  3. C Definition in sketch to configure library
6 Posts 2 Posters 1.7k Views 2 Watching
  • Robinek70R
    Robinek70R
    Robinek70
    I'm trying to write own library.
    I would like to library was configurable from sketch by #define MY_USE_ADC_FILTER similar like configuration MySensors.
    But my library don't see definition from sketch in my .h and .cpp files.
    I don't know how it is done in MySensors library.
    Could someone just explain how to achieve similar behaviour?
    Robert
    • Robinek70R Robinek70
      Robert
      @Robinek70 are the defines in the sketch before including the library? That should be sufficient. If they already are, could you share your code?
      • Robinek70R
        Robinek70R
        Robinek70
        wrote on last edited by Robinek70
        it is something like below.
        Definitions
        #define MY_ADC_PIN
        are not visible in .h and .cpp.
        I don't know what I'm doing wrong :(
        //test.ino
        #define MY_ADC_PIN
        #include <RPlibs.h>
        //RPlibs.h
        #ifndef MY_ADC_PIN
          #defie MY_ADC_PIN  A0
        #define DT_FILTER  10
        int getAdc();
        //RPlibs.cpp
        #include <RPlibs.h>
        static int prevValue ;
        int getAdc() {
          int value = analogRead(MY_ADC_PIN);
          #ifdef MY_USE_ADC_FILTER
              prevValue = (prevValue *DT_FILTER  + value) / (DT_FILTER  + 1);
          #else
              prevValue = value;
          return prevValue
          This works for me
          sketch.ino
          #define MY_ADC_PIN
          #include "RPlibs.h"
          RPlibs.h:
          #error "Define ADC set!"
          #else
          #error "Define ADC not set!"
          With the define, the build process outputs
          In file included from C:\Users\Micke\AppData\Local\Temp\arduino_modified_sketch_472392\sketch_sep20a.ino:6:0:
          RPlibs.h:2: error: #error "Define ADC set!"
          and without the define it outputs
          In file included from C:\Users\Micke\AppData\Local\Temp\arduino_modified_sketch_303778\sketch_sep20a.ino:6:0:
          RPlibs.h:4: error: #error "Define ADC not set!"
          • Robinek70R
            Robinek70R
            Robinek70
            it's very strange for me.
            I checked under two environments:
            Arduino 1.6.7 and Visual Studio 2012 with plugin Visual Micro.
            And my result of tests:
            directly under Arduino, .h file see definition from sketch, but .cpp file don't :(
            under VS definition isn't visible in .h and .cpp files.
            • Robinek70R
              Robinek70R
              Robinek70
              full test files
              File in path Arduino/Test/
              //test.ino
              #include <RPlib.h>
                Serial.println(getAdc());
              Files in path Arduino/libraries/RPlib/
              //RPlib.h
              #ifndef MY_ADC_PIN
                #define MY_ADC_PIN  A0
              int getAdc();
              //RPlib.cpp
              #include <RPlib.h>
              #include <Arduino.h>
              static int prevValue;
              int getAdc() {
              		#error  FILTER
                #else
              	#error  NO FILTER
                    prevValue = value;
                return prevValue;
              I always got
              #error NO FILTER
