  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 750.2k Views 98 Watching
  • dbemowskD dbemowsk
    @nca78 I would assume that pads 1 and 2 are capacitive touch surfaces, correct? very nice design.
    Nca78N
    Nca78N
    @dbemowsk said in What did you build today (Pictures) ?:
    Thank you !
    Yes using dirt cheap TTP223 breakouts at the back so no SMD soldering needed.
    • NeverDieN
      NeverDieN
      #182
      I received the next version of the leak detector PCB today. Putting it together, it checks out: thanks to a change in layout, it has the same board size as before, but now no clearance issues. i.e. No need for Kapton tape!
      If I had had my own PCB CNC etcher, it would have saved me the time I lost waiting for the earlier version from the fab, only to find out that the clearances were too tight and that I would have to re-do it. Looking forward to not having such delays ever again.
      • W
        W
        wergeld
        wrote on last edited by wergeld
        #183
        Christmas wreathe for the techie in all of us.
        pretty colors
        flashing
        wire wrapping
        Uses a pro mini and a lot of wire-wrapping. Other components on the circuit boards are just there for show.
        (ugh, google photos links not showing up so converted to links)
        dbemowskD 1 Reply Last reply
        • W wergeld
          pretty colors
          flashing
          wire wrapping
          dbemowskD
          dbemowskD
          @wergeld Hadn't thought of it that way... Good call....
          • R
            R
            reinhold
            wrote on last edited by reinhold
            #185
            Finally got the PCBs from AllPCB.com (cost 5 Euros and took a total of 7 days from order submission to free DHL delivery to Europe!!!) for my own MySensors Arduino Pro Mini prototyping board. Unfortunately the soldering iron broke during my assembly, so it's not fully finished and I couldn't test it yet, either...
            Arduino Pro Mini IO shield
            This board is inspired by the Nano IO shields that are offered on AliExpress and improves it further for my needs (and switched to the Pro Mini instead of the Nano).
            • Each analog and digital pin of the Pro Mini has its own VCC and GND pins,
            • the board also provides its own voltage regulator, solder pins for by NRF24L01+ and RFM69H are provided (plus the 5V->3.3V XC6206 regulator),
            • either a tiny 55-pin breadboard or three I²C connectors can be placed on the board.
            • One can also use PogoPins instead of soldering the Pro Mini (or headers for it) to burn the bootloader or change fuses on the Pro Mini via the ICSP connector.
              Using PogoPins to burn the bootloader
            All design files are available on GitHub: https://www.openhardware.io/view/538/Arduino-Pro-Mini-IO-Shield
            NeverDieN 1 Reply Last reply
            • R reinhold
              NeverDieN
              NeverDieN
              @reinhold I like how you hid the pin holes for the ICSP underneath the breadboard.
              • YveauxY
                YveauxY
                A temperature controlled PWM fan controller for my DPS5005 power supply!
                The original 2-wire fan that came with the power supply casing made an incredible amount of noise.
                Using PWM to reduce its velocity made it even more noisy :imp:
                So, I made a fresh start and ordered a quality fan (almost as expensive as the whole casing...)
                Using nothing more than a 5V pro mini, piezo speaker, DS18B20 temperature sensor and a resistor I made a full fledged fan controller ;-)
                It takes the current temp from the DS18B20 (which will be mounted on the heatsink) and ramps up the fan linearly in the 30..60 C range. Below 30 C, the fan is off.
                If RPM readback indicates a stalled fan, or DS18B20 returns wrong values the buzzer will force me to invest what's wrong :muscle:
                mfalkviddM Nca78N 2 Replies Last reply
                • YveauxY Yveaux
                  @yveaux next step is to use the piezo for active noise cancelling ;-)
                  YveauxY 1 Reply Last reply
                    YveauxY
                    YveauxY
                    @mfalkvidd don't tempt me...
                    gohanG 1 Reply Last reply
                    • YveauxY Yveaux
                      @yveaux that looks like a Noctua fan. I have a DPS5015 and I was planning to make some mods on the case (I got the other model that is bigger), so I guess I am gonna ask you for some code :D
                      • YveauxY Yveaux
                        Nca78N
                        Nca78N
                        @yveaux said in What did you build today (Pictures) ?:
                        Less funny that way but did you try to lower the PWM frequency of the atmega to it's minimum ? I had the same problem with the fan I put in my fridge cabinet and low PWM frequency solved it.
                        • Nca78N Nca78
                          YveauxY
                          YveauxY
                          @nca78 I did fiddle with the frequency, but the fan was just total crap, so I decided to replace it anyhow.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Yveaux @Nca78
                            An RC filter could probably also make wonders for the fan. I had to add one for the parts fan on my 3D printer. Couldn't control the speed with PWM without the RC filter..
                            Btw. probably a bit over the top of using an arduino as fan control? Unless you plan on adding a NRF radio, and report the temperature + PWM duty cycle to your mysensors system, and store the values in influxdb? ;)
                            NeverDieN YveauxY 2 Replies Last reply
                            • tbowmoT tbowmo
                              @Yveaux @Nca78
                              NeverDieN
                              NeverDieN
                              #194
                              @tbowmo said in What did you build today (Pictures) ?:
                              Really? How so? Seems like the end result will be as quiet as possible, yet avoids stalling.
                              • NeverDieN NeverDie
                                YveauxY
                                YveauxY
                                @neverdie said in What did you build today (Pictures) ?:
                                Indeed! I thought of going the analog way, but the final solution would be more expensive, I didn't have the parts at hand, it wouldn't have as many features and it would have cost me a lot more time...
                                • tbowmoT tbowmo
                                  @Yveaux @Nca78
                                  YveauxY
                                  YveauxY
                                  Probably, but again, the fan was total crap and made a lot of wind noise due to the bad condition of its blades.
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    a 555 and a couple of resistors / capacitors.. ;)
                                    https://electronics.stackexchange.com/questions/91102/555-temperature-controlled-pwm
                                    But then again, I recon that most of us might have more atmega328 based boards, than 555's in the parts bin :)
                                    about the RC for PWM, it was meant as a hint for others that might fight problems with a fan that they couldn't control properly with PWM..
                                    ben999B YveauxY 2 Replies Last reply
                                    • tbowmoT tbowmo
                                      ben999B
                                      ben999B
                                      ben999
                                      @tbowmo 555s need knowledge... i wouldn't know what to do with these :/ except cufflinks
                                      arduinos are much more accessible ;)
                                      • tbowmoT tbowmo
                                        YveauxY
                                        YveauxY
                                        Still, no tacho readback to detect stalled fans, no temperature sensor verification or overtemperature warning, no initial fan spinup and little control over how the fans reacts to temperature changes....
                                          #200
                                          Testing a flow meter.
                                          It works pretty well, but at high flow rates (90 pulses per second) the esp8266 resets. Not sure if the reset is caused by too many interrupts or if the sensor uses too much power.
