  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 750.7k Views 98 Watching
  • alowhumA
    alowhumA
    alowhum
    #841
    I didn't build this myself, but I did create the code. It's a MySensors CO2 sensor that is part of a 'privacy friendly smart home of the future' which will be launched later this year.
    It was made by artist and jeweler Dinie Besems. All her creations feature small 'skirts' that you can lift to see the data, or cover up the screen if you have visitors and don't want them to immediately see your data.
      mcchots
      Etched and soldered a new gateway after the original one I had failed.
      • scalzS
        scalzS
        wrote on last edited by scalz
        #843
        Meet Janus project, a premium USB dongle by Tekka and me :sunglasses:
        Dual RF gateway with external antennas.
        • nrf52840 with 20dB PA + SMA connector. So it can be compatible with MySensors, and/or zigbee..
        • rfm69hcw/rfm95 long range + SMA connector . module has all DIO pins routed for sw driver optimizations.
        • reset button
        • user button
        • RGB led
        • high PSRR RF/analog 700mA LDO
        • usb protected
        • 4layers board
        • enclosure size : 52x21 (thickness 11mm). compact!
        Enclosure is just a quick proto, I'll improve quality, or I would like to try online multijet service, I'm curious :)
        It's very recommended, for better performance, to have some distance between antennas.
        So, for example, I'll use a shorter antenna (without cable) for 2.4ghz, and a "remote" antenna (with a cable) for 433/868/905Mhz, so it can be used with different kind of antennas.
        We choosed external antennas, because
        • versatile use
        • better range especially when dongle is close to lot of stuff which could affect range in case of a pcb antennas
        RedferneR Nca78N berkseoB 3 Replies Last reply
        • scalzS scalz
          • reset button
          • user button
          • RGB led
          • usb protected
          • 4layers board
          • versatile use
          RedferneR
          RedferneR
          Redferne
          @scalz ohh! Where can I order one?
          • scalzS scalz
            • reset button
            • user button
            • RGB led
            • usb protected
            • 4layers board
            • versatile use
            Nca78N
            Nca78N
            Wow @scalz that's a badass gateway dongle, any pictures of the inside ?
            Do we have more chances to see that becoming available, than HALO and Aeos ? :D
            • scalzS
              scalzS
              #846
              thx for interests guys :)
              I'm just not sure if there would be enough interest for me to produce. I've not really thought about it! It's the first board of the batch.
              I call it a premium dongle because
              • it's 4layers. It's just a little bit more expensive than 2layers. But quality is a lot increased (better impedance, full gnd plane, better routing etc). It's also recommended by lot of rf module manufacturers for topnotch perf
              • I uses the high quality BT840XE module. As you know, it's a well documented and known module, and it's CE/FCC (better, as it includes a 20dB PA).
                Actually I just use a few pins on edges, and 18 pads under it..
                I had the choice to use this module, or to design mine with a frontend, but for once, I decided to go "simple" for a quick debug. And the price difference vs homemade, maybe +10€, is worth it imho, time saver, and I don't mind I just need one!
              Why did I make it? Because I can and would be pity to deprive myself :)
              And we can have a nice and reliable dongle for the team, just in case.
              You're right I have others hobby projects, they're not dead.. :sweat_smile:
              • just lost a bit of interest on Aeos release, I agree on this, because I prefer subghz for mysensors, and would like to keep 2.4 for others protocols.
              • Halo is not dead, actually it's one my favorite. I just need to find a way to include Janus in my "serverless" project which is mostly ethernet based (I made a full webapp, that I'm porting to true native crossplatform sw, android phone+tv, windows, linux, for better experience). "serverless" meaning optional rpi/computer
              Oki, I'll post others pics soon.
              • scalzS
                scalzS
                This evening I assembled another dongle (and a few other boards).
                @nca78 as you asked, here is a pic during tests. Tiny dual rf dongle board, isn't it :)
                :sunglasses:
                berkseoB 1 Reply Last reply
                • scalzS scalz
                  • reset button
                  • user button
                  • RGB led
                  • usb protected
                  • 4layers board
                  • versatile use
                  berkseoB
                  berkseoB
                  berkseo
                  @scalz How do you plan to use your dongle? Just as coordinator? or only as a gateway mysensors? Have you tried using it as a combo? zigbee quite unceremoniously uses the resources of the mcu.
                  • scalzS scalz
                    :sunglasses:
                    berkseoB
                    berkseoB
                    berkseo
                    @scalz said in What did you build today (Pictures) ?:
                    This customization boards adafruit? I've customized the Board Sandeep Mistry.
                    scalzS 1 Reply Last reply
                    • simboS
                      simboS
                      simbo
                      wrote on last edited by simbo
                      #850
                      Air particulate sensor.
