1.1k Posts 105 Posters 790.5k Views 98 Watching
    This evening I assembled another dongle (and a few other boards).
    @nca78 as you asked, here is a pic during tests. Tiny dual rf dongle board, isn't it :)
    :sunglasses:
    berkseoB 1 Reply Last reply
    • scalzS scalz
      Meet Janus project, a premium USB dongle by Tekka and me :sunglasses:
      Dual RF gateway with external antennas.
      • nrf52840 with 20dB PA + SMA connector. So it can be compatible with MySensors, and/or zigbee..
      • rfm69hcw/rfm95 long range + SMA connector . module has all DIO pins routed for sw driver optimizations.
      • reset button
      • user button
      • RGB led
      • high PSRR RF/analog 700mA LDO
      • usb protected
      • 4layers board
      • enclosure size : 52x21 (thickness 11mm). compact!
      Enclosure is just a quick proto, I'll improve quality, or I would like to try online multijet service, I'm curious :)
      It's very recommended, for better performance, to have some distance between antennas.
      So, for example, I'll use a shorter antenna (without cable) for 2.4ghz, and a "remote" antenna (with a cable) for 433/868/905Mhz, so it can be used with different kind of antennas.
      We choosed external antennas, because
      • versatile use
      • better range especially when dongle is close to lot of stuff which could affect range in case of a pcb antennas
      berkseoB
      berkseoB
      berkseo
      @scalz How do you plan to use your dongle? Just as coordinator? or only as a gateway mysensors? Have you tried using it as a combo? zigbee quite unceremoniously uses the resources of the mcu.
      • scalzS scalz
        :sunglasses:
        berkseoB
        berkseoB
        berkseo
        @scalz said in What did you build today (Pictures) ?:
        This customization boards adafruit? I've customized the Board Sandeep Mistry.
        scalzS 1 Reply Last reply
        • simboS
          simboS
          simbo
          wrote on last edited by simbo
          #850
          Air particulate sensor.
          BTW, solder fumes seem to be bad for you........
          2_1568765899621_Photo 18-9-19, 9 57 10 am-1.jpg 1_1568765899621_Photo 18-9-19, 9 50 34 am-1.jpg 0_1568765899620_Photo 18-9-19, 9 44 38 am-1.jpg
          • berkseoB berkseo
            #851
            @berkseo
            • like I said, MySensors bridge, combo . Yes I know about resources.
              Note: zigbee is out of MySensors scope (not arduino code), so for the moment some ideas and POCs will be local, not making money no ETA, still lot of WIPs and the daily job!
            • yes.
            • FotoFieberF
              FotoFieberF
              FotoFieber
              Modified a laser filament sensor (pat9125, used with Prusa mk3) to be used with an ESP32.
              Maybe I will use it as a filament stuck sensor with octoprint. Or a filament meter?
              • pihomeP
                pihomeP
                pihome
                Very first attempt to solder smd components on pcb with hot air soldering station. lots of mistakes but i m learning...
                PiHome - Smart Heating Control
                • zboblamontZ
                  zboblamontZ
                  zboblamont
                  First of the winter projects done, just the programming to finish and replacement temperature chips to get (broke the legs off both DS18B20s through clumsiness).
                  With mains/battery backup and RTC, it will record boiler start/stop and run times as well as feed/return temperatures, and as an aside the inevitable power cuts which plague this part of the world.
                  The MCU plugs into a socketed backplane hot-glued to the back of the box should removal prove necessary, but quite pleased it is sturdy and all fitted into a slim 25mm deep standard (cheap) box.
                  • berkseoB
                    berkseoB
                    berkseo
                    #855
                    My brand new device on nRF52840. It is a light and shock(vibration) sensor.
                    Two sensors are used, max44009 light sensor (1 ua) and lis2dw accelerometer (1 ua).
                    The light sensor measures in Lux.
                    The shock sensor has five levels of sensitivity.
                    Two modes of operation: main (working) mode and command reception mode.
                    The sensor accepts settings: the interval of sending data from the light sensor (in minutes), sending recalculated light data from Lux to watts per meter squared(on/off), the sensitivity level of the shock sensor(5 levels, 1 to 5)
                    Depending on which sensors are installed on the PCB, it can be used only as a light sensor, only as a shock sensor or both.
