  3. radio failure ?
radio failure ?
4 Posts 2 Posters 1.6k Views 2 Watching
  • epierreE
    epierreE
    epierre
    wrote on last edited by epierre
    I am trying to get my sensors back, and I have one that goes off the road several time...
    board is a uno, with long antennae, mysensors lib is 1.5.
    send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.1
    sometime resetting the uno button is enough, other not, and unpowering several times is the only way to make it work. BTW is is less than 1m from the controller.
    sometimes, it goes well for 2h, then I have a 'fin parent' message on console and hten everything fail after.
    any idea ?
    z-wave - Vera -> Domoticz
      did you try swapping hardware? upgrading library since 2.2 is almost out?
      • epierreE
        epierreE
        epierre
        @gohan I would have too much work going to 2.0 on every node I have, but I have to do this as a background task since I'll have to upgrade all my sketches first...
        swapping hardware is an option, recabling everything is not my cup of tea ;-)
          you could setup a secondary gateway with lib 2.2 and do a node by node upgrade :)
