  3. Mysensor gateway node is not connecting to Domoticz
5 Posts 2 Posters 2.2k Views 2 Watching
  • M Offline
    M Offline
    Mister_ik
    I changed to new router from my internet provider (Ziggo). After adding all my fixed IP-adresses i have problems with mySensors gateway. It will not connect to Domoticz. I am now lost i tried a lot of things...but i don't understand why it is not connecting.
    My setup is:
    • Domoticz v3.8394 on RPI
    • Mysensor node : ESP Easy NodeMCU (uploaded with https://www.letscontrolit.com/wiki/index.php/Tutorial_ESPEasy_Firmware_Upload)
    My log is saying:
    2017-09-15 23:21:27.287 New sensors allowed for 5 minutes...
    2017-09-15 23:21:28.954 TCP: Reconnecting...
    2017-09-15 23:21:29.955 Error: MySensors: Can not connect to: 192.168.1.113:5003
    2017-09-15 23:21:29.955 TCP: Connection problem (Unable to connect to specified IP/Port)
    2017-09-15 23:21:29.955 TCP: Reconnecting in 30 seconds...
    From pi RPI i can ping the mysensor IP
    pi@raspberrypi:~$ ping 192.168.1.113
    PING 192.168.1.113 (192.168.1.113) 56(84) bytes of data.
    64 bytes from 192.168.1.113: icmp_seq=1 ttl=128 time=9.43 ms
    64 bytes from 192.168.1.113: icmp_seq=2 ttl=128 time=9.56 ms
    64 bytes from 192.168.1.113: icmp_seq=3 ttl=128 time=10.0 ms
    64 bytes from 192.168.1.113: icmp_seq=4 ttl=128 time=10.6 ms
    I can connect with browser to mysensor node:
    The following things i checked:
    • all components are on the same IP-range
    • in the settings page i set the 'local notwork'
    • I built a new node but this new node gives the same problem.
    • ect.
    Anyone have a clue? Thanks in advance.
    • mfalkviddM Offline
      What does the debug output of the gateway say?
      • M Offline
        M Offline
        Mister_ik
        This is what the log says: (i rebooted to show you a clear log, otherwise only the uptime messages are shown)
        • M Mister_ik
          @Mister_ik looks like you're not running any MySensors code?
          M 1 Reply Last reply
            M Offline
            M Offline
            Mister_ik
            @mfalkvidd Thank you.....if forgot to upload the gateway software. I thought flashing the NodeMCU was enough. And of-coarse i had to update in the gateway software also the router information. That was the step i forgot :-(