                    In the near future the project will be posted on openhardware.io
                    video (inside view of the sensor, an example of working with a smart home, an example of setting): - https://youtu.be/I2ywIxp-RsE
                    • berkseoB berkseo
                      #856
                      @berkseo this would also be good for monitoring when the trash cans get picked up by the garbage truck. If it has enough range that is. Of course that wouldn't apply to high rise dwellers, but for people in houses it would be a nice perk.
                      • pihomeP
                        pihomeP
                        pihome
                        working on GPIO MySensors Gateway
                        1_1575232762237_PiHome GPIO Gateway_v001.png 0_1575232762236_PiHome GPIO Gateway_v001 v3.png
                        pihomeP 1 Reply Last reply
                        • berkseoB
                          berkseoB
                          berkseo
                          #858
                          An updated version of my temperature and humidity sensor with e-ink. Now on nRF52840. Now it is not a module but a device in the case.
                          Replaced temperature sensor sht20 -- > > si7020
                          Added accelerometer.
                          In the near future the project will be posted updated on the website openhardware.io
                          0_1575378314466_photo_2019-11-17_21-14-04.jpg 0_1575378328998_photo_2019-11-17_21-13-56.jpg
                          1_1575378360290_photo_2019-11-17_21-14-30.jpg 0_1575378360290_photo_2019-11-17_21-14-15.jpg
                          Video: https://youtu.be/T66y83lF-xg
                          • franz-unixF
                            franz-unixF
                            franz-unix
                            Amazing! 😃
                            The case is 3d printable?
                            • franz-unixF franz-unix
                              Amazing! 😃
                              berkseoB
                              berkseoB
                              berkseo
                              @franz-unix
                              This is made on SLA printer, but should normally print on FDM
                              Nca78N franz-unixF 2 Replies Last reply
                              • pihomeP pihome
                                pihomeP
                                pihomeP
                                pihome
                                @pihome just realized one big blunder, The NSS, MOSI and SCK are not 5V tolerant on RFM69. hence need level converter :(
                                i was wondering is there any one ic can can do instead i have to used BSS138 per pin.
                                • berkseoB berkseo
                                  #862
                                  @berkseo I'm quite interested in a schematic view showing how the epaper gets wired up, because priced just by itself epaper seems like an affordable solution.
                                  aliexpress.com/item/32962453684.html?spm=a2g0o.productlist.0.0.3e97287fLkUbFb&algo_pvid=9af4e6cf-0e45-470a-925d-b0b1d62212d5&algo_expid=9af4e6cf-0e45-470a-925d-b0b1d62212d5-0&btsid=e444f3d1-9949-4c49-ada6-376ecc83a846&ws_ab_test=searchweb0_0,searchweb201602_8,searchweb201603_55
                                  or
                                  https://www.aliexpress.com/item/32810660608.html?spm=a2g0o.detail.1000013.1.10ee3442rep8pS&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.146401.0&scm_id=1007.13339.146401.0&scm-url=1007.13339.146401.0&pvid=8e948464-a786-4cf4-96ff-86c51f67bf4c
                                  On the other hand, if one has to rely on adafruit or similar for an epaper breakout board to make use of it, the effective price jumps by around 5-6x or so.
                                  monteM 1 Reply Last reply
                                    or
                                    monteM
                                    monteM
                                    monte
                                    wrote on last edited by monte
                                    #863
                                    @neverdie you can use this and this as a reference. No need to buy ready breakout board, if you know how to trace your own.
                                    • bjacobseB
                                      bjacobseB
                                      bjacobse
                                      https://github.com/dkjonas/Wavin-AHC-9000-mqtt
                                      iron and toner transfer, then etched and soldered and finally acrylic spray on cobber so it won't corrode
                                      • Nca78N
                                        Hello, as it was getting seriously off topic, I moved the discussion related to SLA printing of enclosure to here :
                                        https://forum.mysensors.org/topic/10815/printing-enclosures-with-sla-printers
                                        Feel free to suggest a better title.
                                        • nagelcN
                                          nagelcN
                                          nagelc
                                          wrote on last edited by nagelc
                                          #866
                                          I've had surprisingly good luck buying cheap parts from Ali-express, but not this time. I bought an NRF52832 iBeacon that supposedly had an SHT30 temperature sensor and KX022 accelerometer. When the parts arrived, neither of those parts were populated. All the beacon has is a push button.
                                          I was able to program it to work with MySensors, however. With only SWIO and SWCLK (no txt out), I took @scalz advice (in another topic) and used a J-Link EDU Mini so I could use the RTT app to get printf style debugging. That worked nicely and I learned a new tool.
                                          Perhaps I can use the iBeacon button for a remote.
