  3. BME 280 how to use it?
6 Posts 4 Posters 5.9k Views 4 Watching
  • W
    W
    wardur
    I bought a BME 280 and don´t know how to wire it, because the sensor is different to the normal ones.
    mfalkviddM YveauxY 2 Replies Last reply
    • W wardur
      @wardur looks to be the same as https://learn.adafruit.com/adafruit-bme280-humidity-barometric-pressure-temperature-sensor-breakout/pinouts I think?
      For i2c, you only connect Vcc, Gnd, Scl and Sda.
      • W
        W
        wardur
        wrote on last edited by gohan
          This is a library for the BME280 humidity, temperature & pressure sensor
          Designed specifically to work with the BME280 Breakout board
          ----> http://www.adafruit.com/products/2650
          This sketch only supports the I2C bus for connection.
        #include <Wire.h>
        #include "cactus_io_BME280_I2C.h"
        // Create the BME280 object
        BME280_I2C bme;
        // I2C using default 0x77
        // or
        //BME280_I2C bme(0x76);  // I2C using address 0x76
          Serial.begin(9600);
          Serial.println("Bosch BME280 Barometric Pressure - Humidity - Temp Sensor | cactus.io");
          if (!bme.begin()&&!bmee.begin()) {
            Serial.println("Could not find a valid BME280 sensor, check wiring!");
            while (1);
          bme.setTempCal(-1);
          Serial.println("Pressure\tHumdity\t\tTemp\t\tTemp");
            bme.readSensor();
            Serial.print(bme.getPressure_MB()); Serial.print("\t\t");    // Pressure in millibars
            Serial.print(bme.getHumidity()); Serial.print("\t\t");
            Serial.print(bme.getTemperature_C()); Serial.print(" *C\t");
            Serial.print(bme.getTemperature_F()); Serial.println(" *F\t");
            // add a 2 second delay to slow down the output
            delay(2000);
        i use this code and he can´t find a device:/
        gohanG 1 Reply Last reply
          Try to run an I2C scanner, it could be the sensor has a different address
          • W wardur
            YveauxY
            YveauxY
            @wardur make sure you power it at the correct level (see the breakout's specs) and use the same power level in communication to the arduino. Either use the same level for bme and arduino, or use a level shifter.
            • W wardur
              #include <Wire.h>
              BME280_I2C bme;
              // or
                Serial.begin(9600);
                  while (1);
                bme.setTempCal(-1);
                  bme.readSensor();
                  delay(2000);
              @wardur this is my stripped down code I use to read data from the BME280
              Adafruit_BME280 bme; // I2C
              uint8_t BME280_i2caddr = 0x76;
              MyMessage msgPress(CHILD_ID_BARO, V_PRESSURE);
              	Serial.begin(MY_BAUD_RATE);
              	metric = getControllerConfig().isMetric;  // was getConfig().isMetric; before MySensors v2.1.1
              	Wire.begin(); // Wire.begin(sda, scl)
              	if (!bme.begin(BME280_i2caddr)) {
              		while (1);
              	// weather monitoring
              	Serial.println("-- Weather Station Scenario --");
              	Serial.println("forced mode, 1x temperature / 1x humidity / 1x pressure oversampling,");
              	Serial.println("filter off");
              	bme.setSampling(Adafruit_BME280::MODE_FORCED,
              		Adafruit_BME280::SAMPLING_X1, // temperature
              		Adafruit_BME280::SAMPLING_X1, // pressure
              		Adafruit_BME280::SAMPLING_X1, // humidity
              		Adafruit_BME280::FILTER_OFF,
              		Adafruit_BME280::STANDBY_MS_1000);
              	// suggested rate is 1/60Hz (1m)
              	bme.takeForcedMeasurement();
              	float HUM = bme.readHumidity();
              	float TEMP = bme.readTemperature();
              	float BARO = bme.readPressure() / 100;
              	send(msgHum.set(HUM, 2));
              	send(msgTemp.set(TEMP, 2));
              	send(msgPress.set(BARO, 1));
