  3. Mysensors si7021 sketch
11 Posts 5 Posters 3.9k Views 4 Watching
  • T
    Tommas
    Dear All!
    Has anybody a sketch for this temperature and humidity sensor? I would like to use it with mini pro combined easypcb board.
    Thank you in advance!
    • T Tommas
      Dear All!
      @Tommas - some resources i found.
      https://forum.mysensors.org/topic/2432/si7021-multisensor-first-try
      https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/SI7021
      https://forum.mysensors.org/topic/6434/solved-problems-with-an-si7021-temp-humidity-sensor/3
      T 2 Replies Last reply
      • sundberg84S sundberg84
        Tommas
        Dear @sundberg84
        Thanks for the suggestions!
        Another, which pin should i connect to the si7021? I cant find this info...
        Thanks,
        • T Tommas
          Dear @sundberg84
          Thanks,
          @Tommas the si7021 uses i2c so you can use the wiring described at https://www.mysensors.org/build/light-bh1750 which also is an i2c device.
          T 1 Reply Last reply
            Tommas
            wrote on last edited by Tommas
            Dear @mfalkvidd !
            Thank you, and to everyone for the help!
            I got it work!
            If the sketch will be completed i will upload that!
              Tommas
              @sundberg84
              What is the problem with my sketch? It is in developement phase, but the reading stops at this line, but sometimes it works for 3-4 loop...
              " DEBUG_PRINTLN("Send TEMP and HUM started"); "
               * Version 1.0: Henrik EKblad
              #define MY_NODE_ID 4
              // Enable debug prints
              //#define MY_RS485
              /* Sketch with Si7021 and battery monitoring.
              by m26872, 20151109
              #include <Wire.h>
              #include <SI7021.h>
              #include <RunningAverage.h>
              #define DEBUG
              #ifdef DEBUG
              #define DEBUG_SERIAL(x) Serial.begin(x)
              #define DEBUG_PRINT(x) Serial.print(x)
              #else
              #define NODE_ID 4             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
              #define CHILD_ID_TEMP 0
              #define CHILD_ID_HUM 1
              //#define SLEEP_TIME 15000 // 15s for DEBUG
              #define SLEEP_TIME 10000   // 5 min
              //#define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
              #define FORCE_TRANSMIT_CYCLE 1  // 5min*12=1/hour, 5min*36=1/3hour
              //#define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
              //#define VMIN 1900
              //#define VMAX 3300
              #define HUMI_TRANSMIT_THRESHOLD 3.0  // THRESHOLD tells how much the value should have changed since last time it was transmitted.
              #define TEMP_TRANSMIT_THRESHOLD 0.5
              #define AVERAGES 2
              //int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
              int measureCount = 0;
              float lastTemperature = -100;
              int lastHumidity = -100;
              RunningAverage raHum(AVERAGES);
              SI7021 humiditySensor;
              //MySensor gw;
              MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP); // Initialize temperature message
              MyMessage msgHum(CHILD_ID_HUM,V_HUM);
              void presentation(){
              sendSketchInfo("Node 4, Temp,Hum sensor", "1.1");
                present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
                present(CHILD_ID_HUM, S_HUM);
                DEBUG_SERIAL(115200);
                DEBUG_PRINTLN("Serial started");
                //DEBUG_PRINT("Voltage: ");
                //DEBUG_PRINT(readVcc());
                //DEBUG_PRINTLN(" mV");
                delay(500);
                DEBUG_PRINT("Internal temp: ");
                DEBUG_PRINT(GetInternalTemp()); // Probably not calibrated. Just to print something.
                DEBUG_PRINTLN(" *C");
                delay(500); // Allow time for radio if power useed as reset
                //begin(NULL,NODE_ID);
                //DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
                raHum.clear();
                DEBUG_PRINTLN("Loop started");
                measureCount ++;
                bool forceTransmit = true;
                //if (measureCount > FORCE_TRANSMIT_CYCLE) {
                //forceTransmit = true;
                sleep(SLEEP_TIME);
                DEBUG_PRINTLN("Loop ended");
               * * Sends temperature and humidity from Si7021 sensor
               * Parameters
               * - force : Forces transmission of a value (even if it's the same as previous measurement)
              void sendTempHumidityMeasurements(bool force) {
                bool tx = force;
                si7021_env data = humiditySensor.getHumidityAndTemperature();
                float temperature = data.celsiusHundredths / 100.0;
                DEBUG_PRINT("T: ");DEBUG_PRINTLN(temperature);
                float diffTemp = abs(lastTemperature - temperature);
                DEBUG_PRINT(F("TempDiff :"));DEBUG_PRINTLN(diffTemp);
                //if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                //lastTemperature = temperature;
                //measureCount = 0;
                DEBUG_PRINTLN("T sent!");
                int humidity = data.humidityPercent;
                DEBUG_PRINT("H: ");DEBUG_PRINTLN(humidity);
                raHum.addValue(humidity);
                humidity = raHum.getAverage();  // MA sample imply reasonable fast sample frequency
                float diffHum = abs(lastHumidity - humidity);
                DEBUG_PRINT(F("HumDiff  :"));DEBUG_PRINTLN(diffHum);
                //if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                //lastHumidity = humidity;
                //measureCount = 0;
                DEBUG_PRINTLN("H sent!");
              • T Tommas
                @sundberg84
                //#define MY_RS485
                by m26872, 20151109
                #include <Wire.h>
                #include <SI7021.h>
                #define DEBUG
                #ifdef DEBUG
                #else
                //#define VMIN 1900
                //#define VMAX 3300
                #define AVERAGES 2
                //MySensor gw;
                  delay(500);
                  raHum.clear();
                  measureCount ++;
                  sleep(SLEEP_TIME);
                 * Parameters
                  bool tx = force;
                  //measureCount = 0;
                  //measureCount = 0;
                @Tommas - sorry, im not the code expert...
                If it stops without any indication why it can be a power issue as well.
                  Tommas
                  @sundberg84
                  There arent any indication. Sometimes it works.... i tried another si7021 and same. Voltage is Ok. A connected the sda - A4 scl - A5 on easypcb board
                  Any idea?
                  YveauxY 1 Reply Last reply
                  • T Tommas
                    @sundberg84
                    Any idea?
                    YveauxY
                    YveauxY
                    @Tommas do you have pullups (around 10k) at sda & scl lines?
                    • YveauxY Yveaux
                      Tommas
                      Dear @Yveaux
                      I think that yes. The si7021 module has an smd 103 part on it. Maybe it is at the sda and scl but im not sure.
                      https://www.ebay.com/i/401364416322
                      • Nca78N
                        Nca78N
                        you are missing the sensor.begin() to initialize the sensor. Return value will tell you if initialization succeeded or not.
                        if (!sensor.begin()) {
                        #ifdef MY_DEBUG
                            Serial.println("FAILED TO INIT SENSOR !!!!");