                      BTW, solder fumes seem to be bad for you........
                      2_1568765899621_Photo 18-9-19, 9 57 10 am-1.jpg 1_1568765899621_Photo 18-9-19, 9 50 34 am-1.jpg 0_1568765899620_Photo 18-9-19, 9 44 38 am-1.jpg
                      • berkseoB berkseo
                        scalzS
                        scalzS
                        #851
                        @berkseo
                        • like I said, MySensors bridge, combo . Yes I know about resources.
                          Note: zigbee is out of MySensors scope (not arduino code), so for the moment some ideas and POCs will be local, not making money no ETA, still lot of WIPs and the daily job!
                        • yes.
                        • FotoFieberF
                          FotoFieberF
                          FotoFieber
                          Modified a laser filament sensor (pat9125, used with Prusa mk3) to be used with an ESP32.
                          Maybe I will use it as a filament stuck sensor with octoprint. Or a filament meter?
                          • pihomeP
                            pihomeP
                            pihome
                            Very first attempt to solder smd components on pcb with hot air soldering station. lots of mistakes but i m learning...
                            PiHome - Smart Heating Control
                            • zboblamontZ
                              zboblamontZ
                              zboblamont
                              First of the winter projects done, just the programming to finish and replacement temperature chips to get (broke the legs off both DS18B20s through clumsiness).
                              With mains/battery backup and RTC, it will record boiler start/stop and run times as well as feed/return temperatures, and as an aside the inevitable power cuts which plague this part of the world.
                              The MCU plugs into a socketed backplane hot-glued to the back of the box should removal prove necessary, but quite pleased it is sturdy and all fitted into a slim 25mm deep standard (cheap) box.
                              • berkseoB
                                berkseoB
                                berkseo
                                wrote on last edited by berkseo
                                #855
                                My brand new device on nRF52840. It is a light and shock(vibration) sensor.
                                Two sensors are used, max44009 light sensor (1 ua) and lis2dw accelerometer (1 ua).
                                The light sensor measures in Lux.
                                The shock sensor has five levels of sensitivity.
                                Two modes of operation: main (working) mode and command reception mode.
                                The sensor accepts settings: the interval of sending data from the light sensor (in minutes), sending recalculated light data from Lux to watts per meter squared(on/off), the sensitivity level of the shock sensor(5 levels, 1 to 5)
                                Depending on which sensors are installed on the PCB, it can be used only as a light sensor, only as a shock sensor or both.
                                In the near future the project will be posted on openhardware.io
                                video (inside view of the sensor, an example of working with a smart home, an example of setting): - https://youtu.be/I2ywIxp-RsE
                                NeverDieN 1 Reply Last reply
                                • berkseoB berkseo
                                  NeverDieN
                                  NeverDieN
                                  #856
                                  @berkseo this would also be good for monitoring when the trash cans get picked up by the garbage truck. If it has enough range that is. Of course that wouldn't apply to high rise dwellers, but for people in houses it would be a nice perk.
                                  • pihomeP
                                    pihomeP
                                    pihome
                                    working on GPIO MySensors Gateway
                                    1_1575232762237_PiHome GPIO Gateway_v001.png 0_1575232762236_PiHome GPIO Gateway_v001 v3.png
                                    pihomeP 1 Reply Last reply
                                    • berkseoB
                                      berkseoB
                                      berkseo
                                      #858
                                      An updated version of my temperature and humidity sensor with e-ink. Now on nRF52840. Now it is not a module but a device in the case.
                                      Replaced temperature sensor sht20 -- > > si7020
                                      Added accelerometer.
                                      In the near future the project will be posted updated on the website openhardware.io
                                      0_1575378314466_photo_2019-11-17_21-14-04.jpg 0_1575378328998_photo_2019-11-17_21-13-56.jpg
                                      1_1575378360290_photo_2019-11-17_21-14-30.jpg 0_1575378360290_photo_2019-11-17_21-14-15.jpg
                                      Video: https://youtu.be/T66y83lF-xg
                                      • franz-unixF
                                        franz-unixF
                                        franz-unix
                                        Amazing! 😃
                                        The case is 3d printable?
                                        • franz-unixF franz-unix
                                          Amazing! 😃
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          @franz-unix
                                          This is made on SLA printer, but should normally print on FDM
                                          Nca78N franz-unixF 2 Replies Last reply
