue2=2;
    	sleep(5);
    	value = digitalRead(PRIMARY_BUTTON_PIN);
    	if (value != sentValue) {
    		// Value has changed from last transmission, send the updated value
    		digitalWrite(LED_PIN, HIGH);
        delay (5);
    		send(msg.set(value==HIGH));
        digitalWrite(LED_PIN, LOW);
    		sentValue = value;
    	value = digitalRead(SECONDARY_BUTTON_PIN);
    	if (value != sentValue2) {
        delay (5);
    		send(msg2.set(value==HIGH));
    		sentValue2 = value;
    	// Sleep until something happens with the sensor
    	sleep(PRIMARY_BUTTON_PIN-2, CHANGE,SECONDARY_BUTTON_PIN-2, CHANGE, 7000);
    how make it...???
    also interrupt must working correctly.
    please help me with my code.
    tnx
    Peter
      Are you having problems with the code?
      Is there a reason why you don't use
      #define MY_NODE_ID 88
      • U Offline
        U Offline
        ustredna
        In my specific application i use one GW as receiver and one node with Static NODE ID as transmitter.
          that didn't answer much my questions, as that is the common setup for Mysensors network. :)
          • R Offline
            R Offline
            rvendrame
            @ustredna , try changing this line:
            by
            send(msg.set(value));
            The same for msg2 line:
            to
            send(msg2.set(value));
            And if you only need to update the GW on every 7 seconds (and not immediately), change the sleep:
            sleep( 7000 ) ;
            Hope it helps!
            ESP8266 GW + mySensors 2.3.2
            Alexa / Google Home
